Jump to content
Sign in to follow this
Poko-san
Can't work USB WebCamera
Recommended Posts
I have some USB Web Camera (UVC), but all of them doesn't work.
Do I need to make any settings to be able to use the webcam?
[ Testing environment ]
Tinker board 2S
(1)Debian10 v2.0.14
(2)Debian v2.1.6
I tried both OS as clean installed environment.
(a)Pre-installed "Cheese" Application
(b)Pre-installed "Qt V4L2 test Utility" Application
[Result]
(1) and (2) are same result.
Normaly, /dev/video0 ~ video4 are appears.
Then pluged the USB Web Camera, /dev/video5 and /dev/video6 are added.
$ v4l2-ctl -d /dev/video5 -all
video5 seems video device, and video6 seems other device.
(a) : Shows "There wan an error playing video from the webcam" Error.
   Probably auto selected video0 as a default device.
    There should be a preferences menu in the Cheese app and can select video5, but the settings menu can't be displayed (probably a bug)
(b):File > Open Device > device5, then crashed application and desktop...
Share this post
Link to post
Share on other sites
hello @Poko-san,
i've used tinker board 2s with debian 10 v.2.0.14
installed qv4l2 test utility, cheese and vlc - there's some compatibility that i cannot use cheese to take/ preview photos or videos
using qv4l2:
open qv4l2 -> open device -> select video5 -> start capturing
uvc running successfully
i've tried using vlc media player:
open media -> capture device -> video device name '/dev/video5' in my case
and it works too
what's the usb video camera you're using?
i'll look into the issues happened in cheese too, but if it's a compatibility limitation, we'd suggest to use another package
Share this post
Link to post
hello @Poko-san,
we've used v.2.1.6 & v.2.0.14 for uvc testing,
using cheese:
you will have to switch to usb camera first, to do so, please use the "Camera Product Name"
1. you can check the Product Name with the following command in lxterminal:
$ udevadm info /sys/class/video4linux/video5 | grep ID_V4L_PRODUCT
ID_V4L_PRODUCT=Logitech Webcam C930e
in this case the Camera Product Name is "Logitech Webcam C930e"
2. then you can open the camera with the command:
$ cheese -d “Logitech Webcam C930e”
we've tested 1080p/480p MJPG & YUYV configs with qv4l2 and both configs work.
may we know which usb cam you're using and the configs?
we've used another unknown branded usb web cam and have noticed that unstable connection can lead to failure such as
cheese:1291): cheese-WARNING **: 10:17:11.512: Failed to allocate required memory.: gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin29/GstV4l2Src:v4l2src2:
Buffer pool activation failed
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
