AngeloC 0 Posted April 22, 2021 Hello, I try to build AOSP from sources ( lxc container ubuntu 20.04 ) . ============================================ PLATFORM_VERSION_CODENAME=REL PLATFORM_VERSION=10 TARGET_PRODUCT=WW_Tinker_Board_2 TARGET_BUILD_VARIANT=user TARGET_BUILD_TYPE=release TARGET_ARCH=arm64 TARGET_ARCH_VARIANT=armv8-a TARGET_CPU_VARIANT=cortex-a53 TARGET_2ND_ARCH=arm TARGET_2ND_ARCH_VARIANT=armv7-a-neon TARGET_2ND_CPU_VARIANT=cortex-a15 HOST_ARCH=x86_64 HOST_2ND_ARCH=x86 HOST_OS=linux HOST_OS_EXTRA=Linux-5.11.11-200.fc33.x86_64-x86_64-Ubuntu-20.04.2-LTS HOST_CROSS_OS=windows HOST_CROSS_ARCH=x86 HOST_CROSS_2ND_ARCH=x86_64 HOST_BUILD_TYPE=release BUILD_ID=QD4A.200805.003 OUT_DIR=out I use the following commands: ./build.sh -U -K -A -v user -n R100V00 -V tinker2 -J20 ./build.sh -p All work fine , no errrors found. Also android build m command work fine. when i try to do : ./build.sh -r have this error : package resoure.img with charger images Pack ./tools/images/ & ../kernel/resource.img to resource.img ... Unpacking old image(../kernel/resource.img): rk-kernel.dtb battery_1.bmp battery_2.bmp battery_3.bmp battery_4.bmp battery_5.bmp battery_fail.bmp logo.bmp logo_kernel.bmp battery_0.bmp tinkerboard.bmp 11 Pack to resource.img successed! Packed resources: rk-kernel.dtb battery_1.bmp battery_2.bmp battery_3.bmp battery_4.bmp battery_5.bmp battery_fail.bmp logo.bmp logo_kernel.bmp battery_0.bmp tinkerboard.bmp 11 resource.img is packed ready /aosp/rock mv: cannot stat '/aosp/rock/IMAGE/Tinker_Board_2-Android10-eng-ubuntu-20210422.0759/IMAGES/WW_Tinker_Board_2-raw.img': No such file or directory adding: Tinker_Board_2-Android10-eng-ubuntu-20210422.0759/ (stored 0%) /aosp/rock I have probably forgotten a build step ..... How i can create WW_Tinker_Board_2-raw.img? all android images are present : ls -al out/target/product/rk3399_Android10/*.img -rw-rw-r--. 1 ubuntu ubuntu 27359232 Apr 22 07:55 out/target/product/rk3399_Android10/boot-debug.img -rw-rw-r--. 1 ubuntu ubuntu 27111424 Apr 22 07:56 out/target/product/rk3399_Android10/boot.img -rw-rw-r--. 1 ubuntu ubuntu 155796 Apr 22 07:55 out/target/product/rk3399_Android10/cache.img -rw-rw-r--. 1 ubuntu ubuntu 115479 Apr 22 07:55 out/target/product/rk3399_Android10/dtb.img -rw-rw-r--. 1 ubuntu ubuntu 1048616 Apr 22 07:56 out/target/product/rk3399_Android10/odm.img -rw-rw-r--. 1 ubuntu ubuntu 289529956 Apr 22 07:55 out/target/product/rk3399_Android10/product.img -rw-rw-r--. 1 ubuntu ubuntu 919091 Apr 22 07:55 out/target/product/rk3399_Android10/ramdisk-debug.img -rw-rw-r--. 1 ubuntu ubuntu 787440 Apr 22 07:55 out/target/product/rk3399_Android10/ramdisk.img -rw-rw-r--. 1 ubuntu ubuntu 24000917 Apr 22 07:56 out/target/product/rk3399_Android10/ramdisk-recovery.img -rw-rw-r--. 1 ubuntu ubuntu 623 Apr 22 07:55 out/target/product/rk3399_Android10/rebuild-dtbo.img -rw-rw-r--. 1 ubuntu ubuntu 50327552 Apr 22 07:56 out/target/product/rk3399_Android10/recovery.img -rw-r--r--. 1 ubuntu ubuntu 4592 Apr 22 07:55 out/target/product/rk3399_Android10/super_empty.img -rw-r--r--. 1 ubuntu ubuntu 1405199320 Apr 22 07:56 out/target/product/rk3399_Android10/super.img -rw-rw-r--. 1 ubuntu ubuntu 870412436 Apr 22 07:56 out/target/product/rk3399_Android10/system.img -rw-rw-r--. 1 ubuntu ubuntu 251506764 Apr 22 07:56 out/target/product/rk3399_Android10/vendor.img and the build.sh script have copied in the IMAGE path all : tree IMAGE IMAGE └── Tinker_Board_2-Android10-eng-ubuntu-20210422.0759 ├── build_cmd_info.txt ├── build.sh ├── IMAGES │ ├── boot.img │ ├── config.cfg │ ├── dtbo.img │ ├── idbloader.img │ ├── kernel.img │ ├── MiniLoaderAll.bin │ ├── misc.img │ ├── odm.img │ ├── parameter.txt │ ├── pcba_small_misc.img │ ├── pcba_whole_misc.img │ ├── recovery.img │ ├── resource.img │ ├── super.img │ ├── system.img │ ├── trust.img │ ├── uboot.img │ ├── vbmeta.img │ └── vendor.img ├── manifest_Tinker_Board_2-Android10-eng-ubuntu-20210422.0759.xml ├── PATCHES │ └── kernel │ └── vmlinux ├── Tinker_Board_2-Android10-eng-ubuntu-20210422.0759.zip └── Tinker_Board_2-Android10-eng-ubuntu-20210422.0759.zip.sha256sum Thanks in advance Share this post Link to post Share on other sites
AngeloC 0 Posted April 22, 2021 first, build.sh has an error: replace with this code if [ "$PACK_RELEASE" = true ] ; then set -x mkdir -p $STUB_PATH/$RELEASE_NAME cp $IMAGE_PATH/WW_Tinker_Board_2-raw.img $STUB_PATH/$RELEASE_NAME/Tinker_Board_2-Android10-V"$BUILD_NUMBER".img second for obtain WW_Tinker_Board_2-raw.img i have to do: ./build.sh -UKA ./mkimage.sh (ok I can change build.sh more...) ./build.sh -u (update name to create blob image is incongruent ) ./build.sh -p ./build.sh -r ( with previous change on build.sh ) greetings Share this post Link to post Share on other sites
tooz 56 Posted April 26, 2021 hello @AngeloC How i can create WW_Tinker_Board_2-raw.img? >to generate WW_Tinker_Board_2-raw.img, please add the -u parameter to build.sh command. for example: ./build.sh -U -K -A -v user -n R100V00 -V tinker2 -J20 -u Share this post Link to post Share on other sites
