Jump to content
Jay
sojourner
Recommended Posts
I just bought a Tinkerboard 2s and the wifi and bluetooth is not working.
1  Is the hardware bad or does the tinkerboard OS 2s newest installation need to be fixed?
2  Will an older version work?
3   I don't know if it is that software drivers need an update.  I don't want to send it back and buy another one just to find out that this one has no hard ware problem.
4  Has anyone get the bluetooth working in the TB2s?
I searched the forum and found nothing about bluetooth and wifi.
I installed this one and tried the newest android.  No bluetooth and wifi.
Tinker Board 2 Debian 10 V2.0.4      2022/01/25    1.47 GBytes
Share this post
Link to post
Share on other sites
Hey Jay,
Did you install to the emmc or a sd flash drive? (is the emmc in parked mode?)
Have you tried re-flashing/re-installing?  ?
I had a similar problem that were related to build/compile errors at install.
Re-flashing, installing then re-configuring fixed it for me. ?
Edited by BrokenStorie
Share this post
Link to post
I installed to the emmc.  What is parked mode?
I will flash to an ssd and see if the bluetooth works.
So, you're bluetooth is working on a tinkerboard 2s with the tinkerboard 2 debian 10 os?
Edited by Jay
Share this post
Link to post
I tried android os and no wireless network seen.  It's not seeing the router.  And no bluetooth connection to devices.
I will return it.
They sent me a new tinkerboard 2s and it's the same no wireless and bluetooth.
Can you help me get it configured?
Edited by Jay
Share this post
Link to post
I get this a Sap driver failure.  Anyway to fix it?
@linaro:-S  sudo systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
   Active: active (running) since Thu 2019-02-14 02:12:01 PST; 3 years 5 months
     Docs: man:bluetoothd(8)
 Main PID: 540 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4591)
   Memory: 2.3M
   CGroup: /system.slice/bluetooth.service
           └─540 /usr/lib/bluetooth/bluetoothd
Feb 14 02:12:01 linaro-alip bluetoothd[540]: Bluetooth daemon 5.50
Feb 14 02:12:01 linaro-alip bluetoothd[540]: Starting SDP server
Feb 14 02:12:01 linaro-alip bluetoothd[540]: Bluetooth management interface 1.10
   Feb 14 02:12:01 linaro-alip bluetoothd[540]: Sap driver initialization failed.
   Feb 14 02:12:01 linaro-alip bluetoothd[540]: sap-server: Operation not permitted
Feb 14 02:12:07 linaro-alip bluetoothd[540]: Endpoint registered: sender=:1.39 p
Share this post
Link to post
I found this and was able to disable the Sap Driver.  But, bluetooth still not working.
SAP stands for SIM Access Profile, so you have to disable it:
    Open /etc/systemd/system/bluetooth.target.wants/bluetooth.service
Change:
    ExecStart=/usr/lib/bluetooth/bluetoothd
To
    ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
Reload the systemd:
    $ sudo systemctl daemon-reload
Restart the bluetooth:
    $ sudo service bluetooth restart
Get the bluetooth status:
    $ sudo service bluetooth status
linaro@linaro-alip:~$ sudo systemctl status bluetooth.service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2022-07-16 08:05:10 PDT; 2min 11s ago
 Main PID: 520 (bluetoothd)
   Status: "Running"
   Memory: 2.1M
           └─520 /usr/lib/bluetooth/bluetoothd --noplugin=sap
Jul 16 08:05:10 linaro-alip bluetoothd[520]: Bluetooth daemon 5.50
Jul 16 08:05:10 linaro-alip bluetoothd[520]: Starting SDP server
Jul 16 08:05:10 linaro-alip bluetoothd[520]: Excluding (cli) sap
Jul 16 08:05:10 linaro-alip bluetoothd[520]: Bluetooth management interface 1.10 initialized
Jul 16 08:05:16 linaro-alip bluetoothd[520]: Endpoint registered: sender=:1.39 path=/MediaEnd
lines 1-17/17 (END)
Share this post
Link to post
I found out what was the problem.  I finally connected with bluetooth.  However, the bluetooth device has to be within 1 foot of the Tinkerboard 2s.
One foot?
It looses connection if further away.  So this TB2s has a one foot range for bluetooth.
I assume the wireless has to be one foot from the router to connect wirelessly.
How can you fix something like this?
The wireless would need a wireless extender right next to the TB2s.
Any suggestions for bluetooth?  Does the bluetooth need the antennas connected?  I think that is only for wireless internet.
Edited by Jay
Share this post
Link to post
Yes, the antennas must be snapped on the wifi/bluetooth circuit board that is screwed down on the TBs2 board.  Wifi and bluetooth is working.
Edited by Jay
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
