Jump to content
Fu-.
wiringPi problem
Recommended Posts
I want to use wiringPi on Tinker2S.
I'm trying to use GPIO Pin#15 (wiring Pi Pin#3) as a pull-down input, but after a bit of research, it seems to be acting like it's latching. Once the Input goes High, the input does not drop to Low after that.
Is there a good solution?
Share this post
Link to post
Share on other sites
I wrote and test this dts;
/dts-v1/;
/plugin/;
        compatible = "rockchip,rk3399";
        /* disable spi5 */
        fragment@0 {
                target = <&spi5>;
                __overlay__ {
                        status = "okay";
                        spi5 {
                                status = "disabled";
        fragment@1 {
                target-path = "/";
                __overlay__ {
                    gpio15 {
                                compatible = "gpio2";
                                pinctrl-names = "default";
                                pinctrl-0 = <&gpio_pins>;
                                gpios = <&gpio2 20 0>;
                                status = "okay";
        fragment@2 {
                target = <&gpio2>;
                __overlay__ {
                        gpio_pins: gpio_pins {
                                rockchip,pins = <2 20 0 &pcfg_pull_down>;
However, this did not work.
It still behaves as if it is latching.
Share this post
Link to post
On 6/16/2021 at 12:54 PM, Fu-. said:
Hi Fu,
Please refer the following examples
[Image Version]
Tinker_Board_2-Android10-V1.0.0-20210318.img
[Example]
/usr/local/share/gpio_lib_c_rk3399/examples/isr.c
/usr/local/share/gpio_lib_c_rk3399/examples/isr-osc.c
[Step]
1.  cd /usr/local/share/gpio_lib_c_rk3399/examples
2.  sudo make isr
3.  sudo ./isr
4.  GPIO #15 (wiring Pi #3) pulled down <-> up switch
4.  Output:
     Waiting ...  Int on pin 3: Counter:     1
     Waiting ...  Int on pin 3: Counter:     2
     Waiting ...  Int on pin 3: Counter:     3
Share this post
Link to post
/dts-v1/;
/plugin/;
        /* disable spi5 */
        fragment@0 {
                target = <&spi5>;
                __overlay__ {
                        status = "okay";
                        spi5 {
        fragment@1 {
                target-path = "/";
                __overlay__ {
                    gpio15 {
                                status = "okay";
        fragment@2 {
                target = <&gpio2>;
                __overlay__ {
You can try to modify Pin define from /boot/config.txt
And run "gpio readall"  to get list
Share this post
Link to post
Thanks Joe,
I tried your sample, but I still have problems.
A High is input to GPIO#15 once, and the original value is maintained even when the input is released.
I want GPIO#15 to go Low when the input is released.
Any solution?
Share this post
Link to post
Thanks Joe,
Result is this:
linaro@linaro-alip:~$ gpio readall
 +-----+-----+---------+------+---+--Tinker--+---+------+---------+-----+-----+
 | CPU | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | CPU |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |  73 |   8 | GPIO2B1 |   IN | 1 |  3 || 4  |   |      | 5v      |     |     |
 |  74 |   9 | GPIO2B2 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   8 |   7 | GPIO0B0 |   IN | 0 |  7 || 8  | 1 | IN   | GPIO2C1 | 15  | 81  |
 |     |     |      0v |      |   |  9 || 10 | 1 | IN   | GPIO2C0 | 16  | 80  |
 |  83 |   0 | GPIO2C3 |   IN | 1 | 11 || 12 | 0 | IN   | GPIO3D0 | 1   | 120 |
 |  85 |   2 | GPIO2C5 |   IN | 0 | 13 || 14 |   |      | 0v      |     |     |
 |  84 |   3 | GPIO2C4 |   IN | 1 | 15 || 16 | 0 | IN   | GPIO2C6 | 4   | 86  |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO2C7 | 5   | 87  |
 |  40 |  12 | GPIO1B0 |   IN | 1 | 19 || 20 |   |      | 0v      |     |     |
 |  39 |  13 | GPIO1A7 |   IN | 1 | 21 || 22 | 0 | IN   | GPIO3D4 | 6   | 124 |
 |  41 |  14 | GPIO1B1 |   IN | 1 | 23 || 24 | 1 | IN   | GPIO1B2 | 10  | 42  |
 |     |     |      0v |      |   | 25 || 26 | 0 | IN   | GPIO0A6 | 11  | 6   |
 |  71 |  30 | GPIO2A7 |   IN | 1 | 27 || 28 | 1 | IN   | GPIO2B0 | 31  | 72  |
 | 126 |  21 | GPIO3D6 |   IN | 0 | 29 || 30 |   |      | 0v      |     |     |
 | 125 |  22 | GPIO3D5 |   IN | 0 | 31 || 32 | 0 | IN   | GPIO4C2 | 26  | 146 |
 | 150 |  23 | GPIO4C6 |  OUT | 1 | 33 || 34 |   |      | 0v      |     |     |
 | 121 |  24 | GPIO3D1 |   IN | 0 | 35 || 36 | 1 | IN   | GPIO2C2 | 27  | 82  |
 | 149 |  25 | GPIO4C5 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO3D3 | 28  | 123 |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO3D7 | 29  | 127 |
Even though there is no input to GPIO#15, it is high.
Share this post
Link to post
I found and wrote into /boot/config.txt;
gpio=84=ip,pd
but this doesn't make any sense.
I did notice one odd thing.
Looking directly at GPIO#15 (pin No.84), the value seems to be changing correctly with no input (but I had to change active_low to 1 as follows).
# echo 84 > /sys/class/gpio/export
# cd /sys/class/gpio/export/gpio84
# cat active_low
0
# echo 1 > active_low
# cat value
0
Also,
# cat/sys/kernel/debug/pinctrl/pinctrl/pinmux-pins
pin 84 (gpio2-20): (MUX UNCLAIMED) gpio2:84
It doesn't look like the multiplexer is selecting a GPIO.
Does wiringPi correctly select Func_1(gpio2_c[4])?
Edited by Fu-.
Share this post
Link to post
gpio=84=ip,pd
# cat active_low
0
# cat value
0
Also,
Hmm...
The value remains latched even when the input of GPIO#84 is manipulated directly (once Low->High and then High input is turned off, the value remains High).
Share this post
Link to post
On 6/17/2021 at 5:16 PM, Joe said:
Hi Fu,
[Image Version]
[Example]
[Step]
2.  sudo make isr
3.  sudo ./isr
4.  Output:
How to do this?
Share this post
Link to post
After further investigation, it seems that GPIO#15 (gpio2c_4) is correctly set to pull-down GPIO mode.
read GRF_GPIO2C_IOMUX:
io -4 -r 0xff77e008
ff77e008: 00000000
bits 9:8 is 2'b00 = GPIO
read GRF_GPIO2C_P:
io -4 -r 0xff77e048
ff77e048: 0000fd3f
bits 9:8 is 2'b01 = weak 0(pull down)
Nevertheless, once the input changes from Low->High and the High input is nothing, GPIO#15 continues to stay High.
Is there something else I should be setting?
From these conditions, it does not seem to be a problem with wiringPi.
Is this not a problem with RK3399, but a specification of Tinker2S?
Edited by Fu-.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
