Tinker Board 2 Posted September 2, 2021 If there's any failure encountered during the OS writing process on Tinker Board S, you can either recover using the UMS from eMMC if eMMC’s U-Boot still workable, or re-writing the OS using UMS from a microSD card if there's a problem booting from eMMC's U-bbot. Below are the procedures: UMS from eMMC eMMC’s U-Boot still workable and had built-in the UMS function. Can use the UMS mode to re-flash The eMMC need have a workable U-Boot. Connect Tinker Board S to PC via Micro-USB. It would booting & create the partitions like a USB drive. (please remove other extend device on board) Just flash as the old way. UMS from SD card eMMC’s U-Boot is broken to booting or not built-in the UMS function (e.g. 3rd party custom image). Can trigger the UMS mode from SD card Flash the Image (with UMS’s U-Boot) to SD card. Install the SD card to Tinker Board S. Plug the Jumper on the Maskrom mode. (force to boot from SD, jump out the eMMC) Connect Tinker Board S to PC via Micro-USB, then there will become as USB mass storage on your computer Then you can flash the eMMC as usual, the old way. (e.g.: win32DiskImager, etcher and so on) After finish the image flash, unplug the USB from PC and then put the jumper at the "no function" mode. Plug in the AC adaptor to boot the device It would boot successfully & create the partitions like a USB drive. (please remove other extend device on board) Without UMS mode Recovery from SD’s image system & without the PC mode (ready on TinkerOS v2.0.4 or above) Plug the Jumper on the Maskrom mode. (force to boot from SD, jump out the eMMC) Flash the Image (any can bootable) to SD card. Plug the SD card to Tinker Board S. Booting the Tinker Board S. It would booting to the RootFS. Then dd or other ways to flash new image file to eMMC(mmcblk1). * Further details could be find on Setup - Tinker Board Wiki (tinkerboarding.co.uk). 1 Share this post Link to post Share on other sites
Dima.Sh 0 Posted December 8, 2021 On 9/2/2021 at 2:33 PM, Tinker Board said: Without UMS mode Recovery from SD’s image system & without the PC mode (ready on TinkerOS v2.0.4 or above) Plug the Jumper on the Maskrom mode. (force to boot from SD, jump out the eMMC) Flash the Image (any can bootable) to SD card. Plug the SD card to Tinker Board S. Booting the Tinker Board S. It would booting to the RootFS. Then dd or other ways to flash new image file to eMMC(mmcblk1). * Further details could be find on Setup - Tinker Board Wiki (tinkerboarding.co.uk). Hi, I am trying to boot into recovery mode like explained on the above... but nothing happens. I made sure that the jumper is in Makrom mode, but it just boots back into the normal ROM on the sdcard. Im using the TinkerBoard R2.0 with latest android 11 image installed. Share this post Link to post Share on other sites
