Nott 0 Posted September 2, 2022 The system shows error messages as below when I install chromium-driver? This is my first time install driver on Tinker board and have stuck on this situation. Did I miss something before installation ? Can anyone help me or give me some advises? thanks in advanced. linaro@linaro-alip:~$ sudo apt install chromium-driver Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: chromium-x11 : Conflicts: chromium but 89.0.4389.114-1~deb10u1 is to be installed Conflicts: chromium-common but 89.0.4389.114-1~deb10u1 is to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. linaro@linaro-alip:~$ sudo apt install chromium Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: chromium-x11 : Conflicts: chromium but 89.0.4389.114-1~deb10u1 is to be installed Conflicts: chromium-common but 89.0.4389.114-1~deb10u1 is to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. Hardware:Tinker board 2s OS:Tinker Board 2 Debian 10 V2.1.6 Share this post Link to post Share on other sites
tooz 56 Posted September 2, 2022 hello @Nott, please execute the cmd below before installing chromium so all the pkgs and libs are up to date: sudo apt update && sudo apt upgrade -y and then sudo apt install chromium -y Share this post Link to post Share on other sites
Nott 0 Posted September 2, 2022 15 minutes ago, tooz said: hello @Nott, please execute the cmd below before installing chromium so all the pkgs and libs are up to date: sudo apt update && sudo apt upgrade -y and then sudo apt install chromium -y I need the package is chromium and chromium-driver I try the your solution after executing and get the message as below: It seems not working....or I ignore some thing? BTW, thanks for your reply. linaro@linaro-alip:~$ sudo apt update && sudo apt upgrade -y Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://cdn-fastly.deb.debian.org/debian buster InRelease Get:3 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease [56.6 kB] Fetched 56.6 kB in 7s (7781 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 102 packages can be upgraded. Run 'apt list --upgradable' to see them. E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem. linaro@linaro-alip:~$ sudo dpkg --configure -a Setting up lirc (0.10.1-6.3~deb10u1) ... insserv: warning: script 'mountboot.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `mountboot.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `mountboot.sh' insserv: warning: script 'rkisp_3A.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `rkisp_3A.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `rkisp_3A.sh' insserv: warning: script 'mountboot.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `mountboot.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `mountboot.sh' insserv: warning: script 'rkisp_3A.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `rkisp_3A.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `rkisp_3A.sh' Created symlink /etc/systemd/system/multi-user.target.wants/lircd.service → /lib/systemd/system/lircd.service. Created symlink /etc/systemd/system/sockets.target.wants/lircd.socket → /lib/systemd/system/lircd.socket. Processing triggers for man-db (2.8.5-2) ... linaro@linaro-alip:~$ sudo apt update && sudo apt upgrade -y Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://cdn-fastly.deb.debian.org/debian buster InRelease Hit:3 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease Reading package lists... Done Building dependency tree Reading state information... Done 102 packages can be upgraded. Run 'apt list --upgradable' to see them. Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: libaom0 libdrm-freedreno1 libdrm-tegra0 libmysofa0 libva-drm2 libva-x11-2 libva2 libvdpau1 libvidstab1.1 Use 'sudo apt autoremove' to remove them. The following packages have been kept back: base-files bluez bluez-obexd debconf debconf-i18n distro-info-data ffmpeg ir-keytable klibc-utils libavcodec-dev libavcodec58 libavdevice-dev libavdevice58 libavfilter-dev libavfilter7 libavformat-dev libavformat58 libavresample-dev libavresample4 libavutil-dev libavutil56 libbluetooth3 libc-bin libc-l10n libcups2 libdns-export1104 libdrm-common libdrm-dev libdrm2 libdvbv5-0 libdvbv5-dev libdvbv5-doc libexpat1 libexpat1-dev libflac8 libfluidsynth1 libgcrypt20 libgmp10 libgnutls30 libgssapi-krb5-2 libhogweed4 libisc-export1100 libk5crypto3 libklibc libkrb5-3 libkrb5support0 libnettle6 libnss3 libntfs-3g883 libpam-systemd libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpostproc-dev libpostproc55 libsasl2-2 libsasl2-modules-db libsmbclient libsndfile1 libswresample-dev libswresample3 libswscale-dev libswscale5 libsystemd0 libudev1 libuv1 libv4l-0 libv4l-dev libv4lconvert0 libwavpack1 libwbclient0 locales ntfs-3g openbox openbox-dev openssl policykit-1 psmisc qv4l2 rsyslog samba-libs systemd systemd-sysv tzdata udev v4l-utils vim vim-common vim-runtime vim-tiny xdmx xdmx-tools xnest xorg-server-source xserver-common xserver-xephyr xserver-xorg-core xserver-xorg-dev xserver-xorg-legacy xterm xvfb xxd 0 upgraded, 0 newly installed, 0 to remove and 102 not upgraded. linaro@linaro-alip:~$ sudo apt install chromium -y Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: chromium-x11 : Conflicts: chromium but 89.0.4389.114-1~deb10u1 is to be installed Conflicts: chromium-common but 89.0.4389.114-1~deb10u1 is to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. Share this post Link to post Share on other sites
Nott 0 Posted September 5, 2022 I need the package is chromium and chromium-driver I try the your solution after executing and get the message as below: It seems not working....or I ignore some thing? BTW, thanks for your reply. linaro@linaro-alip:~$ sudo apt update && sudo apt upgrade -y Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://cdn-fastly.deb.debian.org/debian buster InRelease Get:3 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease [56.6 kB] Fetched 56.6 kB in 7s (7781 B/s) Reading package lists... Done Building dependency tree Reading state information... Done 102 packages can be upgraded. Run 'apt list --upgradable' to see them. E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem. linaro@linaro-alip:~$ sudo dpkg --configure -a Setting up lirc (0.10.1-6.3~deb10u1) ... insserv: warning: script 'mountboot.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `mountboot.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `mountboot.sh' insserv: warning: script 'rkisp_3A.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `rkisp_3A.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `rkisp_3A.sh' insserv: warning: script 'mountboot.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `mountboot.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `mountboot.sh' insserv: warning: script 'rkisp_3A.sh' missing LSB tags insserv: Default-Start undefined, assuming empty start runlevel(s) for script `rkisp_3A.sh' insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `rkisp_3A.sh' Created symlink /etc/systemd/system/multi-user.target.wants/lircd.service → /lib/systemd/system/lircd.service. Created symlink /etc/systemd/system/sockets.target.wants/lircd.socket → /lib/systemd/system/lircd.socket. Processing triggers for man-db (2.8.5-2) ... linaro@linaro-alip:~$ sudo apt update && sudo apt upgrade -y Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://cdn-fastly.deb.debian.org/debian buster InRelease Hit:3 http://cdn-fastly.deb.debian.org/debian buster-updates InRelease Reading package lists... Done Building dependency tree Reading state information... Done 102 packages can be upgraded. Run 'apt list --upgradable' to see them. Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: libaom0 libdrm-freedreno1 libdrm-tegra0 libmysofa0 libva-drm2 libva-x11-2 libva2 libvdpau1 libvidstab1.1 Use 'sudo apt autoremove' to remove them. The following packages have been kept back: base-files bluez bluez-obexd debconf debconf-i18n distro-info-data ffmpeg ir-keytable klibc-utils libavcodec-dev libavcodec58 libavdevice-dev libavdevice58 libavfilter-dev libavfilter7 libavformat-dev libavformat58 libavresample-dev libavresample4 libavutil-dev libavutil56 libbluetooth3 libc-bin libc-l10n libcups2 libdns-export1104 libdrm-common libdrm-dev libdrm2 libdvbv5-0 libdvbv5-dev libdvbv5-doc libexpat1 libexpat1-dev libflac8 libfluidsynth1 libgcrypt20 libgmp10 libgnutls30 libgssapi-krb5-2 libhogweed4 libisc-export1100 libk5crypto3 libklibc libkrb5-3 libkrb5support0 libnettle6 libnss3 libntfs-3g883 libpam-systemd libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpostproc-dev libpostproc55 libsasl2-2 libsasl2-modules-db libsmbclient libsndfile1 libswresample-dev libswresample3 libswscale-dev libswscale5 libsystemd0 libudev1 libuv1 libv4l-0 libv4l-dev libv4lconvert0 libwavpack1 libwbclient0 locales ntfs-3g openbox openbox-dev openssl policykit-1 psmisc qv4l2 rsyslog samba-libs systemd systemd-sysv tzdata udev v4l-utils vim vim-common vim-runtime vim-tiny xdmx xdmx-tools xnest xorg-server-source xserver-common xserver-xephyr xserver-xorg-core xserver-xorg-dev xserver-xorg-legacy xterm xvfb xxd 0 upgraded, 0 newly installed, 0 to remove and 102 not upgraded. linaro@linaro-alip:~$ sudo apt install chromium -y Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: chromium-x11 : Conflicts: chromium but 89.0.4389.114-1~deb10u1 is to be installed Conflicts: chromium-common but 89.0.4389.114-1~deb10u1 is to be installed E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages. Share this post Link to post Share on other sites
Joe 3 Posted September 6, 2022 Hi Nott: Can you try ?? wget https://github.com/electron/electron/releases/download/v11.2.3/chromedriver-v11.2.3-linux-arm64.zip unzip chromedriver-v11.2.3-linux-arm64.zip ./chromedriver Thanks. 1 Share this post Link to post Share on other sites
tooz 56 Posted September 6, 2022 hello @Nott, to install the latest chromium, the built-in version of chromium needs to be removed first, please execute the following to 1. remove the built-in chromium and 2. install the latest version of chromium: sudo apt-mark unhold chromium-x11 sudo apt-mark unhold chromium-x11-dbgsym sudo apt -y remove chromium-x11 sudo apt-get update sudo apt -y install chromium Share this post Link to post Share on other sites
