tobe2be 0 Posted January 10, 2022 (edited) Hello everybody, I am still facing the issue, that the OS crashes once I have started sudo apt update or sudo apt-get update. This is the terminal prompt: mendel@zippy-ibis:~$ sudo apt-get update Get:1 file:/var/cache/mdt/packages ./ InRelease Ign:1 file:/var/cache/mdt/packages ./ InRelease Get:2 file:/opt/aiy/packages ./ InRelease Ign:2 file:/opt/aiy/packages ./ InRelease Get:3 file:/var/cache/mdt/packages ./ Release Ign:3 file:/var/cache/mdt/packages ./ Release Get:4 file:/opt/aiy/packages ./ Release Ign:4 file:/opt/aiy/packages ./ Release Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages Ign:7 file:/opt/aiy/packages ./ Packages Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en Get:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en Ign:6 file:/var/cache/mdt/packages ./ Translation-en Get:7 file:/opt/aiy/packages ./ Packages [110 kB] Get:8 file:/opt/aiy/packages ./ Translation-en Ign:8 file:/opt/aiy/packages ./ Translation-en 0% [Connecting to mendel-linux.org] [Connecting to debian.map.fastly.net (2a04:4e42:62::644)] As far as I could find out, this issue is either related to IPv6 or to package sources fastly needs. Has anyone faced the same problem and knows how to overcome this behaviour? Thank you in advance. Best regards Thomas Edited January 10, 2022 by tobe2be Share this post Link to post Share on other sites
tobe2be 0 Posted January 17, 2022 OK, I've got this peculiar device running. However it continuously hangs up, Ctrl-C does not work, mouse pointer is frozen... And: no response from manufacturer. Thank you for nothing. I've bought a Coral Dev Board in the meantime, which is running fine from the very beginning and without showing any of the phenomena the Tinker Edge T delights me with Share this post Link to post Share on other sites
apineda2005 0 Posted December 15, 2022 I have the same problem.My Asus Tinker Board T hangs in the same spot when issuing an sudo apt update or sudo apt-get update. ------------------------------------------------------------------------------------------- ... Ign:8 file:/opt/aiy/packages ./ Translation-en 0% [Connecting to mendel-linux.org] [Connecting to debian.map.fastly.net (2a04:4e42:62::644)] -------------------------------------------------------------------------------------------- Is there a fix for this? Share this post Link to post Share on other sites
tooz 13 Posted December 15, 2022 hello @apineda2005/ @tobe2be, i think this is where the error comes from: N: Repository 'https://deb.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'stable' to 'oldstable' to solve this, please run: sudo apt-get --allow-releaseinfo-change update mendel@lime-bunny:~$ sudo apt-get --allow-releaseinfo-change update Get:1 file:/var/cache/mdt/packages ./ InRelease Ign:1 file:/var/cache/mdt/packages ./ InRelease Get:2 file:/opt/aiy/packages ./ InRelease Ign:2 file:/opt/aiy/packages ./ InRelease Get:3 file:/var/cache/mdt/packages ./ Release Ign:3 file:/var/cache/mdt/packages ./ Release Get:4 file:/opt/aiy/packages ./ Release Ign:4 file:/opt/aiy/packages ./ Release Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Hit:11 https://packages.cloud.google.com/apt coral-edgetpu-stable InRelease Hit:12 https://deb.debian.org/debian-security buster/updates InRelease Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Hit:13 https://mendel-linux.org/apt/unstable-bsp-enterprise unstable InRelease Hit:14 https://mendel-linux.org/apt/unstable unstable InRelease Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Ign:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages Ign:8 file:/opt/aiy/packages ./ Packages Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Get:5 file:/var/cache/mdt/packages ./ Packages Get:6 file:/var/cache/mdt/packages ./ Translation-en_US Ign:6 file:/var/cache/mdt/packages ./ Translation-en_US Get:7 file:/var/cache/mdt/packages ./ Translation-en Ign:7 file:/var/cache/mdt/packages ./ Translation-en Get:8 file:/opt/aiy/packages ./ Packages [110 kB] Get:9 file:/opt/aiy/packages ./ Translation-en Ign:9 file:/opt/aiy/packages ./ Translation-en Get:10 file:/opt/aiy/packages ./ Translation-en_US Ign:10 file:/opt/aiy/packages ./ Translation-en_US Reading package lists... Done note: Hit means apt checked the timestamps on package list, those match and there are no changes. Ign means there are no changes in the pdiff index file, it wont bother downloading it again. Get means apt checked the timestamps on package list, there were changes and will be downloaded. Share this post Link to post Share on other sites
