abhayrjoshi 0 Posted September 8, 2022 Can the Tinker Edge R be powered using the VCC 5V pin on the 40 pin header? With the CPU, NPU, and 1 USB-A under operation, what will be the typical power consumption profile? Is it around 10-12W that can be supplied using the pins on the header (if possible)? My current application works towards integrating the Tinker Edge R into a remote controlled car, and if there are any other recommendations on powering the board, it will be of great help! Share this post Link to post Share on other sites
abhayrjoshi 0 Posted September 10, 2022 (edited) Can you please comment on the power consumption of the Tinker Edge R series and the recommended wattage of the power supply? Is a typical 30W power supply as in the case of Tinker Board 2 enough or is a higher wattage recommended? Will the following power sources suffice or are there any alternative recommendations? 12V/3A https://talentcell.com/lithium-ion-battery/12v/yb1206000-usb.html 12V/6A https://talentcell.com/lithium-ion-battery/12v/yb1208300-usb.html Thank you for your time, Edited September 10, 2022 by abhayrjoshi Share this post Link to post Share on other sites
tooz 56 Posted September 13, 2022 hello @abhayrjoshi, On 9/9/2022 at 3:34 AM, abhayrjoshi said: Can the Tinker Edge R be powered using the VCC 5V pin on the 40 pin header? no, the 40 pin header of tinker edge r cannot be used to power the board. only dc in jack & dc in pin header can be used as power supply pins. the full load power consumption of cpu/ npu/ usb is around 16w. we'd suggest to have power supply with 50 wattage if all the input output ports are being accessed/ used. Share this post Link to post Share on other sites
abhayrjoshi 0 Posted October 21, 2022 Thank you! I ended up buying the https://talentcell.com/lithium-ion-battery/12v/yb1208300-usb.html and was able to power the board. The bundled connectors are compatible. Share this post Link to post Share on other sites
