Brian Van Den Beuken 0 Posted May 3, 2021 (edited) got my TB2 today, and pleased to say it works pretty much out of the box. But I do have one small issue, my project needs me to get access to the mouse scroll wheel, directly, and normally I do this by putting the mouse into ImPS/2 mode using this code... however it gives me the the cannot switch error... Is there any known reason for this? static const size_t mousedev_seq_len = 6; static const unsigned char mousedev_imps_seq[] = { 0xf3, 200, 0xf3, 100, 0xf3, 80 }; unsigned char buffer[4]; ssize_t len; const char* devpath = "/dev/input/mice"; int wasleft, wasmiddle, wasright; devfd = open(devpath, O_RDWR | O_NOCTTY); /* Switch the mouse to ImPS/2 protocol. */ if (write(devfd, mousedev_imps_seq, mousedev_seq_len) != (ssize_t)mousedev_seq_len) { fprintf(stderr, "Cannot switch to ImPS/2 protocol.\n"); close(devfd); return (void*)&devfd;; // this is rubbish to give a retun value } if (read(devfd, buffer, sizeof buffer) != 1 || buffer[0] != 0xFA) { fprintf(stderr, "Failed to switch to ImPS/2 protocol.\n"); close(devfd); return (void*)&devfd; } Edited May 3, 2021 by Brian Van Den Beuken typos Share this post Link to post Share on other sites
TzuWen_Chang 0 Posted May 6, 2021 Hi, Please check your devpath. You can use "dmesg" or "udevadm monitor" command to get more information. root@linaro-alip:/dev/input/by-id# udevadm monitor monitor will print the received events for: UDEV - the event which udev sends out after rule processing KERNEL - the kernel uevent [ 458.189823] usb 5-1.3: new low-speed USB device number 4 using xhci-hcd [ 458.298912] usb 5-1.3: New USB device found, idVendor=0461, idProduct=4e84 [ 458.305868] usb 5-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 458.313467] usb 5-1.3: Product: USB Optical Mouse [ 458.318335] usb 5-1.3: Manufacturer: PixArt [ 458.324909] usb 5-1.3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes KERNEL[458.005759] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3 (usb) KERNEL[458.047247] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0 (usb) KERNEL[458.054557] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002 (hid) [ 458.383211] input: PixArt USB Optical Mouse as /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/input/input5 KERNEL[458.063876] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/input/input5 (input) KERNEL[458.090385] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/input/input5/event3 (input) [ 458.453946] hid-generic 0003:0461:4E84.0002: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-xhci-hcd.11.auto-1.3/input0 KERNEL[458.134852] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/hidraw/hidraw0 (hidraw) UDEV [458.165723] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3 (usb) UDEV [458.190489] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0 (usb) UDEV [458.202123] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002 (hid) UDEV [458.215344] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/hidraw/hidraw0 (hidraw) UDEV [458.223512] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/input/input5 (input) UDEV [458.298266] add /devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb5/5-1/5-1.3/5-1.3:1.0/0003:0461:4E84.0002/input/input5/event3 (input) root@linaro-alip:/dev/input# ls by-id by-path event0 event1 event2 event3 Share this post Link to post Share on other sites
Brian Van Den Beuken 0 Posted May 20, 2021 Hi, Im not sure what your asking me to check with that command, my dev path is correct isnt it? Its listed there const char* devpath = "/dev/input/mice"; and the mice file is there in place and I open the mice file ok, it just refuses to switch mode? Share this post Link to post Share on other sites
Brian Van Den Beuken 0 Posted May 20, 2021 ok I managed to fix it, it was an access permission issue, the mice file was not allowing access so I had to use sudo chod a+r+w to make it usable. I know this isn't something linux users like to do, is there an elegant way to allow access to a file in C++? Share this post Link to post Share on other sites
Brian Van Den Beuken 0 Posted May 23, 2021 oops, I feel a bit silly, while my basic fix is correct I was actually doing in on a different machine connected to my kvm.. which was using ubuntu, sorry ? (I thought it was the TB2 it was in fact a Jetson) It seems Debian doesn't have /dev/input/mice and instead I need to check which event is controlling the mouse.... sigh. I kinda hate these small variations ? But you have put me on the right track, I wasn't accessing the mice config file (cos there isn't one) and on machines which had it it was indeed a permissions issue, so I need to review how I access my config files for keyboard and mouse. Share this post Link to post Share on other sites
