Robin S 0 Posted April 13, 2022 Hello, I have tried to flash my Tinker Edge R by using the Flash tool (GUI) and the image from Tinker Edge R Debian 10 V2.0.5. In the GUI, I can select the image and my Tinker Edge R. I suppose my Tinker is in MASKROM mode. I have followed the steps from the Flash tool GUI manual, but everytime I get the notification that the flas has failed and that I should restart the Tinker into MASKROM mode and should try again. What goes wrong and how can I fix this? With kind regards. Share this post Link to post Share on other sites
MThompson 0 Posted April 26, 2022 I had a lot of problems figuring out how to get Debian 10 v2.0.5 running on my new Edge R. Below are the steps I followed to finally get Debian 10 v2.0.5 running: Install a previous version of Debian for the Tinker Board Edge R (ie. v1.0.4). This puts the correct bootloader and working Linux on the Edge R. Connect the Edge R to my PC via a USBC cable. Reboot the Edge R into UMS mode. From a shell, "sudo reboot ums". Use balenaEtcher to write the v2.0.5 image from my PC The flash tool may work as well, but I used balenaEtcher. I believe the primary issue is that the Debian 10 v2.0.5 image contains just the Debian file system image and doesn't include the bootloader as the other images do. For this reason, it can only be written once a proper bootloader is installed on the Edge R and booted into UMS mode. I hope this helps. Share this post Link to post Share on other sites
Goolge 0 Posted August 26, 2022 On 4/13/2022 at 9:02 PM, Robin S said: Hello, I have tried to flash my Tinker Edge R by using the Flash tool (GUI) and the image from Tinker Edge R Debian 10 V2.0.5. In the GUI, I can select the image and my Tinker Edge R. I suppose my Tinker is in MASKROM mode. I have followed the steps from the Flash tool GUI manual, but everytime I get the notification that the flas has failed and that I should restart the Tinker into MASKROM mode and should try again. What goes wrong and how can I fix this? With kind regards. I got a same issue. Can't flash devian v10. It makes me crazy. Share this post Link to post Share on other sites
jaremekgw 0 Posted January 22, 2023 Thank you @MThompson, your advice was very helpful. First I had to update v1.0.4 then after switch to UMS mode I managed to update to v2.0.5. Share this post Link to post Share on other sites
sri 0 Posted November 5, 2024 Hi I have v1.04, i am unable to update to v2.0.5. I use linux, is there any way i can flash sd card with v2.0.5 and make it boot from sdcard? Share this post Link to post Share on other sites
tooz 56 Posted November 5, 2024 hello @sri, 1. to flash tinker edge r to emmc: 2. to flash the os to sd card, the steps are similar -- download the image and use utilities such as balenaetcher to flash the image to sd card the board should be booting from sd card by default, if the card is inserted + has image flashed into Share this post Link to post Share on other sites
