Jump to content
Recommended Posts
Hello.
Since the OS can no longer boot, I have to boot recovery as described in the readme.
Write the recovery.img file to uSD,
    (ON: Switch 1 / Switch 3 / Switch 4; OFF: Switch 2)
I set it to.
But it doesn't boot from uSD.
Please let us know how to deal with it.
Share this post
Link to post
Share on other sites
Hi k-soeta,
There are some steps to solve this problem.
1. Please flash the sdcard_arm64.img file to your microSD card with a program such as balenaEtcher.
2. Change the boot mode switches to boot from SD card. (ON: Switch 1/Switch 3/Switch 4; OFF: Switch 2)
3. Insert the SD card and then power on the board and the board should auto boot.
4. Please launch weston-terminal on the board and run sudo reboot-bootloader to reboot the board into the fastboot mode.
5. Run the flash.cmd script for Windows or flash.sh for Linux in this directory.
Thanks and best regards.
Share this post
Link to post
On 4/19/2021 at 11:47 AM, Frank_Chiang said:
Hi k-soeta,
I have flashed Eagle-V3.0.7 to eEPROM. In this mode the OS constantly crashes completely. So I flashed sdcard_arm.img to SDcard and booted the board. Now I am struggling at step #4 of the above instruction, since sudo is not accepted. The terminal prompt shows:
mendel@jumping-calf:/$ sudo reboot-bootloader
>>> /etc/sudoers: syntax error near line 28 <<<
sudo: parse error in /etc/sudoers near line 28
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
What can I do to overcome this problem? Maybe I could help myself if only I had the password, which I could not find anywhere...
Best
Thomas
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
