sushil 0 Posted October 10, 2022 i can't create AP mode in tinkerboard2. Share this post Link to post Share on other sites
tooz 51 Posted April 14, 2023 hello @sushil, to enable softap mode: Developer Guide · TinkerBoard/TinkerBoard Wiki (github.com) 1. for tinker board / tinker board r2.0, download https://github.com/TinkerBoard/TinkerBoard/files/8107749/SoftAP_debian10_20220127.zip and unzip the file 2. update packages and install dnsmasq and hostapd, then execute the shellscript to enable softap sudo apt-get update sudo apt install dnsmasq hostapd move to the SoftAP_debian10_20220127 directory, and execute the script (with root access) chmod 755 Enable_SoftAP.sh Disable_SoftAP.sh ./Enable_SoftAP.sh error rfkill: cannot open /dev/rfkill: No such file or directory can be ignored 1. to get wifi back to normal mode, please execute ./Disable_SoftAP.sh (otherwise it stays in softap mode after ./Enable_SoftAP.sh is executed) 2. when doing ./Enable_SoftAP.sh or ./Disable_SoftAP.sh if the error SIOCSIFFLAGS: Operation not possible due to RF-kill occurrs, please execute echo 1 > /sys/class/rfkill/rfkill0/state it is not recommended to use concurrent mode Share this post Link to post Share on other sites
sushil 0 Posted April 18, 2023 hello @tooz, yes i am able to create this softap earlier but i need to create ap and sta mode at same time as of raspberry pi 3B/4B. Share this post Link to post Share on other sites
