CommandLine726 0 Posted August 25, 2022 Hi! How do you rotate the screen 180 degrees? I have an original Raspberry touchscreen installed on an Asus Tinker Board S running Tinker OS and the image is upside down, I would like to rotate it 180 degrees, how do I do that? Thanks Share this post Link to post Share on other sites
tooz 56 Posted March 13, 2023 hello @CommandLine726, sorry for the very late reply. unfortunaly if you're using a dsi panel there's no way to rotate the screen; however if you're using a hdmi monitor, you cand rotate the screen by editing the /etc/X11/xorg.conf.d/20-modesetting.conf 1. sudo su 2. cat /etc/X11/xorg.conf.d/20-modesetting.conf (if the configuration exisits, you will see the last section: Section "Monitor" Identifier "Default Monitor" Option "Rotate" "normal") 3. vim /etc/X11/xorg.conf.d/20-modesetting.conf change the Option "Rotate" "normal" to "inverted" "normal" 4. reboot now Share this post Link to post Share on other sites
