stargate77 0 Posted January 4, 2022 Hello i have flashed image with tinker OS Debian to USB-HDD. how can i change the boot loader to boot from external USB Hardisk ? there is no /boot/extlinux.conf on tinkerboard 2 S thanks in advance Share this post Link to post Share on other sites
yaborad 0 Posted January 15, 2022 Hi I have just figured it out today (with very sad speed though of 36mb/s from a nice SSD. not enough juice on the bus is what i'm thinking.) Following a post https://tinkerboarding.co.uk/forum/archive/index.php/thread-1040.html and a youtube from that post https://www.youtube.com/watch?v=XLlMWfDfpzw The version of TinkerOS you need is the 2.0.11 and not the latest. that still has the 2 partitions. In that you will need to delete `console=<something>` and add the `root=/dev/sda1` or whatever device you are using just instead before the `rw` Good luck and do report the speeds you got to. Share this post Link to post Share on other sites
asdas 127816 0 Posted May 2, 2023 Hello, I've been researching this for a while and still haven't come to a conclusion. I need some help. I am using asus tinkerboard 2s and now there is TinkerOS 2.0.14 in emmc. 1 hdd with a sata to usb cable and an SSD with a sata to type-c cable are connected to the device. My aim is to boot tinkerboard 2s over ssd with proxmox installed, but I could not do it. Is there no built-in BIOS or BOOT menu in the device? If so, how can I enter? There is very little information on the internet about this. Share this post Link to post Share on other sites
asdas 127816 0 Posted May 4, 2023 On 5/2/2023 at 7:43 PM, asdas 127816 said: Hello, I've been researching this for a while and still haven't come to a conclusion. I need some help. I am using asus tinkerboard 2s and now there is TinkerOS 2.0.14 in emmc. 1 hdd with a sata to usb cable and an SSD with a sata to type-c cable are connected to the device. My aim is to boot tinkerboard 2s over ssd with proxmox installed, but I could not do it. Is there no built-in BIOS or BOOT menu in the device? If so, how can I enter? There is very little information on the internet about this. @tooz Share this post Link to post Share on other sites
tooz 52 Posted May 5, 2023 the bootflow of tinker board 2s is different from tinker board and editingi /extlinux.conf will not work on tinker board 2s Share this post Link to post Share on other sites
asdas 127816 0 Posted May 5, 2023 9 minutes ago, tooz said: the bootflow of tinker board 2s is different from tinker board and editingi /extlinux.conf will not work on tinker board 2s There was no such file in my boot folder anyway. So what should I do to boot from SSD? Please guide. Share this post Link to post Share on other sites
asdas 127816 0 Posted May 9, 2023 Does anyone know anything about the subject ? Share this post Link to post Share on other sites
