serene 0 Posted August 18, 2021 Hi, How do I enable serial-console in 2S? I am running TinkerOS Debian 10, and there is no extlinux folder nor extlinux.conf I found /boot/config.txt and un-commented "intf:uart0=off", to no avail. Share this post Link to post Share on other sites
tooz 56 Posted August 23, 2021 hello @serene Connect Tinker Board 2S to PC with a USB serial cable On PC, open Putty and select Serial. The Serial line can be checked from Windows >Device Manager >Ports (COM & LPT). The speed is 115200 baud. Click the Open button on Putty and power the board, and some boot logs will be printed on Putty from PC Share this post Link to post Share on other sites
serene 0 Posted August 24, 2021 (edited) 18 hours ago, tooz said: Previous Page Next Page Previous Page Next Page hello @serene Connect Tinker Board 2S to PC with a USB serial cable On PC, open Putty and select Serial. The Serial line can be checked from Windows >Device Manager >Ports (COM & LPT). The speed is 115200 baud. Click the Open button on Putty and power the board, and some boot logs will be printed on Putty from PC Previous Page Next Page Previous Page Next Page I see, so that's the Debug UART. Is it possible to enable console on UART0 or UART1 at boot up? What should I put in boot kernel parameter - /boot/config.txt or /boot/cmdline.txt? In /boot/config.txt I enabled uart1 by setting "intf:uart0=on" and also "console=ttyS1,115200n8" to no avail. Or should I use "console=ttyS0" instead? I left /boot/cmdline.txt empty. Edited August 24, 2021 by serene typo Share this post Link to post Share on other sites
tooz 56 Posted September 7, 2021 hello @serene you can use overlay to enable console on UART0 or UAR1 at bootup, change the last line of overlay= in /boot/config.txt to overlay=console-uart0-overlay there's no need to edit cmdline.txt Share this post Link to post Share on other sites
daejoon 0 Posted January 17, 2022 hello to activate the uart, I change the /boot/config.txt 1. last line => overlay=console-uart0-overlay 2. intf:uart0=off => intf-uart0=on is that all? but, I can't connect the uart0. Is there anything else I need to configure? $ dmesg | grep tty [ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=987cee5e97234e00 root=/dev/mmcblk1p9 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 rootfstype=ext4 coherent_pool=1m [ 0.560088] Registered FIQ tty driver [ 1.910761] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A [ 2949.553543] ttyS0 - failed to request DMA, use interrupt mode Share this post Link to post Share on other sites
daejoon 0 Posted January 26, 2022 i solved the problem after wiring to pin 8 and 10. helped a lot Share this post Link to post Share on other sites
