Jump to content
serene
Kernel build error (wlan, wireless, and net modules)
Recommended Posts
I built the kernel in Debian 10, on Tinkerboard 2S.
I got these 3 errors. Do they need patches?
make[4]: *** [scripts/Makefile.build:484: drivers/net/wireless/rockchip_wlan] Error 2
make[3]: *** [scripts/Makefile.build:484: drivers/net/wireless] Error 2
make[2]: *** [scripts/Makefile.build:484: drivers/net] Error 2
make[1]: *** [Makefile:1036: drivers] Error 2
make: *** [arch/arm64/Makefile:169: kernel.img] Error 2
make: *** Deleting file 'kernel.img'
Share this post
Link to post
Share on other sites
hello @serene,
the kernel file has to be in the same directory with prebuilts. if your files are located in different directories then you may have problems because of the wrong gcc.
/TinkerBoard2$ ls
kernel prebuilts rkbin u-boot
those four are in the same directory
Share this post
Link to post
17 hours ago, tooz said:
hello @serene,
/TinkerBoard2$ ls
Hello @tooz
I re-arranged the folder to match what you described, all of those 4 folders (kernel, prebuilts, rkbin, and u-boot) are in the same folder (TinkerBoard2S), no luck, still got the same error.
Btw, which gcc version should I put in the prebuilts?
What can I try next?
Edited by serene
Add explanation
Share this post
Link to post
Hello @tooz
Never mind, I am able to compile it now after I read a post in the GitHub.
I had been trying to build the kernel natively in Tinkerboard 2S hardware, thinking it would be the same the previous generation.
When I built it in Ubuntu (cross-compile) using the same gcc used by u-boot, I can build the kernel.
Share this post
Link to post
Hi @serene
Can you try the SOP?
Let me know if you have any questions
[Tinker2 Source Download]
1)  Kernel Code => git clone https://github.com/TinkerBoard2/kernel.git
2)  GCC            =>  wget http://releases.linaro.org/components/toolchain/binaries/6.3-2017.05/aarch64-linux-gnu/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz
3)  tar -Jxvf gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu.tar.xz -C ~
[Tinker2 kernel]
1) cd kernel
2)  make ARCH=arm64 tinker2_defconfig Thank you.CROSS_COMPILE=~/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- -j32
3)  make ARCH=arm64 rk3399-tinker_board_2.img CROSS_COMPILE=~/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- -j32
4)  compile finish,copy kernel/boot.img to tinker2
5)  dd if=boot.img of=/dev/mmcblk1p4   (excute in tinker2)
Thank you
Joe
Share this post
Link to post
On 10/18/2021 at 8:26 PM, Joe said:
Hi @serene
[Tinker2 kernel]
1) cd kernel
Thank you
Joe
Hi @Joe
Thank you for sharing the SOP.
But I already managed to compile it as I mentioned in my previous post. My interaction with amiotk in github made me realize that I need to cross compile.
Here is the link of my interaction:
https://github.com/TinkerBoard2/kernel/issues/8
Share this post
Link to post
I tried the Tinker OS 2.0 kernel compile. But, I faced the following error.
Does anyone know how to fix this problem?
Quote
linaro@linaro-alip:~/kernel-linux4.4-rk3399-debian10$ make ARCH=arm64 rk3399-tinker_board_2.img CROSS_COMPILE=aarch64-linux-gnu- -j32
scripts/kconfig/conf  --silentoldconfig Kconfig
  HOSTCC  scripts/basic/bin2c
  CHK     include/config/kernel.release
  WRAP    arch/arm64/include/generated/asm/bug.h
<snip>
  HOSTCC  scripts/dtc/dtc-parser.tab.o
scripts/extract-cert.c:21:10: fatal error: openssl/bio.h: No such file or directory
 #include <openssl/bio.h>
compilation terminated.
make[1]: *** [scripts/Makefile.host:91: scripts/extract-cert] Error 1
make[1]: *** Waiting for unfinished jobs....
  CHK     scripts/mod/devicetable-offsets.h
  UPD     scripts/mod/devicetable-offsets.h
<snip>
So, I tried updating the libssl-dev, but libssl1.1 and libssl-dev have mismatched the version. How can I fix this?
Quote
linaro@linaro-alip:~/kernel-linux4.4-rk3399-debian10$ sudo apt update
Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:1 http://cdn-fastly.deb.debian.org/debian buster InRelease [122 kB]
Get:3 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:4 http://security.debian.org buster/updates/main Sources [205 kB]
<snip>
Get:20 http://cdn-fastly.deb.debian.org/debian buster-updates/main Translation-en [13.9 kB]
Fetched 22.9 MB in 19min 43s (19.3 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
linaro@linaro-alip:~/kernel-linux4.4-rk3399-debian10$ sudo apt install libssl-dev
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 libssl-dev : Depends: libssl1.1 (= 1.1.1d-0+deb10u7) but 1.1.1d-0+deb10u4 is to be installed
E: Unable to correct problems, you have held broken packages.
Best regards,
Yoshio Kashiwagi
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
