Remontoir 0 Posted April 21, 2022 Using Tinker Board S R2.0 Debian 10 V3.0.11 No video acceleration. Xorg log : [ 1941.779] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/rockchip_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/rockchip_dri.so: cannot open shared object file: No such file or directory) inxi : Graphics: Device-1: display-subsystem driver: rockchip_drm v: N/A Device-2: rk3288-dw-hdmi driver: dwhdmi_rockchip v: N/A Device-3: malit764 driver: mali v: N/A Display: tty server: X.Org 1.20.4 driver: modesetting resolution: 1920x1080~60Hz OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6 Share this post Link to post Share on other sites
Remontoir 0 Posted April 21, 2022 Well, adding the same parameters to electron as the one used in /usr/lib/chromium/chromium-wrapper, I can see an improvement. GPU usage is now registering in 'tinker-power-management', but GPU usage is still around 50% for a FHD video. The error in the post above is still present. Here are the aforementioned flags : --use-gl=egl --no-sandbox --gpu-sandbox-start-early --enable-accelerated-video-decode --ignore-gpu-blacklist --ignore-gpu-blocklist AFAII, it's using some userland drivers/decoders for the mali chip ? Share this post Link to post Share on other sites
Remontoir 0 Posted April 28, 2022 So: someone said this on the now dead tinkerboarding.co.uk : Quote This error message is caused by the userspace application try to use the OpenGL API. However, Tinker Board can only support OpenGL ES but not OpenGL API. So you need to use the OpenGL-ES API instead of OpenGL. Also, the missing file should be in libgl1-mesa-dri Share this post Link to post Share on other sites
tooz 55 Posted July 6, 2022 hello @Remontoir, yes, tinkerboard/ tinkerboard s only supports opengl es-- which test are you running? perhaps we can run it our side and see what comes out. Share this post Link to post Share on other sites
Remontoir 0 Posted July 11, 2022 It's to run an electron app. I managed to make it run with some flags passed to chromium ( something like '--use-gl=egl' ). Share this post Link to post Share on other sites
