And_Zammit 0 Posted August 13, 2021 I am planning to use tinker board for NLP applications (training of BERT models, etc) instead of GPU cards. Do you think that this would work? Furthermore, is it possible to connect multiple tinker boards together and have them work in parallel? Thanks!!! Share this post Link to post Share on other sites
tooz 56 Posted September 6, 2021 hello @And_Zammit if you're planning to train BERT models using Tinker Edge R, you will need to first convert BERT models to RKNN models(otherwise the NPU/AI accelerator will not work). here's a document for RKNN conversion https://github.com/rockchip-linux/rknn-toolkit/blob/master/doc/Rockchip_User_Guide_RKNN_Toolkit_V1.7.0_EN.pdf On 8/14/2021 at 6:36 AM, And_Zammit said: Furthermore, is it possible to connect multiple tinker boards together and have them work in parallel? since each Tinker Edge R is an individual processing unit, you'll need an app to control from the host and switch between the boards. Share this post Link to post Share on other sites
