peterkwon 1 Posted September 19, 2022 https://github.com/TinkerEdgeT/mendel-manifest $ repo init -u https://github.com/TinkerEdgeT/mendel-manifest.git -b mendel-eagle-imx_8m $ repo sync After downloading the development environment, run build/setup.sh Run build.sh Check the following error message -------------------------------------------------------------------------- build Message---------------------------------------------------------------------- ./build.sh VERSION_NUMBER: ======================================== ROOTDIR=/home/peterkwon/prj/tinkerBoard_T OUT=/home/peterkwon/prj/tinkerBoard_T/out PRODUCT_OUT=/home/peterkwon/prj/tinkerBoard_T/out/target/product/imx8m_phanbell HOST_OUT=/home/peterkwon/prj/tinkerBoard_T/out/host/linux-x86 ROOT_OUT=/home/peterkwon/prj/tinkerBoard_T/out/root ======================================== Type m to build. /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:32.5-18: Warning (reg_format): /fragment@2/__overlay__/pcm5122@4d:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #address-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #size-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/waveshare_5inch_dsi.dts:10.12-12.6: Warning (unit_address_vs_reg): /fragment@0/__overlay__/panel@0: node has a unit name, but no reg property *** GUI build selected -- set HEADLESS_BUILD=true if this is not what you intend. *** Building packages locally, set FETCH_PACKAGES=true to use prebuilts mkdir -p /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/board /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build/Dockerfile /home/peterkwon/prj/tinkerBoard_T/cache/docker-build docker build -t aiy-board-builder /home/peterkwon/prj/tinkerBoard_T/cache/docker-build [+] Building 7.6s (8/8) FINISHED => [internal] load build definition from Dockerfile 0.0s => => transferring dockerfile: 924B 0.0s => [internal] load .dockerignore 0.0s => => transferring context: 2B 0.0s => [internal] load metadata for docker.io/library/debian:10.0 1.0s => [1/4] FROM docker.io/library/debian:10.0@sha256:2f04d3d33b6027bb74ecc81397abe780649ec89f1a2af18d7022737d0482cefe 0.0s => [internal] load build context 0.0s => => transferring context: 3.56kB 0.0s => CACHED [2/4] ADD ./build /build 0.0s => CACHED [3/4] ADD ./board /board 0.0s => ERROR [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs' 6.6s ------ > [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs': #0 0.558 Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB] #0 0.694 Get:2 http://deb.debian.org/debian buster InRelease [122 kB] #0 0.882 Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB] #0 0.900 Get:4 http://security.debian.org/debian-security buster/updates/main amd64 Packages [357 kB] #0 1.286 Get:5 http://deb.debian.org/debian buster/main amd64 Packages [7909 kB] #0 2.154 Get:6 http://deb.debian.org/debian buster-updates/main amd64 Packages [8788 B] #0 3.351 Fetched 8488 kB in 3s (3000 kB/s) #0 3.351 Reading package lists... #0 4.013 Reading package lists... #0 4.659 Building dependency tree... #0 4.769 Reading state information... #0 4.873 The following additional packages will be installed: #0 4.873 lsb-base #0 4.873 Suggested packages: #0 4.873 make-doc #0 4.933 The following NEW packages will be installed: #0 4.933 lsb-base make sudo #0 5.159 0 upgraded, 3 newly installed, 0 to remove and 36 not upgraded. #0 5.159 Need to get 1614 kB of archives. #0 5.159 After this operation, 5259 kB of additional disk space will be used. #0 5.159 Get:1 http://deb.debian.org/debian buster/main amd64 lsb-base all 10.2019051400 [28.4 kB] #0 5.235 Get:2 http://deb.debian.org/debian buster/main amd64 make amd64 4.2.1-1.2 [341 kB] #0 5.400 Get:3 http://deb.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u3 [1244 kB] #0 5.789 debconf: delaying package configuration, since apt-utils is not installed #0 5.823 Fetched 1614 kB in 1s (2443 kB/s) #0 5.851 Selecting previously unselected package lsb-base. (Reading database ... 6674 files and directories currently installed.) #0 5.863 Preparing to unpack .../lsb-base_10.2019051400_all.deb ... #0 5.868 Unpacking lsb-base (10.2019051400) ... #0 5.924 Selecting previously unselected package make. #0 5.925 Preparing to unpack .../make_4.2.1-1.2_amd64.deb ... #0 5.929 Unpacking make (4.2.1-1.2) ... #0 6.049 Selecting previously unselected package sudo. #0 6.050 Preparing to unpack .../sudo_1.8.27-1+deb10u3_amd64.deb ... #0 6.058 Unpacking sudo (1.8.27-1+deb10u3) ... #0 6.238 Setting up lsb-base (10.2019051400) ... #0 6.252 Setting up make (4.2.1-1.2) ... #0 6.267 Setting up sudo (1.8.27-1+deb10u3) ... #0 6.337 invoke-rc.d: could not determine current runlevel #0 6.346 invoke-rc.d: policy-rc.d denied execution of start. #0 6.417 /build/setup.sh: line 57: git: command not found #0 6.423 ======================================== #0 6.423 ROOTDIR=/ #0 6.423 OUT=//out #0 6.423 PRODUCT_OUT=//out/target/product/imx8m_phanbell #0 6.423 HOST_OUT=//out/host/linux-x86 #0 6.423 ROOT_OUT=//out/root #0 6.423 ======================================== #0 6.423 #0 6.423 Type m to build. #0 6.427 make: Entering directory '/build' #0 6.441 make: Leaving directory '/build' #0 6.441 Makefile:26: *** qemu-user-static is either not installed or not configured properly.. Stop. ------ Dockerfile:21 -------------------- 20 | ADD ./board /board 21 | >>> RUN /bin/bash -c '\ 22 | >>> apt-get update && \ 23 | >>> apt-get install -y sudo make && \ 24 | >>> ln -sfr /build/Makefile /Makefile && \ 25 | >>> source /build/setup.sh && \ 26 | >>> make -C /build prereqs' 27 | -------------------- error: failed to solve: process "/bin/sh -c /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs'" did not complete successfully: exit code: 2 make: *** [/home/peterkwon/prj/tinkerBoard_T/build/docker.mk:32: /home/peterkwon/prj/tinkerBoard_T/cache/aiy-board-builder.tar] Error 1 /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:32.5-18: Warning (reg_format): /fragment@2/__overlay__/pcm5122@4d:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #address-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #size-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/waveshare_5inch_dsi.dts:10.12-12.6: Warning (unit_address_vs_reg): /fragment@0/__overlay__/panel@0: node has a unit name, but no reg property *** GUI build selected -- set HEADLESS_BUILD=true if this is not what you intend. *** Building packages locally, set FETCH_PACKAGES=true to use prebuilts mkdir -p /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/board /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build/Dockerfile /home/peterkwon/prj/tinkerBoard_T/cache/docker-build docker build -t aiy-board-builder /home/peterkwon/prj/tinkerBoard_T/cache/docker-build [+] Building 8.5s (8/8) FINISHED => [internal] load .dockerignore 0.0s => => transferring context: 2B 0.0s => [internal] load build definition from Dockerfile 0.0s => => transferring dockerfile: 924B 0.0s => [internal] load metadata for docker.io/library/debian:10.0 1.9s => [internal] load build context 0.0s => => transferring context: 3.56kB 0.0s => [1/4] FROM docker.io/library/debian:10.0@sha256:2f04d3d33b6027bb74ecc81397abe780649ec89f1a2af18d7022737d0482cefe 0.0s => CACHED [2/4] ADD ./build /build 0.0s => CACHED [3/4] ADD ./board /board 0.0s => ERROR [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs' 6.5s ------ > [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs': #0 0.520 Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB] #0 0.635 Get:2 http://deb.debian.org/debian buster InRelease [122 kB] #0 0.824 Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB] #0 0.857 Get:4 http://security.debian.org/debian-security buster/updates/main amd64 Packages [357 kB] #0 1.239 Get:5 http://deb.debian.org/debian buster/main amd64 Packages [7909 kB] #0 2.078 Get:6 http://deb.debian.org/debian buster-updates/main amd64 Packages [8788 B] #0 3.277 Fetched 8488 kB in 3s (3041 kB/s) #0 3.277 Reading package lists... #0 3.953 Reading package lists... #0 4.582 Building dependency tree... #0 4.691 Reading state information... #0 4.796 The following additional packages will be installed: #0 4.796 lsb-base #0 4.796 Suggested packages: #0 4.796 make-doc #0 4.854 The following NEW packages will be installed: #0 4.854 lsb-base make sudo #0 5.079 0 upgraded, 3 newly installed, 0 to remove and 36 not upgraded. #0 5.079 Need to get 1614 kB of archives. #0 5.079 After this operation, 5259 kB of additional disk space will be used. #0 5.079 Get:1 http://deb.debian.org/debian buster/main amd64 lsb-base all 10.2019051400 [28.4 kB] #0 5.156 Get:2 http://deb.debian.org/debian buster/main amd64 make amd64 4.2.1-1.2 [341 kB] #0 5.324 Get:3 http://deb.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u3 [1244 kB] #0 5.654 debconf: delaying package configuration, since apt-utils is not installed #0 5.696 Fetched 1614 kB in 1s (2661 kB/s) #0 5.736 Selecting previously unselected package lsb-base. (Reading database ... 6674 files and directories currently installed.) #0 5.749 Preparing to unpack .../lsb-base_10.2019051400_all.deb ... #0 5.753 Unpacking lsb-base (10.2019051400) ... #0 5.808 Selecting previously unselected package make. #0 5.810 Preparing to unpack .../make_4.2.1-1.2_amd64.deb ... #0 5.814 Unpacking make (4.2.1-1.2) ... #0 5.936 Selecting previously unselected package sudo. #0 5.938 Preparing to unpack .../sudo_1.8.27-1+deb10u3_amd64.deb ... #0 5.946 Unpacking sudo (1.8.27-1+deb10u3) ... #0 6.129 Setting up lsb-base (10.2019051400) ... #0 6.143 Setting up make (4.2.1-1.2) ... #0 6.157 Setting up sudo (1.8.27-1+deb10u3) ... #0 6.226 invoke-rc.d: could not determine current runlevel #0 6.233 invoke-rc.d: policy-rc.d denied execution of start. #0 6.305 /build/setup.sh: line 57: git: command not found #0 6.311 ======================================== #0 6.311 ROOTDIR=/ #0 6.311 OUT=//out #0 6.311 PRODUCT_OUT=//out/target/product/imx8m_phanbell #0 6.311 HOST_OUT=//out/host/linux-x86 #0 6.311 ROOT_OUT=//out/root #0 6.311 ======================================== #0 6.311 #0 6.311 Type m to build. #0 6.314 make: Entering directory '/build' #0 6.328 Makefile:26: *** qemu-user-static is either not installed or not configured properly.. Stop. #0 6.328 make: Leaving directory '/build' ------ Dockerfile:21 -------------------- 20 | ADD ./board /board 21 | >>> RUN /bin/bash -c '\ 22 | >>> apt-get update && \ 23 | >>> apt-get install -y sudo make && \ 24 | >>> ln -sfr /build/Makefile /Makefile && \ 25 | >>> source /build/setup.sh && \ 26 | >>> make -C /build prereqs' 27 | -------------------- error: failed to solve: process "/bin/sh -c /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs'" did not complete successfully: exit code: 2 make: *** [/home/peterkwon/prj/tinkerBoard_T/build/docker.mk:32: /home/peterkwon/prj/tinkerBoard_T/cache/aiy-board-builder.tar] Error 1 /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:32.5-18: Warning (reg_format): /fragment@2/__overlay__/pcm5122@4d:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #address-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dts:29.24-34.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/pcm5122@4d: Relying on default #size-cells value /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/hifiberry-dacplus-overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size' /home/peterkwon/prj/tinkerBoard_T/packages/uboot-imx/debian/overlays/waveshare_5inch_dsi.dts:10.12-12.6: Warning (unit_address_vs_reg): /fragment@0/__overlay__/panel@0: node has a unit name, but no reg property *** GUI build selected -- set HEADLESS_BUILD=true if this is not what you intend. *** Building packages locally, set FETCH_PACKAGES=true to use prebuilts mkdir -p /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/board /home/peterkwon/prj/tinkerBoard_T/cache/docker-build cp -a /home/peterkwon/prj/tinkerBoard_T/build/Dockerfile /home/peterkwon/prj/tinkerBoard_T/cache/docker-build docker build -t aiy-board-builder /home/peterkwon/prj/tinkerBoard_T/cache/docker-build [+] Building 7.7s (8/8) FINISHED => [internal] load build definition from Dockerfile 0.0s => => transferring dockerfile: 924B 0.0s => [internal] load .dockerignore 0.0s => => transferring context: 2B 0.0s => [internal] load metadata for docker.io/library/debian:10.0 0.9s => [1/4] FROM docker.io/library/debian:10.0@sha256:2f04d3d33b6027bb74ecc81397abe780649ec89f1a2af18d7022737d0482cefe 0.0s => [internal] load build context 0.0s => => transferring context: 3.56kB 0.0s => CACHED [2/4] ADD ./build /build 0.0s => CACHED [3/4] ADD ./board /board 0.0s => ERROR [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs' 6.7s ------ > [4/4] RUN /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs': #0 0.573 Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB] #0 0.675 Get:2 http://deb.debian.org/debian buster InRelease [122 kB] #0 0.877 Get:3 http://deb.debian.org/debian buster-updates InRelease [56.6 kB] #0 0.917 Get:4 http://security.debian.org/debian-security buster/updates/main amd64 Packages [357 kB] #0 1.307 Get:5 http://deb.debian.org/debian buster/main amd64 Packages [7909 kB] #0 2.205 Get:6 http://deb.debian.org/debian buster-updates/main amd64 Packages [8788 B] #0 3.397 Fetched 8488 kB in 3s (2946 kB/s) #0 3.397 Reading package lists... #0 4.089 Reading package lists... #0 4.705 Building dependency tree... #0 4.812 Reading state information... #0 4.917 The following additional packages will be installed: #0 4.917 lsb-base #0 4.917 Suggested packages: #0 4.917 make-doc #0 4.976 The following NEW packages will be installed: #0 4.976 lsb-base make sudo #0 5.169 0 upgraded, 3 newly installed, 0 to remove and 36 not upgraded. #0 5.169 Need to get 1614 kB of archives. #0 5.169 After this operation, 5259 kB of additional disk space will be used. #0 5.169 Get:1 http://deb.debian.org/debian buster/main amd64 lsb-base all 10.2019051400 [28.4 kB] #0 5.244 Get:2 http://deb.debian.org/debian buster/main amd64 make amd64 4.2.1-1.2 [341 kB] #0 5.405 Get:3 http://deb.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u3 [1244 kB] #0 5.795 debconf: delaying package configuration, since apt-utils is not installed #0 5.835 Fetched 1614 kB in 1s (2576 kB/s) #0 5.871 Selecting previously unselected package lsb-base. (Reading database ... 6674 files and directories currently installed.) #0 5.883 Preparing to unpack .../lsb-base_10.2019051400_all.deb ... #0 5.887 Unpacking lsb-base (10.2019051400) ... #0 5.943 Selecting previously unselected package make. #0 5.945 Preparing to unpack .../make_4.2.1-1.2_amd64.deb ... #0 5.950 Unpacking make (4.2.1-1.2) ... #0 6.076 Selecting previously unselected package sudo. #0 6.077 Preparing to unpack .../sudo_1.8.27-1+deb10u3_amd64.deb ... #0 6.084 Unpacking sudo (1.8.27-1+deb10u3) ... #0 6.283 Setting up lsb-base (10.2019051400) ... #0 6.297 Setting up make (4.2.1-1.2) ... #0 6.310 Setting up sudo (1.8.27-1+deb10u3) ... #0 6.377 invoke-rc.d: could not determine current runlevel #0 6.386 invoke-rc.d: policy-rc.d denied execution of start. #0 6.459 /build/setup.sh: line 57: git: command not found #0 6.465 ======================================== #0 6.465 ROOTDIR=/ #0 6.465 OUT=//out #0 6.465 PRODUCT_OUT=//out/target/product/imx8m_phanbell #0 6.465 HOST_OUT=//out/host/linux-x86 #0 6.465 ROOT_OUT=//out/root #0 6.465 ======================================== #0 6.465 #0 6.465 Type m to build. #0 6.468 make: Entering directory '/build' #0 6.483 make: Leaving directory '/build' #0 6.483 Makefile:26: *** qemu-user-static is either not installed or not configured properly.. Stop. ------ Dockerfile:21 -------------------- 20 | ADD ./board /board 21 | >>> RUN /bin/bash -c '\ 22 | >>> apt-get update && \ 23 | >>> apt-get install -y sudo make && \ 24 | >>> ln -sfr /build/Makefile /Makefile && \ 25 | >>> source /build/setup.sh && \ 26 | >>> make -C /build prereqs' 27 | -------------------- error: failed to solve: process "/bin/sh -c /bin/bash -c 'apt-get update && apt-get install -y sudo make && ln -sfr /build/Makefile /Makefile && source /build/setup.sh && make -C /build prereqs'" did not complete successfully: exit code: 2 make: *** [/home/peterkwon/prj/tinkerBoard_T/build/docker.mk:32: /home/peterkwon/prj/tinkerBoard_T/cache/aiy-board-builder.tar] Error 1 -------------------------------------------------------------------------- build Message End ---------------------------------------------------------------------- I want to know how to fix the error. Regard. Share this post Link to post Share on other sites
peterkwon 1 Posted September 19, 2022 (edited) self-response The contents of build/Dockerfile were modified. --> FROM debian:10.0 MAINTAINER coral-support@google.com # Install the prerequisite packages into the image. ADD ./build /build ADD ./board /board RUN /bin/bash -c '\ apt-get update && \ apt-get install -y sudo make && \ + apt-get install -y sudo git && \ + apt-get install -y sudo build-essential && \ + apt-get install -y sudo qemu-user-static && \ + apt-get install -y sudo bc && \ ln -sfr /build/Makefile /Makefile && \ source /build/setup.sh && \ make -C /build prereqs' In this way, build-essential, qemu-user-static, and bc are added and build.sh is executed, and the build is in progress. Edited September 19, 2022 by peterkwon Share this post Link to post Share on other sites
