Vincenzo 0 Posted September 18, 2022 (edited) good morning all I have a couple of questions: I was finding the TinkerOS lite (like RaspianOS lite).. i.e the OS without the X11 graphical GUI. But I realized, that maybe TinkeOS lite does not exist. Is it correct? Therefore: How can I delete all packages related to GUI, in order to have a clean TinkerOS to be used as pure "server"? 2. in my virtual box debian installed into windows 10 laptop, i cloned the image of the TinkerOS flashed into an SD using this command: sudo dd bs=4M if=/dev/sdc of=220918_TB_32GB_port_22.img status=progress && sync but then when I recover this image using Balena in a new SD card for example... the new SD card does not boot. what is wrong? thanks for your support Vincenzo Edited September 18, 2022 by Vincenzo Share this post Link to post Share on other sites
berkin88 0 Posted June 25, 2023 Hi, when will tinker os lite version come? Share this post Link to post Share on other sites
