Frank 0 Posted April 1, 2025 Hey there, i want to compile a kernel for the Tinker Board S version V3.0.23. But i can't find the kernel code for that version.... On GitHub the latest kernel code data is for Tinker Board Debian 10 V3.0.11 Could you please provide the kernel cod for your latest version? Frank Share this post Link to post Share on other sites
tooz 56 Posted April 1, 2025 hello @Frank, https://tinkerboard.github.io/docs/tinker_os-releases/tinker_board the branch is: linux4.4-rk3288-tinker_board manifest: tinker_board-debian-3.0.23.xml if you'd like to use the latest: repo init -u https://github.com/TinkerBoard-Linux/rockchip-linux-manifest.git -b REVISION Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 @tooz thanks for the link. I will have a look into this. Is it still possible to remove the TinkerBoard bootimage when recompiling the kernel with an empty black image? Frank Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 Is it possible to use v3.0.27 für the TinkerBoard S too? Share this post Link to post Share on other sites
tooz 56 Posted April 2, 2025 hello @Frank, 12 minutes ago, Frank said: Is it still possible to remove the TinkerBoard bootimage when recompiling the kernel with an empty black image? yes, please refer to wiki: Developer Guide · TinkerBoard/TinkerBoard Wiki · GitHub >change the boot logo 6 minutes ago, Frank said: Is it possible to use v3.0.27 für the TinkerBoard S too? yes Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 I was able to setup the docker build environment container. But when i try to build the image i get the following error after some time... I: Extracting liblzma5... I: Extracting zlib1g... P: Running debootstrap second stage under QEMU chroot: failed to run command '/usr/bin/env': Exec format error P: Begin unmounting filesystems... P: Saving caches... if [ -f binary-tar.tar.gz ]; then \ tar -jcf linaro-buster-alip-`date +%Y%m%d`-1.config.tar.bz2 auto/ config/ configure; \ sudo mv binary.contents linaro-buster-alip-`date +%Y%m%d`-1.contents; \ sudo mv chroot.packages.live linaro-buster-alip-`date +%Y%m%d`-1.packages; \ sudo mv binary-tar.tar.gz linaro-buster-alip-`date +%Y%m%d`-1.tar.gz; \ md5sum linaro-buster-alip-`date +%Y%m%d`-1.build-log.txt linaro-buster-alip-`date +%Y%m%d`-1.config.tar.bz2 linaro-buster-alip-`date +%Y%m%d`-1.contents linaro-buster-alip-`date +%Y%m%d`-1.packages linaro-buster-alip-`date +%Y%m%d`-1.tar.gz > linaro-buster-alip-`date +%Y%m%d`-1.md5sums.txt; \ sha1sum linaro-buster-alip-`date +%Y%m%d`-1.build-log.txt linaro-buster-alip-`date +%Y%m%d`-1.config.tar.bz2 linaro-buster-alip-`date +%Y%m%d`-1.contents linaro-buster-alip-`date +%Y%m%d`-1.packages linaro-buster-alip-`date +%Y%m%d`-1.tar.gz > linaro-buster-alip-`date +%Y%m%d`-1.sha1sums.txt; \ fi Failed to run livebuild, please check your network connection. \033[36m Run mk-base-debian.sh first \033[0m Extract image tar: linaro-buster-armhf.tar.gz: Cannot open: No such file or directory tar: Error is not recoverable: exiting now umount: binary/dev: no mount point specified. ERROR: Running build_debian failed! ERROR: exit code 32 from line 642: VERSION=${VERSION} VERSION_NUMBER=${VERSION_NUMBER} ARCH=$ARCH ./mk-rootfs-buster.sh What i'm doing wrong? How to fix this? Frank Share this post Link to post Share on other sites
tooz 56 Posted April 2, 2025 hello @Frank, 34 minutes ago, Frank said: chroot: failed to run command '/usr/bin/env': Exec format error did this happen when you run ./build.sh? you might want to install qemu-user-static and then copy it to the mounted point e.g. /mnt/usr/bin sudo apt install qemu-usr-static sudo cp /usr/bin/qemu-arm-static /path/to/mount/usr/bin and then restart the system systemctl restart systemd-binfmt.service Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 Yes the error occured when i try to run ./build.sh Should i install "qemu-user-static" inside the docker container or on the host system (Ubuntu 24.04)? Inside the container it was installed already. What mountpoint do you mean? I haven't mounted anything.... I just synced the repository and installed docker on the host system. After that is startetd the docker run cmd "docker-builder-run.sh" When the container was ready i tried to build with "./buils.sh" Share this post Link to post Share on other sites
tooz 56 Posted April 2, 2025 hello @Frank, is your host machine an x86 host? if so, the steps above is to set up the right environment as tinkerboard is arm based Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 My host system is x86_64 (Ubuntu 24.04 on Windows 11 - wsl) Share this post Link to post Share on other sites
Frank 0 Posted April 2, 2025 The file "qemu-arm-static" is present under /usr /bin on the host system and inside the docker container.... Share this post Link to post Share on other sites
tooz 56 Posted April 3, 2025 if you're using a x86 wsl there might be something relates to architecture similar to: https://askubuntu.com/questions/1006846/chroot-onto-arm-based-image it's necessary to have qemu supported in aarch64/ arm64. some reference: https://www.cnx-software.com/2016/05/10/how-to-run-ubuntu-16-04-aarch64-64-bit-arm-cloud-images-on-your-intelamd-linux-computer/ the easiest way to cross compile would be having a ubuntu host machine Share this post Link to post Share on other sites
Frank 0 Posted April 3, 2025 Hi @tooz, i switched to an Ubuntu 24.04 native machine. The problem from yesterday did not appear on this machine. But i get another error after some time when i try to build the image with ./build.sh ake: Leaving directory '/source/buildroot' ====Start build rockchip_rk3288_recovery==== 2025-04-03T10:24:23 >>> host-bison 3.0.4 Extracting Done in 5s (error code: 2) Command exited with non-zero status 2 you take 0:05.22 to build recovery ERROR: Running build_recovery failed! ERROR: exit code 2 from line 719: /usr/bin/time -f "you take %E to build recovery" $COMMON_DIR/mk-ramdisk.sh recovery.img $RK_CFG_RECOVERY Can you please help me to solve this issue? Tanks. Frank Share this post Link to post Share on other sites
Frank 0 Posted April 4, 2025 @tooz Same result when i try to build the image using an Ubuntu 20.04 host machine (same as docker container) Please help Share this post Link to post Share on other sites
tooz 56 Posted April 8, 2025 hello @Frank, were you able to use buildroot? may i have the full log please? Share this post Link to post Share on other sites
Frank 0 Posted April 10, 2025 @tooz Finaly i got it running. Some packages are not available anymore on the defined sources. So we need to download them from other websites. After reading a lot of logfiles and catching all packages it was working. But i have still some questions. 1. Do you have some kind of documentation for the commands of the asus-docker-env. We were not able to find something. 2. The other question is if there is a documentation about the changes from the v3.0.27 to the latest manifest? Frank Share this post Link to post Share on other sites
Frank 0 Posted April 11, 2025 BTW Building the Image under Windows 11 using WSL with Distro Ubuntu 20.04 is working too Ubuntu 20.04 seems to be the last supported OS version for the asus-docker-env GitHub - asus-iot/asus-docker-env Share this post Link to post Share on other sites
tooz 56 Posted April 11, 2025 hello @Frank 22 hours ago, Frank said: 2. The other question is if there is a documentation about the changes from the v3.0.27 to the latest manifest? Disable auto login for the uart console and the dekstop environment. Force the user linaro to change its password at the linaro's next login Eable ROCKCHIP_EFUSE config for u-boot to set cpuid from efuse to fix the issue that all CPU has the same ID Share this post Link to post Share on other sites
Frank 0 Posted April 11, 2025 @tooz You don't get me. I want to know what are the changes between the v3.0.27 build (current releas from Asus) and the version i can build with manifest "latest". Is it the same? The changes from v3.0.23 to v3.0.27 are clear to me.... Share this post Link to post Share on other sites
tooz 56 Posted April 11, 2025 hello @Frank, sorry for the confusion, that's correct. the latest version is v.3.0.27 Share this post Link to post Share on other sites
tooz 56 Posted April 16, 2025 hello @Frank, On 4/10/2025 at 8:14 PM, Frank said: 1. Do you have some kind of documentation for the commands of the asus-docker-env. We were not able to find something. To set up the environment: Install docker and asus-docker-env Follow GitHub - asus-iot/asus-docker-env to run asus_docker_env_run Install necessary packages below : sudo apt-get install libgmp-dev sudo apt-get install libmpc-dev sudo apt-get install bsdmainutils sudo apt-get remove live-build git clone https://salsa.debian.org/live-team/live-build.git --depth 1 -b debian/1%20230131 cd live-build rm -rf manpages/po/ sudo make install -j8 Use build.sh to build code base Share this post Link to post Share on other sites
