esperal 0 Posted June 28, 2024 Hi, I'm looking for a way to remotely (no physical access to the device) find out what version of TB2S I'm working on. The only visible physical difference I know about is that the second revision has RAM chips secured with underfill, but I need to be able to tell remotely. I haven't found any differences in Debian's System Information except for the serial number - any chance assess the version based on SN? Thanks in advance! Share this post Link to post Share on other sites
tooz 56 Posted June 29, 2024 hello @esperal, you can check the hardware version with command: cat /proc/boardinfo 1 Share this post Link to post Share on other sites
esperal 0 Posted July 1, 2024 Thank you, @tooz. Unfortunately, it only shows 'Tinker Board 2' in both V1 and V2 cases. Share this post Link to post Share on other sites
tooz 56 Posted July 2, 2024 hello @esperal, my bad, i thought you're talking about tinker board and tinker board 2s, please try cat /proc/boardid this command instead: 1 Share this post Link to post Share on other sites
esperal 0 Posted July 2, 2024 You're a star, @tooz! Exactly what I was looking for 🙂 Thank you very much! Share this post Link to post Share on other sites
