ksh 0 Posted December 12, 2022 when i open up terminal and command cat /sys/module/usbcore/parameters/autosuspend it answer 2 it means autosuspend is on working i want to disable it,so i search for its method almost says edit /etc/default/grub but tinkerboard debian don't exist that file so, this is problem how to i change autosuspend 2 to -1? Share this post Link to post Share on other sites
tooz 56 Posted December 19, 2022 hello @ksh, you can modify the cmdline.txt in /boot/ to diasble autosuspend: sudo vim /boot/cmdline.txt add the following line: usbcore.autosuspend=-1 just delete this line if you'd want to enable autosuspend again (which means set it back to default) Share this post Link to post Share on other sites
