wahaha 4 Posted November 2, 2022 I was trying to enable config for bpf in tinker_def_config. # Bpf config CONFIG_BPF=y CONFIG_BPF_SYSCALL=y CONFIG_BPF_JIT=y CONFIG_NET_CLS_BPF=y CONFIG_NET_CLS_ACT=y CONFIG_NET_SCH_INGRESS=y CONFIG_CRYPTO_SHA1=y But came up with these errors: In file included from ./include/linux/bpf_verifier.h:11:0, from kernel/bpf/verifier.c:17: kernel/bpf/verifier.c: In function 'fixup_bpf_calls': kernel/bpf/verifier.c:6131:36: error: 'BPF_JMP32' undeclared (first use in this function); did you mean 'BPF_JMP_A'? BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6131:36: note: each undeclared identifier is reported only once for each function it appears in BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6140:34: warning: pointer/integer type mismatch in conditional expression error, forbidden warning:verifier.c:6140 BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6140:47: error: invalid operands to binary | (have 'struct bpf_insn *' and 'int') BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6141:19: error: invalid operands to binary | (have 'struct bpf_insn *' and 'int') BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ~ BPF_JEQ | BPF_K, insn->src_reg, ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6140:18: warning: initialization makes integer from pointer without a cast [-Wint-conversion] error, forbidden warning:verifier.c:6140 BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ kernel/bpf/verifier.c:6140:18: note: (near initialization for '(anonymous).code') BPF_RAW_INSN((is64 ? BPF_JMP : BPF_JMP32) | ^ ./include/linux/filter.h:317:12: note: in definition of macro 'BPF_RAW_INSN' .code = CODE, \ ^~~~ CC kernel/locking/mutex.o CC fs/configfs/file.o make[2]: *** [scripts/Makefile.build:334: kernel/bpf/verifier.o] Error 1 make[2]: *** Waiting for unfinished jobs.... CC kernel/bpf/helpers.o CC mm/fadvise.o CC fs/configfs/dir.o Please help. Share this post Link to post Share on other sites
