DSehrawat 0 Posted August 17, 2022 (edited) Hi Guys, After using Raspberry Pi for a long time, I have just started using TinkerBoard R2.0. It's very similar to RPi and I really like it. But I need your help with the following issue: Issue: How to save tinkerBoard SD Card Image to laptop as 'Img' (or some other format) file which can then be used to write more such SD cards? "Win32DiskImager" software does not even detect the SD card which successfully boots on TinkerBoard R2. It works perfectly fine with Raspberry Pi Images though. Cheers, Deepak Edited August 17, 2022 by DSehrawat Share this post Link to post Share on other sites
tooz 56 Posted August 24, 2022 hello @DSehrawat, if you have a laptop with linux environment, you can use this command: sudo dd bs=4M if=/dev/sdX of=TB.img status=progress && sync X = storage device node if you're using a windows laptop, please update it to 21H2 so the sd card would be recognizable https://docs.microsoft.com/en-us/windows/whats-new/whats-new-windows-10-version-21h2 Share this post Link to post Share on other sites
DSehrawat 0 Posted August 26, 2022 (edited) Hi, Thank you for the response. But I am running windows 11 and it does not recognize the SD card USB drive (attaching snapshot). Can you please tell us how will it work for Windows 11? Edition Windows 11 Pro Version 21H2 Installed on 16-12-2021 OS build 22000.856 Experience Windows Feature Experience Pack 1000.22000.856.0 Edited August 26, 2022 by DSehrawat Share this post Link to post Share on other sites
DSehrawat 0 Posted August 26, 2022 (edited) Also, on the Linux machine it's showing several SDA driver when I insert USB drive (with Tinker board SD card). Please have a look at the snapshot below. So, not sure which one to use as 'X' in your mentioned command: sudo dd bs=4M if=/dev/sdX of=TB.img status=progress && sync Edited August 26, 2022 by DSehrawat Share this post Link to post Share on other sites
tooz 56 Posted August 26, 2022 hello @DSehrawat, if you execute lsblk before and after the card insert, the node can be observed from the differences -- say if sda8 is missing when the card's pulled out, then chances are sda8 presents the micro sd card. Share this post Link to post Share on other sites
DSehrawat 0 Posted August 26, 2022 Hi, All the sda shown in the attachment appeared after inserting single SD card carrying tinker board image. Share this post Link to post Share on other sites
tooz 56 Posted August 26, 2022 hello @DSehrawat, then you can sudo dd bs=4M if=/dev/sda of=TB.img status=progress && sync make sure you have enough storage for the file, if not you can use an external storage just in case Share this post Link to post Share on other sites
DSehrawat 0 Posted August 26, 2022 Thanks. Will try that. But what about the windows issue? How to do that in Windows? Share this post Link to post Share on other sites
