Jump to content
wahaha
wlan device not found
Recommended Posts
I reinstalled debian onto the tinkeboard 2s, and added the below to /etc/network/interfaces
# Add the following (for ethernet):
auto lo eth0
allow-hotplug eth0
iface lo inet loopback
iface eth0 inet dhcp
However, when I did:
ifconfig
It produced the below result:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.50.146  netmask 255.255.255.0  broadcast 192.168.50.255
        inet6 fe80::7e10:c9ff:feed:f504  prefixlen 64  scopeid 0x20<link>
        ether 7c:10:c9:ed:f5:04  txqueuelen 1000  (Ethernet)
        RX packets 1536  bytes 159578 (159.5 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 908  bytes 199763 (199.7 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 35
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 90  bytes 6869 (6.8 KB)
        TX packets 90  bytes 6869 (6.8 KB)
As you can see, wlan / wlp1s0 is not found in there. As such, I am unable to connect via wifi / bluetooth.
Is there a driver / kernel / firmware that I can use to update the drivers so that the wifi and bluetooth modules are detectable?
Share this post
Link to post
Share on other sites
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
