serene 0 Posted September 25, 2021 Hi, I got multiple errors when trying to build the U-Boot for TinkerBoard2. I downloaded rkbin, and then execute "make.sh tinker2" linaro@linaro-alip:~/u-boot$ ./make.sh tinker2 ## make tinker2_defconfig -j12 arch/../configs/tinker2_defconfig:140:warning: override: reassigning to symbol OF_LIBFDT_OVERLAY # # configuration written to .config # ERROR: No toolchain: ../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin I then downloaded the toolchain, put it in the location mentioned on the error above, then I got these multiple errors: linaro@linaro-alip:~/u-boot$ ./make.sh tinker2 ## make tinker2_defconfig -j12 arch/../configs/tinker2_defconfig:140:warning: override: reassigning to symbol OF_LIBFDT_OVERLAY # # configuration written to .config # /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: ELF: not found /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: 2: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Syntax error: "(" unexpected /bin/sh: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error dirname: missing operand Try 'dirname --help' for more information. scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h UPD include/config.h CFG u-boot.cfg GEN include/autoconf.mk.dep /bin/sh: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error CFG spl/u-boot.cfg /bin/sh: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error make[1]: *** [scripts/Makefile.autoconf:79: u-boot.cfg] Error 1 make[1]: *** Waiting for unfinished jobs.... CFG tpl/u-boot.cfg make[1]: *** [scripts/Makefile.autoconf:50: include/autoconf.mk.dep] Error 1 /bin/sh: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error make[1]: *** [scripts/Makefile.autoconf:83: spl/u-boot.cfg] Error 1 /bin/sh: 1: /home/linaro/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc: Exec format error make[1]: *** [scripts/Makefile.autoconf:87: tpl/u-boot.cfg] Error 1 make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'. Stop. linaro@linaro-alip:~/u-boot$ Share this post Link to post Share on other sites
tooz 56 Posted September 27, 2021 hello @serene, what's the build environment? you'll need x86_64 environment in order to build gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu use the command lscpu and you will see the architecture: x86_64C Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Share this post Link to post Share on other sites
serene 0 Posted September 27, 2021 7 hours ago, tooz said: hello @serene, what's the build environment? you'll need x86_64 environment in order to build gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu use the command lscpu and you will see the architecture: x86_64C Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Thanks @tooz I thought the script compiles natively, I ran it on aarch64. I successfully built it on x86_64 (Ubuntu PC). Share this post Link to post Share on other sites
Joe 3 Posted October 19, 2021 Hi serene: Can you try the SOP? Let me know if you have any questions [Tinker2 Source Download] 1) u-boot Code => git clone https://github.com/TinkerBoard2/u-boot.git 2) GCC => wget http://releases.linaro.org/components/toolchain/binaries/6.3-2017.05/aarch64-linux-gnu/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz 3) tar -Jxvf gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz -C ~ [Tinker2 u-boot] 1) cd u-boot 2) make tinker2_defconfig 3) make CROSS_COMPILE=~/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- all --jobs=80 4) ./tools/loaderimage --pack --uboot u-boot.bin uboot.img 0x00200000 5) compile finish,copy u-boot/uboot.img to Tinker2 6) dd if=uboot.img of=/dev/mmcblk1p1 (excute in tinker2) Thank you. Joe Share this post Link to post Share on other sites
