hasank 3 Posted April 24, 2022 Tinker Board 2 Debian 10 V2.0.4 does not mount external disk stably. After a while the system starts, it mounts and does not work properly. After a while, the files on the disk are not read. As such, a clean install is required. Then again I am having the same problem. Is there a way to mount an external disk in a stable and healthy way? Share this post Link to post Share on other sites
tooz 56 Posted June 15, 2022 hello @hasank, we cannot reproduce the issue, but for most cases external disks without individual power supply consume a lot of power that causes connection problem. we'd suggest to use a seperate power supply for the external disk, otherwise use an usb hub with external power supply. 1 Share this post Link to post Share on other sites
hasank 3 Posted August 5, 2022 Thank you for the answer. I tried an external power supply as you said. However, my problem remains the same. I think I've identified the problem. When the external hard drive goes to sleep, it does not wake up again. How can I solve this problem? Share this post Link to post Share on other sites
tooz 56 Posted August 8, 2022 hello @hasank, what is the output of the external power supply? if it's < 1A, it's most likely that the board is not receiving enough power. we'd suggest having an external power supply with output > = 1.5A. Share this post Link to post Share on other sites
tooz 56 Posted August 9, 2022 hello @hasank, this command might help -- to disable usb runtime suspend; the controller & phy will not be on low power mode for i in $(find /sys -name control | grep usb);do echo on > $i;echo "echo on > $i";done; Share this post Link to post Share on other sites
