Eugene 0 Posted January 15, 2022 Hi! Is it possible to run usb wifi adapters (Realteck rtl8187, Ralink) on TinkerBoadr2 ? Firmfare-realtek utility installed. Adapters are successfully detected with lsusb. According to WIKI driver modules are built into the kernel. Quote Connect the device to your system. The necessary kernel module is automatically loaded for supported devices. However, they are not on the Tinker board 2. sudo find /lib/modules -name *ko' only finds rtl88*. I tried to install drivers from source, but it is for kernel 3.0 -3.2. I have not enough knowledge for it. Does ASUS plan to add drivers into the kernel? Maybe some manual for compiling/installing/inserting? Or the cross-compilation Is the only way? Thanks in advance for your replies. Share this post Link to post Share on other sites
Eugene 0 Posted January 17, 2022 Note: I not shure I did it in right way. And first time I losst even a single default module installed. Finnaly I get it working! I had to compile missing modules from TinkerBoard2 source. 1. Git clone: https://github.com/TinkerBoard2/kernel Then, as per this forum advice: 2. make clean && make distclean && make mrproper 3. make ARCH=arm64 tinker2_defconfig Then start menu: 4. sudo make ARCH=arm menuconfig Select nessesary driver rtl8187 as M (module) select additional driver depence eeprom_93cx6 as M (and I add "pps for gpio" driver for gps device) as M 5. in file "kernel\drivers\net\wireless\rockchip_wlan\rkwifi\bcmdhd\dhd_linux.c" bug n.6965 It should be like this :"strncpy(drvname, info.driver, sizeof(drvname));" 6. in file "kernel\drivers\net\wireless\rockchip_wlan\rtl8822be\hal\phydm\halrf\rtl8822b\halrf_iqk_8822b.c bug n.449 n.453 "report = ~(". (in new gcc comiler) I just removed symbol "~" Looks like working. 7. save .config file and sudo make modules 8. At this stage will be many questiions. I don't now answers, so I just press "Enter". 9. After succesful module complilation, install their sudo make modules_install 10.sudo insmod /lib/modules/4.4.194/kernel/drivers/misc/eeprom/eeprom_93cx6.ko nohwcrypt=0 sudo insmod /usr/src/linux-headers-4.4.194/drivers/net/wireless/rtl8187/rtl8187.ko nohwcrypt=0 11.sudo depmod -a 12.sudo lsmod rtl8187 61440 0 eeprom_93cx6 16384 1 rtl8187 pps_ldisc 16384 2 8822ce 3424256 0 Share this post Link to post Share on other sites
