Jump to content
skuenstler
WiFi not working with BalenaOS Debian Linux
Recommended Posts
Posted (edited)
  I tried to get WiFi running using BalenaOS (image balenaOS 2.38.3+rev1) following the Balena setup manual
But WiFi is not working.
Any help on this ?
What I tried A), B) or C) see as follows...
But unfortunately, none of the trials A, B or C helped 😞
Do you have any idea on how to get the WiFi running using the balenaOS.2.38+rev1 image ????
Trial A) using the file system-connections/balena-wifi-01 in the flash-boot of the BalenaOS image
[connection]
id=balena-wifi-01
type=wifi
[wifi]
hidden=false
mode=infrastructure
ssid=MY_SSID
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=MY_PW
Trial B) As described in flash-boot's system-connections/README.ignores file, I took away the .ignores of the resin-sample File. But this seems an old way of doing things. Not sure about this.
[connection]
id=resin-sample
type=wifi
[wifi]
hidden=true
mode=infrastructure
ssid=MY_SSID
[wifi-security]
auth-alg=open
key-mgmt=wpa-psk
psk=MY_PW
[ipv4]
method=auto
[ipv6]
method=auto
Trial C) entering WiFi/PW credentials in flash-boot's device-type.json
    "slug": "asus-tinker-board-s",
    "version": 1,
    "aliases": [
    "name": "Asus Tinker Board S (EXPERIMENTAL)",
    "arch": "armv7hf",
    "state": "EXPERIMENTAL",
    "stateInstructions": {
        "postProvisioning": [
            "The device is performing a shutdown. Please wait until all LEDs are off.",
            "Remove the balenaOS installation media.",
            "Before powering up the Asus Tinker Board S, make sure that the jumper between the 5V power supply and the HDMI connector is in the parking (no function) mode, as ilustrated in this link https://tinkerboarding.co.uk/wiki/index.php/Setup",
            "Remove and re-connect power to the board."
    "instructions": [
        "Write the OS file you downloaded to your SD card. We recommend using <a href=\"http://www.etcher.io/\">Etcher</a>.",
        "Insert the freshly burnt SD card into the Asus Tinker Board S.",
        "<strong role=\"alert\">Warning!</strong> This will also completely erase internal storage media, so please make a backup first.",
        "Before powering up the Asus Tinker Board S, make sure that the jumper between the 5V power supply and the HDMI connector is in the MASKROM mode, as ilustrated in this link https://tinkerboarding.co.uk/wiki/index.php/Setup",
    "gettingStartedLink": {
        "windows": "https://docs.resin.io/asus-tinker-board-s/nodejs/getting-started/#adding-your-first-device",
        "osx": "https://docs.resin.io/asus-tinker-board-s/nodejs/getting-started/#adding-your-first-device",
        "linux": "https://docs.resin.io/asus-tinker-board-s/nodejs/getting-started/#adding-your-first-device"
    "supportsBlink": true,
    "yocto": {
        "machine": "asus-tinker-board-s",
        "image": "resin-image-flasher",
        "fstype": "resinos-img",
        "version": "yocto-sumo",
        "deployArtifact": "resin-image-flasher-asus-tinker-board-s.resinos-img",
        "compressed": true
    "options": [
            "isGroup": true,
            "name": "network",
            "message": "Network",
            "options": [
                    "message": "Network Connection",
                    "name": "network",
                    "type": "list",
                    "choices": [
                        "wifi"
                    "message": "Wifi SSID",
                    "name": "MY_WIFI",
                    "type": "text",
                    "when": {
                        "network": "wifi"
                    "message": "Wifi Passphrase",
                    "name": "MY_PW",
                    "type": "password",
                    "when": {
                        "network": "wifi"
            "isGroup": true,
            "isCollapsible": true,
            "collapsed": true,
            "name": "advanced",
            "message": "Advanced",
            "options": [
                    "message": "Check for updates every X minutes",
                    "name": "appUpdatePollInterval",
                    "type": "number",
                    "min": 10,
                    "default": 10
    "configuration": {
        "config": {
            "partition": {
                "primary": 1
            "path": "/config.json"
    "initialization": {
        "options": [
                "message": "Select a drive",
                "type": "drive",
                "name": "drive"
        "operations": [
                "command": "burn"
Edited by skuenstler
Share this post
Link to post
Share on other sites
I snapped the two antenna wires to the board and my wifi worked.  Without those connected it would not see anything.
Share this post
Link to post
I cannot make the wifi to work as a hotspot. This is using the standard Linux image setup, nothing fancy. I cannot make it work for S R2.0 and for the 2S. Antennas or not antennas. Frustrating.
Share this post
Link to post
Access point UP and this is the sequence of negotiation and them refusal (timeout?)
Sep 21 16:03:31 OEI-XXXX kernel: RTW: ============ STA [88:66:5a:11:3e:e1]  ===================
Sep 21 16:03:31 OEI-XXXX kernel: RTW: mac_id : 0
Sep 21 16:03:31 OEI-XXXX kernel: RTW: wireless_mode : 0x0b
Sep 21 16:03:31 OEI-XXXX kernel: RTW: mimo_type : 2
Sep 21 16:03:31 OEI-XXXX kernel: RTW: static smps : N
Sep 21 16:03:31 OEI-XXXX kernel: RTW: bw_mode : 20MHz, ra_bw_mode : 20MHz
Sep 21 16:03:31 OEI-XXXX kernel: RTW: rate_id : 2
Sep 21 16:03:31 OEI-XXXX kernel: RTW: rssi : -1 (%), rssi_level : 0
Sep 21 16:03:31 OEI-XXXX kernel: RTW: is_support_sgi : Y, is_vht_enable : N
Sep 21 16:03:31 OEI-XXXX kernel: RTW: disable_ra : N, disable_pt : N
Sep 21 16:03:31 OEI-XXXX kernel: RTW: is_noisy : N
Sep 21 16:03:31 OEI-XXXX kernel: RTW: txrx_state : 0
Sep 21 16:03:31 OEI-XXXX kernel: RTW: curr_tx_rate : CCK_1M (L)
Sep 21 16:03:31 OEI-XXXX kernel: RTW: curr_tx_bw : 20MHz
Sep 21 16:03:31 OEI-XXXX kernel: RTW: curr_retry_ratio : 0
Sep 21 16:03:31 OEI-XXXX kernel: RTW: ra_mask : 0x000000000fffffff
Sep 21 16:03:31 OEI-XXXX kernel: RTW: send eapol packet 1/4
Sep 21 16:03:31 OEI-XXXX kernel: RTW: set group key camid:1, addr:00:00:00:00:00:00, kid:1, type:TKIP
Sep 21 16:03:31 OEI-XXXX kernel: RTW: recv eapol packet 2/4
Sep 21 16:03:31 OEI-XXXX kernel: RTW: send eapol packet 3/4
Sep 21 16:03:31 OEI-XXXX kernel: RTW: recv eapol packet 4/4
Sep 21 16:03:31 OEI-XXXX kernel: RTW: set pairwise key camid:4, addr:88:66:5a:11:3e:e1, kid:0, type:AES
Sep 21 16:03:37 OEI-XXXX kernel: RTW: OnDisassoc(wlp1s0) reason=8, ta=88:66:5a:11:3e:e1
Sep 21 16:03:37 OEI-XXXX kernel: RTW: clear key for addr:88:66:5a:11:3e:e1, camid:4
Sep 21 16:03:38 OEI-XXXX kernel: RTW: ============ STA [88:66:5a:11:3e:e1]  ===================
Sep 21 16:03:38 OEI-XXXX kernel: RTW: mac_id : 0
Sep 21 16:03:38 OEI-XXXX kernel: RTW: wireless_mode : 0x0b
Sep 21 16:03:38 OEI-XXXX kernel: RTW: mimo_type : 2
Sep 21 16:03:38 OEI-XXXX kernel: RTW: static smps : N
Sep 21 16:03:38 OEI-XXXX kernel: RTW: bw_mode : 20MHz, ra_bw_mode : 20MHz
Sep 21 16:03:38 OEI-XXXX kernel: RTW: rate_id : 2
Sep 21 16:03:38 OEI-XXXX kernel: RTW: rssi : -1 (%), rssi_level : 0
Sep 21 16:03:38 OEI-XXXX kernel: RTW: is_support_sgi : Y, is_vht_enable : N
Sep 21 16:03:38 OEI-XXXX kernel: RTW: disable_ra : N, disable_pt : N
Sep 21 16:03:38 OEI-XXXX kernel: RTW: is_noisy : N
Sep 21 16:03:38 OEI-XXXX kernel: RTW: txrx_state : 0
Sep 21 16:03:38 OEI-XXXX kernel: RTW: curr_tx_rate : CCK_1M (L)
Sep 21 16:03:38 OEI-XXXX kernel: RTW: curr_tx_bw : 20MHz
Sep 21 16:03:38 OEI-XXXX kernel: RTW: curr_retry_ratio : 0
Sep 21 16:03:38 OEI-XXXX kernel: RTW: ra_mask : 0x000000000fffffff
Sep 21 16:03:38 OEI-XXXX kernel: RTW: send eapol packet 1/4
Sep 21 16:03:38 OEI-XXXX kernel: RTW: recv eapol packet 2/4
Sep 21 16:03:38 OEI-XXXX kernel: RTW: send eapol packet 3/4
Sep 21 16:03:38 OEI-XXXX kernel: RTW: recv eapol packet 4/4
Sep 21 16:03:38 OEI-XXXX kernel: RTW: set pairwise key camid:4, addr:88:66:5a:11:3e:e1, kid:0, type:AES
Sep 21 16:03:44 OEI-XXXX kernel: RTW: OnDeAuth(wlp1s0) reason=15, ta=88:66:5a:11:3e:e1
Sep 21 16:03:44 OEI-XXXX kernel: RTW: clear key for addr:88:66:5a:11:3e:e1, camid:4
Sep 21 16:04:00 OEI-XXXX kernel: invalid destination resolution act_w = 0, act_h = 0
Share this post
Link to post
have you login as root and see if it will work?  Log off and then as root.
I never used tinkerboard as a hot spot. I use my cellphone and tethering in the setting.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
