dgewwga 0 Posted August 29, 2022 Once, instead of issuing rights for a folder, I banned sudo and after several unsuccessful attempts to restore sudo, I was finally disappointed. Now the system without SD card does not work at all (Runs with SD card). Is there any way to install the system? Share this post Link to post Share on other sites
tooz 54 Posted August 30, 2022 hello @dgewwga, the only way is to flash the board on fastboot mode: -- Note: Do not power the board or connect any cables until instructed to do so. The factory settings only includes a U-Boot bootloader for the fastboot mode and does not include a system. Before you begin the flashing procedure, please ensure of the following: - The board is completely powered off. - The boot mode switches are set to eMMC mode. (ON: Switch 1; OFF: Switch 2/Switch 3/Switch 4) 1. Connect the USB Type-C cable to the USB Type-C ports on the board and your host computer. 2. Power on the board and the board should automatically boots into the fastboot mode. 3. Make sure the driver is installed if the host computer is equipped with Windows. 4. Run the `flashall.cmd` script for Windows or `flash.sh` for Linux in this directory. To reflash the system image, please launch weston-terminal on the board and run `sudo reboot-bootloader` to reboot the board into the fastboot mode. Then, follow the step 4 above. If you get unlucky and you can't even boot your board into the fastboot mode, then you can recover the system by booting into the fastboot mode from an image on the SD card and then reflash the board from your host computer as follows. 1. Power off the board and change the boot mode switches to boot from SD card. (ON: Switch 1/Switch 3/Switch 4; OFF: Switch 2) 2. Use a program such as balenaEtcher to flash the recovery.img file to your microSD card. Note: The recovery.img file is just the U-Boot image. Use that to recover a failing device by flashing it to an SD card and booting from that. 3. Connect the USB Type-C cable to the USB Type-C ports on the board and your host computer. 4. Insert the SD card and then power on the board and the board should automatically boots into the fastboot mode. 5. Run the `flash.cmd` script for Windows or `flash.sh` for Linux in this directory. 6. When flashing is complete, your board will reboot. However, because you set the boot mode to SD card, you will see the fastboot mode again. So power off the board and reset the boot switches to eMMC mode. * The driver for Windows could installed from Microsoft Update automatically or local driver package manually. Share this post Link to post Share on other sites
