Digital Larry 0 Posted March 19, 2022 I have a Tinkerboard running Debian 9 Stretch and finally got it working OK. I use it as a test platform for my company's Linux security software. Now trying Tinkerboard S with the following: Quote linaro@linaro-alip:~$ cat /etc/os-release PRETTY_NAME="Debian GNU/Linux 10 (buster)" NAME="Debian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" linaro@linaro-alip:~$ Quote linaro@linaro-alip:~$ uname -a Linux linaro-alip 4.4.194 #52 SMP Tue Oct 26 08:35:58 UTC 2021 armv7l GNU/Linux linaro@linaro-alip:~$ I've installed XRDP but only get a black screen when connecting. I had the same issue on the Tinkerboard and was able to resolve it following instructions at this page: https://ubuntututorials.org/ubuntu-20-04-xrdp-black-screen/ However, I'm still not getting anything from RDP on this device. I used this article to increase the number of "inotify watches" to 16384 since I kept getting errors related to that. https://unix.stackexchange.com/questions/13751/kernel-inotify-watch-limit-reached I'm also trying to run tightvnc server but keep getting font errors: Quote linaro@linaro-alip:~$ tightvncserver :1 Couldn't start Xtightvnc; trying default font path. Please set correct fontPath in the tightvncserver script. Couldn't start Xtightvnc process. 19/03/22 16:09:19 Xvnc version TightVNC-1.3.9 19/03/22 16:09:19 Copyright (C) 2000-2007 TightVNC Group 19/03/22 16:09:19 Copyright (C) 1999 AT&T Laboratories Cambridge 19/03/22 16:09:19 All Rights Reserved. 19/03/22 16:09:19 See http://www.tightvnc.com/ for information on TightVNC 19/03/22 16:09:19 Desktop name 'X' (linaro-alip:1) 19/03/22 16:09:19 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t 19/03/22 16:09:19 Listening for VNC connections on TCP port 5901 Font directory '/usr/share/fonts/X11/misc/' not found - ignoring Font directory '/usr/share/fonts/X11/Type1/' not found - ignoring Fatal server error: could not open default font 'fixed' 19/03/22 16:09:20 Xvnc version TightVNC-1.3.9 19/03/22 16:09:20 Copyright (C) 2000-2007 TightVNC Group 19/03/22 16:09:20 Copyright (C) 1999 AT&T Laboratories Cambridge 19/03/22 16:09:20 All Rights Reserved. 19/03/22 16:09:20 See http://www.tightvnc.com/ for information on TightVNC 19/03/22 16:09:20 Desktop name 'X' (linaro-alip:1) 19/03/22 16:09:20 Protocol versions supported: 3.3, 3.7, 3.8, 3.7t, 3.8t 19/03/22 16:09:20 Listening for VNC connections on TCP port 5901 Font directory '/usr/share/fonts/X11/misc/' not found - ignoring Font directory '/usr/share/fonts/X11/Speedo/' not found - ignoring Font directory '/usr/share/fonts/X11/Type1/' not found - ignoring Fatal server error: could not open default font 'fixed' linaro@linaro-alip:~$ Share this post Link to post Share on other sites
Digital Larry 0 Posted March 19, 2022 Also, can't get wifi running. Quote cat /etc/wpa_supplicant/wpa_supplicant.conf country=US ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1 network={ ssid="Mountain-Charlie" scan_ssid=1 psk="my password" key_mgmt=WPA-PSK } Quote linaro@linaro-alip:~$ sudo ifconfig wlan0 wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether d0:c5:d3:5a:69:c3 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 linaro@linaro-alip:~$ Share this post Link to post Share on other sites
Digital Larry 0 Posted March 19, 2022 I got tightvncserver running after: Quote sudo apt install xfonts-base Logging in using RealVNC Viewer I was able to get Wi-Fi connected. So now I don't care so much about RDP, but if anyone has a suggestion I'd like to hear it. Share this post Link to post Share on other sites
