김용래 0 Posted November 2, 2022 Environment) 1. Install Tinker OS (android - v 2.0.8) on eMMC on Tinker Board 2S/4GB 2. Power Adapter - DC 12V, 5A Problem Situation) 1. The screen stops after 5 to 15 minutes of booting. 1_1) At this time, the device cannot be found when you enter "adb devices" in the desktop terminal, and the LED on the board is only red. 2. If you unplug and plug in the DC power connector immediately after stopping, it will not boot. However, after a short period of time (5 to 10 minutes), plug in the connector again to boot. The above 1 to 2 situations are repeated. What I worked on after installing Tinker OS (android - v2.0.8)) 1. Enable Developer Mode 2. Change the minimum width value to 1384 3. USB connection between desktop and Tinker Board 2S 4. Installing an application under development through a debugging connection Note) 1) Of the above four tasks, the same problem occurred even if we did not proceed with work 2~4, and we have not tested it yet without working with work 1. 2) I tested it with Android versions v2.0.6 and v2.0.8, but both have the same problem. 3) When Lineage OS was installed on the Raspberry PI board and proceeded the same, it worked well without any problems. More) The same problem occurs when I install Tinker OS (android - v2.0.8) on the SD card and boot with the SD card. normal screen) Abnormalities screen) The above two pictures are when it works without a problem and when there is a problem. Can you let me know if there is a solution? Share this post Link to post Share on other sites
tooz 53 Posted November 2, 2022 hello @김용래, it looks like the cpu is overheated. please use the commands to check the temperature: adb shell watch -n 1 cat /sys/class/thermal/thermal_zone0/temp do you have any console logs that we can look into the issue? Share this post Link to post Share on other sites
김용래 0 Posted November 2, 2022 Temperature checked. The temperature remained between 30000 and 35000 until it stopped. Share this post Link to post Share on other sites
tooz 53 Posted November 2, 2022 hello @김용래, looks like the cpu's kept in normal temperature. can you collect console logs for the symtom? Share this post Link to post Share on other sites
김용래 0 Posted November 3, 2022 How do I collect logs for systom? It's my first time using Android. If you let me know the site I can refer to, I will try it. Share this post Link to post Share on other sites
tooz 53 Posted November 3, 2022 hello @김용래, 1. get a usb uart ttl serial console cable (similar to: https://www.amazon.com/Console-Galileo-Compatible-TTL-232R-3V3-TTL-232R_RPi/dp/B00XRBQJL8?th=1 ) 2. use the usb uart cable to connect tinker 2 (rx and tx pins) it to a pc (usb port) 3. use putty to collect logs, the setup is 'serial (refer device manager for the exact COM#), baud rate = 115200' the log looks like this: DDR Version 1.26 20210628 In channel 0 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x2 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB 256B stride channel 0 CS = 0 MR0=0x98 MR4=0x1 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x98 MR4=0x2 MR5=0xFF MR8=0x8 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x20 ch 1 ddrconfig = 0x101, ddrsize = 0x20 pmugrf_os_reg[2] = 0x3281F281, stride = 0x9 ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 640 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 Share this post Link to post Share on other sites
김용래 0 Posted November 7, 2022 I got the log when booting and the log when the board stopped. When the board stopped, all I did was connect the Desktop and Tinker Board with a USB cable. 1. Log at boot time DDR Version 1.26 20210628 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 644 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=61056MB FwPartOffset=2000 , 0 StorageInit ok = 292645 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT part: 0, name: security, start:0x4000, size:0x2000 GPT part: 1, name: uboot, start:0x6000, size:0x2000 GPT part: 2, name: trust, start:0x8000, size:0x2000 GPT part: 3, name: misc, start:0xa000, size:0x2000 GPT part: 4, name: dtbo, start:0xc000, size:0x2000 GPT part: 5, name: vbmeta, start:0xe000, size:0x800 GPT part: 6, name: boot, start:0xe800, size:0x14000 GPT part: 7, name: recovery, start:0x22800, size:0x30000 GPT part: 8, name: backup, start:0x52800, size:0xc0000 GPT part: 9, name: cache, start:0x112800, size:0xc0000 GPT part: 10, name: metadata, start:0x1d2800, size:0x8000 GPT part: 11, name: baseparameter, start:0x1da800, size:0x800 GPT part: 12, name: splash, start:0x1db000, size:0x8000 GPT part: 13, name: dtoverlay, start:0x1e3000, size:0x8000 GPT part: 14, name: super, start:0x1eb000, size:0x614000 GPT part: 15, name: userdata, start:0x7ff000, size:0x6f40fdf find part:uboot OK. first_lba:0x6000. find part:trust OK. first_lba:0x8000. Trust Addr:0x8000, 0x58334c42 No find bl30.bin Load uboot, ReadLba = 6000 Load OK, addr=0x200000, size=0x10e2a0 RunBL31 0x40000 @ 592488 us NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a ) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09 #android (May 03 2022 - 02:32:32 +0000) Model: Rockchip RK3399 Evaluation Board PreSerial: 2, raw, 0xff1a0000 DRAM: 3.8 GiB Sysmem: init Relocation Offset: f5b6d000 Relocation fdt: f3d612c8 - f3d63ce3 CR: M/C/I Using default environment DM: v1 Set GPIO2_A4 (MASK_RELEASE) output high no mmc device at slot 1 Found IDB in SDcard found super part. dwmmc@fe320000: 1 (SD), sdhci@fe330000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI boot mode: None Flash bootloader message to normal! Android 11.0, Build 2021.8, v2 Found DTB in boot part DTB: rk-kernel.dtb HASH(c): OK ANDROID: fdt overlay OK I2c0 speed: 400000Hz PMIC: RK808 vdd_center 900000 uV vdd_cpu_l 900000 uV vdd_log 1100000 uV rockchip_display_probe load_sn65dsi8x_driver: sn65dsi84@2c load_sn65dsi8x_driver: sn65dsi84@2c : ret=-19 load_sn65dsi8x_driver: sn65dsi86@2d load_sn65dsi8x_driver: sn65dsi86@2d : ret=-19 sn65dsi84_is_connected sn65dsi84 connect = 0 rockchip_display_probe: panel_i2c_busnum = 8 sn65dsi84_is_connected sn65dsi84 connect = 0 I2c8 speed: 100000Hz panel_i2c_reg_read fail, i = 0 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 1 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 2 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 3 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 0 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 1 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 2 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 3 reg = 4 ret = -121 rockchip_display_probe rpi_buffer=-121 powertip_buffer=-121 sn65dsi84_is_connected sn65dsi84 connect = 0 rockchip_display_probe: no dsi panel and no sn65dsi8x connected warning: bad baseparameter Model: ASUS Tinker Board 2/2S read_bmp_header:BMP singature incorrectly 0x0 0x0load_bmp_logo 42 4d bit_count0 Rockchip UBOOT DRM driver version: v1.0.1 xfer: num: 2, addr: 0x50 xfer: num: 2, addr: 0x50 Monitor has basic audio support hdmi info isn't saved in main block mode:1920x1080 hdmi@ff940000: detailed mode clock 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 2025 CEA mode used vic=16 final pixclk = 148500000 tmdsclk = 148500000 PHY powered down in 0 iterations PHY PLL locked 1 iterations PHY powered down in 0 iterations PHY PLL locked 1 iterations sink has audio support hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500 CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A) aplll 816000 KHz apllb 816000 KHz dpll 856000 KHz cpll 24000 KHz gpll 800000 KHz npll 600000 KHz vpll 148000 KHz aclk_perihp 133333 KHz hclk_perihp 66666 KHz pclk_perihp 33333 KHz aclk_perilp0 266666 KHz hclk_perilp0 88888 KHz pclk_perilp0 44444 KHz hclk_perilp1 100000 KHz pclk_perilp1 50000 KHz Net: rk3399_gmac_set_clk: internal clock is UNIMPLEMENTED No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "(none)" optee api revision: 2.0 Vboot=0, AVB images, AVB verify read_is_device_unlocked() ops returned that device is UNLOCKED avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGND get image from preloaded partition... reading cmdline.txt 58 bytes read in 3 ms (18.6 KiB/s) cmdline.txt size = 58 cmdline.txt valid = 1 reading config.txt 1735 bytes read in 3 ms (564.5 KiB/s) config.txt size = 1735 [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line config.txt valid = 1 config on: 1, config off: -1, no config: 0 intf.fiq_debugger = 1 intf.i2c6 = 0 intf.i2c7 = 0 intf.uart0 = 0 intf.uart4 = 0 intf.i2s0 = 0 intf.spi1 = 0 intf.spi5 = 0 intf.pwm0 = 0 intf.pwm1 = 0 intf.pwm3a = 0 intf.spdif = 1 intf.test_clkout2 = 0 conf.gmac = 1 conf.ums = 1 fdt magic number edfe0dd0 fdt size 1048576 set_hw_property: /fiq-debugger status okay set_hw_property: /spdif@ff870000 status okay flash_device_node: /pinctrl/testclk/test-clkout2 rockchip,pins set_hw_property: /ethernet@fe300000 wakeup-enable 1 Could not find "system" partition Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000... Fdt Ramdisk skip relocation ## Booting Android Image at 0x0027f800 ... Kernel: 0x00280000 - 0x0208b810 (30767 KiB) ramdisk: 0x0a200000 - 0x0a2ccd63 (820 KiB) ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 XIP Kernel Image from 0x00280000 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x0208b810 'reserved-memory' ramoops@110000: addr=110000 size=f0000 Using Device Tree in place at 0000000008300000, end 0000000008402fff read_bmp_header:BMP singature incorrectly 0x0 0x0load_bmp_logo 42 4d bit_count0 failed to reserve drm-cubic-lut memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000) Total: 2724.990 ms ----------------------------------------------------------------------------------------------------------------------------- 2. Log when the board stops [ 1166.082944] phy phy-ff770000.syscon:usb2-phy@e450.10: charger = USB_SDP_CHARGER [ 1166.114491] fusb302 4-0022: CC connected in CC2 as UFP [ 1166.132832] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 1166.379861] dwc3 fe800000.dwc3: device reset [ 1166.511629] dwc3 fe800000.dwc3: device reset [ 1166.511764] android_work: did not send uevent (0 0 (null)) [ 1166.658402] android_work: sent uevent USB_STATE=CONNECTED [ 1166.658719] configfs-gadget gadget: high-speed config #1: b [ 1166.659735] android_work: sent uevent USB_STATE=CONFIGURED [ 1166.745781] type=1400 audit(1651547343.230:103): avc: denied { read } for comm="memtrack@1.0-se" name="mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memtrack_default:s0 tcontext=u:object_r:de1 [ 1166.746067] type=1400 audit(1651547343.230:104): avc: denied { open } for comm="memtrack@1.0-se" path="/sys/kernel/debug/mali0/ctx/1964_8/mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memtrac1 [ 1166.746188] type=1400 audit(1651547343.230:105): avc: denied { getattr } for comm="memtrack@1.0-se" path="/sys/kernel/debug/mali0/ctx/1964_8/mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memt1 [ 1167.255438] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency [ 1168.008852] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1168.355529] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1169.022183] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1169.368843] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1170.035529] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1170.382174] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1171.048849] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1171.048937] cpu cpu4: _set_opp_voltage: failed to set voltage (825000 825000 1250000 mV): -110 [ 1171.049048] cpufreq: __target_index: Failed to change cpu frequency: -110 [ 1171.395407] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1172.648740] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1173.662067] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1174.675405] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1175.688736] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1176.702075] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1176.919600] ------------[ cut here ]------------ [ 1176.919629] kernel BUG at arch/arm64/kernel/traps.c:416! [ 1176.919639] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP [ 1176.934998] Modules linked in: 8822ce [ 1176.938666] Process ranker (pid: 550, stack limit = 0x00000000f32b6def) [ 1176.945272] CPU: 4 PID: 550 Comm: ranker Not tainted 4.19.219 #3 [ 1176.951272] Hardware name: ASUS Tinker Board 2/2S (DT) [ 1176.956406] pstate: 00400005 (nzcv daif +PAN -UAO) [ 1176.961197] pc : do_undefinstr+0x4c/0x50 [ 1176.965115] lr : do_undefinstr+0x34/0x50 [ 1176.969032] sp : ffffff8010de3b60 [ 1176.972345] x29: ffffff8010de3b60 x28: ffffffc0d734ab80 [ 1176.977648] x27: 0000000000000002 x26: 0000000013940000 [ 1176.982951] x25: ffffffc0e5ff2a60 x24: 0000000000000000 [ 1176.988253] x23: 0000000020400005 x22: ffffff80082236bc [ 1176.993555] x21: 000000000217d000 x20: 0000007fffffffff [ 1176.998857] x19: ffffff8010de3b80 x18: 0000000000000000 [ 1177.004159] x17: 0000000000000000 x16: 0000000000000000 [ 1177.009461] x15: ffffff80082236bc x14: 0000000000000000 [ 1177.014762] x13: 0000000000000000 x12: 0000000000000002 [ 1177.020064] x11: 0000000000000000 x10: ffffff80099c3018 [ 1177.025366] x9 : 8cc1380e76654f00 x8 : 0000000000000005 [ 1177.030669] x7 : 0000000000000000 x6 : ffffff8010de3b18 [ 1177.035971] x5 : ffffff8010de3b18 x4 : ffffffc0f6f421d0 [ 1177.041273] x3 : 0000000000000001 x2 : 0000000000000001 [ 1177.046575] x1 : 0000000000000000 x0 : 0000000000000000 [ 1177.051878] [ 1177.051878] PC: 0xffffff80080807cc: [ 1177.056841] 07cc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.065016] 07ec 00000000 00000000 00000000 00000000 00000000 a9be7bfd f9000bf3 910003fd [ 1177.073191] 080c aa0003f3 9400127b 34000160 aa1303e0 940040ac 34000100 f9408262 52800080 [ 1177.081366] 082c 52800021 9400403b 39442268 72000d1f 54000081 f9400bf3 a8c27bfd d65f03c0 [ 1177.089541] 084c d4210000 a9be7bfd f9000bf3 910003fd 529f8028 72a007e8 529b800a 0a080009 [ 1177.097715] 086c 72a0024a 6b0a013f aa0103f3 54000101 b0000088 91193108 aa1303e1 d63f0100 [ 1177.105890] 088c f9400bf3 a8c27bfd d65f03c0 11007908 529f0029 0a080008 72a00609 6b09011f [ 1177.114065] 08ac 540001e0 52980029 72a00649 6b09011f 54000100 529f0029 72a00689 6b09011f [ 1177.122241] [ 1177.122241] LR: 0xffffff80080807b4: [ 1177.127203] 07b4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.135378] 07d4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.143552] 07f4 00000000 00000000 00000000 a9be7bfd f9000bf3 910003fd aa0003f3 9400127b [ 1177.151727] 0814 34000160 aa1303e0 940040ac 34000100 f9408262 52800080 52800021 9400403b [ 1177.159901] 0834 39442268 72000d1f 54000081 f9400bf3 a8c27bfd d65f03c0 d4210000 a9be7bfd [ 1177.168076] 0854 f9000bf3 910003fd 529f8028 72a007e8 529b800a 0a080009 72a0024a 6b0a013f [ 1177.176251] 0874 aa0103f3 54000101 b0000088 91193108 aa1303e1 d63f0100 f9400bf3 a8c27bfd [ 1177.184425] 0894 d65f03c0 11007908 529f0029 0a080008 72a00609 6b09011f 540001e0 52980029 [ 1177.192601] [ 1177.192601] SP: 0xffffff8010de3ae0: [ 1177.197563] 3ae0 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 00000002 00000000 [ 1177.205738] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.213914] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.222088] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.230263] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.238437] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.246612] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.254786] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.262962] [ 1177.262962] X4: 0xffffffc0f6f42150: [ 1177.267925] 2150 b05834c8 ffffffc0 0001af34 00000000 02c160c0 ffffffbf 00000000 00000000 [ 1177.276100] 2170 8f0af900 ffffffc0 0000250c 00000000 023c2b00 ffffffbf 0275d600 ffffffbf [ 1177.284275] 2190 ee181a40 ffffffc0 0000005c 00000000 03b86000 ffffffbf 00000000 00000000 [ 1177.292449] 21b0 00000000 00000000 00000000 00000000 00000000 0000000e 00000000 00000000 [ 1177.300623] 21d0 edb43dc0 ffffffc0 0000032c 00000000 03b6d0c0 ffffffbf 00000000 00000000 [ 1177.308798] 21f0 9f2f1490 ffffffc0 00005d9c 00000000 027cbc00 ffffffbf 00000000 00000000 [ 1177.316972] 2210 ef65e000 ffffffc0 000000f4 00000000 03bd9780 ffffffbf 00000000 00000000 [ 1177.325147] 2230 e5716f00 ffffffc0 000014c4 00000000 0395c580 ffffffbf 00000000 00000000 [ 1177.333323] [ 1177.333323] X5: 0xffffff8010de3a98: [ 1177.338285] 3a98 082236bc ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.346460] 3ab8 10de3b80 ffffff80 ffffffff 0000007f 0217d000 00000000 082236bc ffffff80 [ 1177.354635] 3ad8 20400005 00000000 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 [ 1177.362809] 3af8 00000002 00000000 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 [ 1177.370984] 3b18 10de3b60 ffffff80 0808084c ffffff80 00400005 00000000 00000000 00000000 [ 1177.379159] 3b38 20400005 00000000 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 [ 1177.387334] 3b58 0808084c ffffff80 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 [ 1177.395508] 3b78 080f8998 ffffff80 00000000 00000000 13940000 00000000 00000001 00000000 [ 1177.403683] [ 1177.403683] X6: 0xffffff8010de3a98: [ 1177.408646] 3a98 082236bc ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.416820] 3ab8 10de3b80 ffffff80 ffffffff 0000007f 0217d000 00000000 082236bc ffffff80 [ 1177.424996] 3ad8 20400005 00000000 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 [ 1177.433170] 3af8 00000002 00000000 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 [ 1177.441345] 3b18 10de3b60 ffffff80 0808084c ffffff80 00400005 00000000 00000000 00000000 [ 1177.449519] 3b38 20400005 00000000 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 [ 1177.457694] 3b58 0808084c ffffff80 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 [ 1177.465869] 3b78 080f8998 ffffff80 00000000 00000000 13940000 00000000 00000001 00000000 [ 1177.474044] [ 1177.474044] X10: 0xffffff80099c2f98: [ 1177.479091] 2f98 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.487280] 2fb8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.495464] 2fd8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.503648] 2ff8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.511832] 3018 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.520016] 3038 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.528201] 3058 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.536384] 3078 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.544570] [ 1177.544570] X15: 0xffffff800822363c: [ 1177.549617] 363c 1100052a 7100115f 1a8907e9 8b294d0a f9420140 b40000e0 f940000a eb01015f [ 1177.557792] 365c 54000088 f940040a eb01015f 540002a8 1100052a 7100115f 1a8907e9 8b294d08 [ 1177.565966] 367c f9420100 b40000e0 f9400008 eb01011f 54000088 f9400408 eb01011f 54000128 [ 1177.574140] 369c aa1f03e0 d65f03c0 aa1f03e0 f9027d09 f902011f f902851f f902891f f9028d1f [ 1177.582316] 36bc d65f83c0 a9bf7bfd 910003fd a9402009 f9404c0a f940002d cb090108 8b483148 [ 1177.590490] 36dc d1000508 b400028d 52800022 5280018b 14000008 f9404d8d eb0d015f 9a8b256e [ 1177.598665] 36fc f86e798d 1a9f27ef 0a0f0042 b400010d f9400dac aa0d03e9 eb08019f d10161ac [ 1177.606839] 371c 54fffea2 f9003988 17fffff3 8b0e0d8a 14000004 aa1f03e9 52800022 aa0103ea [ 1177.615015] [ 1177.615015] X19: 0xffffff8010de3b00: [ 1177.620063] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.628237] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.636412] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.644586] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.652760] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.660935] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.669109] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.677284] 3be0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.685459] [ 1177.685459] X22: 0xffffff800822363c: [ 1177.690506] 363c 1100052a 7100115f 1a8907e9 8b294d0a f9420140 b40000e0 f940000a eb01015f [ 1177.698680] 365c 54000088 f940040a eb01015f 540002a8 1100052a 7100115f 1a8907e9 8b294d08 [ 1177.706855] 367c f9420100 b40000e0 f9400008 eb01011f 54000088 f9400408 eb01011f 54000128 [ 1177.715030] 369c aa1f03e0 d65f03c0 aa1f03e0 f9027d09 f902011f f902851f f902891f f9028d1f [ 1177.723205] 36bc d65f83c0 a9bf7bfd 910003fd a9402009 f9404c0a f940002d cb090108 8b483148 [ 1177.731380] 36dc d1000508 b400028d 52800022 5280018b 14000008 f9404d8d eb0d015f 9a8b256e [ 1177.739554] 36fc f86e798d 1a9f27ef 0a0f0042 b400010d f9400dac aa0d03e9 eb08019f d10161ac [ 1177.747729] 371c 54fffea2 f9003988 17fffff3 8b0e0d8a 14000004 aa1f03e9 52800022 aa0103ea [ 1177.755904] [ 1177.755904] X25: 0xffffffc0e5ff29e0: [ 1177.760951] 29e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.769126] 2a00 d42f31b0 ffffffc0 d42bd2a8 ffffffc0 0000119f 00000000 082317ec ffffff80 [ 1177.777301] 2a20 df07b000 0000007a 00000000 00000000 00000000 00000080 d139c000 0000007f [ 1177.785475] 2a40 d4bad000 ffffffc0 0000008c 00000004 00207000 00000000 00000e85 00000000 [ 1177.793650] 2a60 00000001 00000000 e5ff2a68 ffffffc0 e5ff2a68 ffffffc0 00000000 00000000 [ 1177.801825] 2a80 00000001 00000000 00000000 00000000 e5ff2a90 ffffffc0 e5ff2a90 ffffffc0 [ 1177.809999] 2aa0 0001a117 00000000 00411785 00000000 0040dd84 00000000 00005e7d 00000000 [ 1177.818174] 2ac0 00000000 00000000 0007472e 00000000 0000af1a 00000000 00000800 00000000 [ 1177.826350] [ 1177.826350] X28: 0xffffffc0d734ab00: [ 1177.831397] ab00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.839571] ab20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.847746] ab40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.855920] ab60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.864094] ab80 04000023 00000000 ffffffff ffffffff d4bad000 01ca0000 00000001 00000000 [ 1177.872269] aba0 00000000 00000000 10de0000 ffffff80 00000002 00404040 00000000 00000000 [ 1177.880444] abc0 00000000 00000000 00000001 00000004 00000050 00000000 00040379 00000001 [ 1177.888618] abe0 f15f5700 ffffffc0 00000005 00000004 00000001 00000082 00000082 00000082 [ 1177.896793] [ 1177.896793] X29: 0xffffff8010de3ae0: [ 1177.901840] 3ae0 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 00000002 00000000 [ 1177.910015] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.918190] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.926364] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.934539] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.942714] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.950889] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.959063] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.967238] [ 1177.968733] Call trace: [ 1177.971181] do_undefinstr+0x4c/0x50 [ 1177.974750] el1_undef+0x10/0xa8 [ 1177.977983] vmacache_find+0x100/0x104 [ 1177.981724] do_page_fault+0x230/0x468 [ 1177.985472] do_translation_fault+0x2c/0x40 [ 1177.989653] do_mem_abort+0x4c/0xf8 [ 1177.993136] el0_da+0x1c/0x20 [ 1177.996105] Code: 54000081 f9400bf3 a8c27bfd d65f03c0 (d4210000) [ 1178.002190] ---[ end trace 4ac3784c65534562 ]--- [ 1178.016992] Kernel panic - not syncing: Fatal exception [ 1178.022214] SMP: stopping secondary CPUs [ 1179.192799] SMP: failed to stop secondary CPUs 0,2-4 [ 1179.197763] CRU: [ 1179.199604] 00000000: 0000003f 00001101 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.208122] 00000020: 0000003b 00001101 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.216641] 00000040: 00000034 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.225159] 00000060: 000000c0 00001302 8000031f 00000008 00000007 00007f00 00000000 00000000 [ 1179.233677] 00000080: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.242194] 000000a0: 000000fa 00001206 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.250712] 000000c0: 00000129 00001608 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.259230] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.267748] 00000100: 00000100 00000707 00000140 00006606 00000045 00008580 00008320 00000141 [ 1179.276266] 00000120: 00000142 00004242 00000141 00000141 00004141 00008343 00003185 00000477 [ 1179.284784] 00000140: 00000102 00000300 00004a87 0000032f 00008381 00008387 00001103 00005282 [ 1179.293301] 00000160: 00008247 00000187 00001784 0000001f 00000300 00000300 00000180 00000000 [ 1179.301819] 00000180: 0000e380 00000200 00000200 00000200 00000200 00000200 00003f3f 00000042 [ 1179.310336] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000004 00000381 [ 1179.318854] 000001c0: 00000381 00000000 00000103 00000087 00000087 00000141 00000141 00008181 [ 1179.327372] 000001e0: 00008323 00000007 00008f1f 00008f8f 00008f8f 00008783 00008787 00008787 [ 1179.335889] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.344407] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.352925] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.361443] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.369961] 00000280: 0bb8ea60 0bb8ea60 01b97a12 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 [ 1179.378480] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000 [ 1179.386998] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.395515] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.404033] 00000300: 00000080 00000080 00000402 0000006f 00000c30 000001c0 00000019 000001c0 [ 1179.412550] 00000320: 0000fff8 0000f0ff 0000e0ff 0000c130 00000040 0000e203 00000000 00000000 [ 1179.421068] 00000340: 00000505 00000505 00000000 00000000 00000200 0000000f 0000cfeb 00003f00 [ 1179.429585] 00000360: 0000ef60 00000020 00000ffe 000001f0 000000c0 00000f86 00000d08 00000180 [ 1179.438104] 00000380: 00002010 00000000 0000003b 00000000 00000000 00000000 00000000 00000000 [ 1179.446621] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.455139] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.463656] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.472174] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.480692] 00000420: 00000000 00004040 00000000 00000014 00000000 00000000 00000000 00000000 [ 1179.489209] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.497727] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.506245] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.514763] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.523281] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.531799] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.540317] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000 [ 1179.548835] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.557352] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.565870] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.574386] 00000580: 00000004 0000089a 00000002 00000000 00000004 [ 1179.580554] PMU CRU: [ 1179.582741] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.591261] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.599780] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.608290] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.616810] 00000080: 0000060d 00001986 00000303 00000003 000002dc 00000200 0bb8ea60 00010014 [ 1179.625329] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.633848] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.642368] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.650887] 00000100: 00000bfc 0000fa80 0000000f 00000000 00000024 00000000 00000000 00000000 [ 1179.659404] 00000120: 00000000 00000000 00000000 00000000 00000003 [ 1179.665573] PMU: [ 1179.667412] 00000000: 00000000 00000000 00000000 00000000 00000000 80cf0000 80cf0000 00000000 [ 1179.675932] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.684451] 00000040: 00000000 00000000 00000000 00000000 00000000 cacf833f 00000000 00000000 [ 1179.692971] 00000060: 20000778 20000778 20000778 00000010 00000000 00007e00 00000000 28800000 [ 1179.701491] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0000000f 00000018 [ 1179.710010] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 00005dc0 00005dc0 [ 1179.718529] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3fffffff 00000000 [ 1179.727048] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.735563] Kernel Offset: disabled [ 1179.739047] CPU features: 0x00000000,2000600c [ 1179.743397] Memory Limit: none [ 1179.746460] rockchip-thermal ff260000.tsadc: channal 0: temperature(43 C) [ 1179.753240] THERMAL REGS: [ 1179.755861] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000 [ 1179.764379] 00000020: 0000022a 00000222 00000000 00000000 0000024e 00000000 00000000 00000000 [ 1179.772898] 00000040: 000002a5 000002a5 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.781416] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000 [ 1179.789931] 00000080: 00000000 00000000 [ 1179.804451] Rebooting in 5 seconds.. [ 1184.808679] sched: RT throttling activated [ 1184.812851] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 Share this post Link to post Share on other sites
tooz 53 Posted November 7, 2022 5 hours ago, 김용래 said: I got the log when booting and the log when the board stopped. When the board stopped, all I did was connect the Desktop and Tinker Board with a USB cable. 1. Log at boot time DDR Version 1.26 20210628 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 644 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=61056MB FwPartOffset=2000 , 0 StorageInit ok = 292645 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT part: 0, name: security, start:0x4000, size:0x2000 GPT part: 1, name: uboot, start:0x6000, size:0x2000 GPT part: 2, name: trust, start:0x8000, size:0x2000 GPT part: 3, name: misc, start:0xa000, size:0x2000 GPT part: 4, name: dtbo, start:0xc000, size:0x2000 GPT part: 5, name: vbmeta, start:0xe000, size:0x800 GPT part: 6, name: boot, start:0xe800, size:0x14000 GPT part: 7, name: recovery, start:0x22800, size:0x30000 GPT part: 8, name: backup, start:0x52800, size:0xc0000 GPT part: 9, name: cache, start:0x112800, size:0xc0000 GPT part: 10, name: metadata, start:0x1d2800, size:0x8000 GPT part: 11, name: baseparameter, start:0x1da800, size:0x800 GPT part: 12, name: splash, start:0x1db000, size:0x8000 GPT part: 13, name: dtoverlay, start:0x1e3000, size:0x8000 GPT part: 14, name: super, start:0x1eb000, size:0x614000 GPT part: 15, name: userdata, start:0x7ff000, size:0x6f40fdf find part:uboot OK. first_lba:0x6000. find part:trust OK. first_lba:0x8000. Trust Addr:0x8000, 0x58334c42 No find bl30.bin Load uboot, ReadLba = 6000 Load OK, addr=0x200000, size=0x10e2a0 RunBL31 0x40000 @ 592488 us NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a ) INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2 INF [0x0] TEE-CORE:init_teecore:83: teecore inits done INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09 #android (May 03 2022 - 02:32:32 +0000) Model: Rockchip RK3399 Evaluation Board PreSerial: 2, raw, 0xff1a0000 DRAM: 3.8 GiB Sysmem: init Relocation Offset: f5b6d000 Relocation fdt: f3d612c8 - f3d63ce3 CR: M/C/I Using default environment DM: v1 Set GPIO2_A4 (MASK_RELEASE) output high no mmc device at slot 1 Found IDB in SDcard found super part. dwmmc@fe320000: 1 (SD), sdhci@fe330000: 0 Bootdev(atags): mmc 1 MMC1: Legacy, 52Mhz PartType: EFI boot mode: None Flash bootloader message to normal! Android 11.0, Build 2021.8, v2 Found DTB in boot part DTB: rk-kernel.dtb HASH(c): OK ANDROID: fdt overlay OK I2c0 speed: 400000Hz PMIC: RK808 vdd_center 900000 uV vdd_cpu_l 900000 uV vdd_log 1100000 uV rockchip_display_probe load_sn65dsi8x_driver: sn65dsi84@2c load_sn65dsi8x_driver: sn65dsi84@2c : ret=-19 load_sn65dsi8x_driver: sn65dsi86@2d load_sn65dsi8x_driver: sn65dsi86@2d : ret=-19 sn65dsi84_is_connected sn65dsi84 connect = 0 rockchip_display_probe: panel_i2c_busnum = 8 sn65dsi84_is_connected sn65dsi84 connect = 0 I2c8 speed: 100000Hz panel_i2c_reg_read fail, i = 0 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 1 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 2 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 3 reg = 80 ret = -121 panel_i2c_reg_read fail, i = 0 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 1 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 2 reg = 4 ret = -121 panel_i2c_reg_read fail, i = 3 reg = 4 ret = -121 rockchip_display_probe rpi_buffer=-121 powertip_buffer=-121 sn65dsi84_is_connected sn65dsi84 connect = 0 rockchip_display_probe: no dsi panel and no sn65dsi8x connected warning: bad baseparameter Model: ASUS Tinker Board 2/2S read_bmp_header:BMP singature incorrectly 0x0 0x0load_bmp_logo 42 4d bit_count0 Rockchip UBOOT DRM driver version: v1.0.1 xfer: num: 2, addr: 0x50 xfer: num: 2, addr: 0x50 Monitor has basic audio support hdmi info isn't saved in main block mode:1920x1080 hdmi@ff940000: detailed mode clock 148500 kHz, flags[5] H: 1920 2008 2052 2200 V: 1080 1084 1089 1125 bus_format: 2025 CEA mode used vic=16 final pixclk = 148500000 tmdsclk = 148500000 PHY powered down in 0 iterations PHY PLL locked 1 iterations PHY powered down in 0 iterations PHY PLL locked 1 iterations sink has audio support hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500 CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A) CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A) aplll 816000 KHz apllb 816000 KHz dpll 856000 KHz cpll 24000 KHz gpll 800000 KHz npll 600000 KHz vpll 148000 KHz aclk_perihp 133333 KHz hclk_perihp 66666 KHz pclk_perihp 33333 KHz aclk_perilp0 266666 KHz hclk_perilp0 88888 KHz pclk_perilp0 44444 KHz hclk_perilp1 100000 KHz pclk_perilp1 50000 KHz Net: rk3399_gmac_set_clk: internal clock is UNIMPLEMENTED No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 ANDROID: reboot reason: "(none)" optee api revision: 2.0 Vboot=0, AVB images, AVB verify read_is_device_unlocked() ops returned that device is UNLOCKED avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGND get image from preloaded partition... reading cmdline.txt 58 bytes read in 3 ms (18.6 KiB/s) cmdline.txt size = 58 cmdline.txt valid = 1 reading config.txt 1735 bytes read in 3 ms (564.5 KiB/s) config.txt size = 1735 [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line [conf] hw_parse_property: illegal line config.txt valid = 1 config on: 1, config off: -1, no config: 0 intf.fiq_debugger = 1 intf.i2c6 = 0 intf.i2c7 = 0 intf.uart0 = 0 intf.uart4 = 0 intf.i2s0 = 0 intf.spi1 = 0 intf.spi5 = 0 intf.pwm0 = 0 intf.pwm1 = 0 intf.pwm3a = 0 intf.spdif = 1 intf.test_clkout2 = 0 conf.gmac = 1 conf.ums = 1 fdt magic number edfe0dd0 fdt size 1048576 set_hw_property: /fiq-debugger status okay set_hw_property: /spdif@ff870000 status okay flash_device_node: /pinctrl/testclk/test-clkout2 rockchip,pins set_hw_property: /ethernet@fe300000 wakeup-enable 1 Could not find "system" partition Booting IMAGE kernel at 0x00280000 with fdt at 0x08300000... Fdt Ramdisk skip relocation ## Booting Android Image at 0x0027f800 ... Kernel: 0x00280000 - 0x0208b810 (30767 KiB) ramdisk: 0x0a200000 - 0x0a2ccd63 (820 KiB) ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 XIP Kernel Image from 0x00280000 to 0x00280000 ... OK kernel loaded at 0x00280000, end = 0x0208b810 'reserved-memory' ramoops@110000: addr=110000 size=f0000 Using Device Tree in place at 0000000008300000, end 0000000008402fff read_bmp_header:BMP singature incorrectly 0x0 0x0load_bmp_logo 42 4d bit_count0 failed to reserve drm-cubic-lut memory Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000) Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000) Total: 2724.990 ms ----------------------------------------------------------------------------------------------------------------------------- 2. Log when the board stops [ 1166.082944] phy phy-ff770000.syscon:usb2-phy@e450.10: charger = USB_SDP_CHARGER [ 1166.114491] fusb302 4-0022: CC connected in CC2 as UFP [ 1166.132832] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 1166.379861] dwc3 fe800000.dwc3: device reset [ 1166.511629] dwc3 fe800000.dwc3: device reset [ 1166.511764] android_work: did not send uevent (0 0 (null)) [ 1166.658402] android_work: sent uevent USB_STATE=CONNECTED [ 1166.658719] configfs-gadget gadget: high-speed config #1: b [ 1166.659735] android_work: sent uevent USB_STATE=CONFIGURED [ 1166.745781] type=1400 audit(1651547343.230:103): avc: denied { read } for comm="memtrack@1.0-se" name="mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memtrack_default:s0 tcontext=u:object_r:de1 [ 1166.746067] type=1400 audit(1651547343.230:104): avc: denied { open } for comm="memtrack@1.0-se" path="/sys/kernel/debug/mali0/ctx/1964_8/mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memtrac1 [ 1166.746188] type=1400 audit(1651547343.230:105): avc: denied { getattr } for comm="memtrack@1.0-se" path="/sys/kernel/debug/mali0/ctx/1964_8/mem_profile" dev="debugfs" ino=61619 scontext=u:r:hal_memt1 [ 1167.255438] dwmmc_rockchip fe320000.dwmmc: Unexpected interrupt latency [ 1168.008852] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1168.355529] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1169.022183] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1169.368843] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1170.035529] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1170.382174] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1171.048849] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1171.048937] cpu cpu4: _set_opp_voltage: failed to set voltage (825000 825000 1250000 mV): -110 [ 1171.049048] cpufreq: __target_index: Failed to change cpu frequency: -110 [ 1171.395407] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1172.648740] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1173.662067] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1174.675405] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1175.688736] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1176.702075] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 [ 1176.919600] ------------[ cut here ]------------ [ 1176.919629] kernel BUG at arch/arm64/kernel/traps.c:416! [ 1176.919639] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP [ 1176.934998] Modules linked in: 8822ce [ 1176.938666] Process ranker (pid: 550, stack limit = 0x00000000f32b6def) [ 1176.945272] CPU: 4 PID: 550 Comm: ranker Not tainted 4.19.219 #3 [ 1176.951272] Hardware name: ASUS Tinker Board 2/2S (DT) [ 1176.956406] pstate: 00400005 (nzcv daif +PAN -UAO) [ 1176.961197] pc : do_undefinstr+0x4c/0x50 [ 1176.965115] lr : do_undefinstr+0x34/0x50 [ 1176.969032] sp : ffffff8010de3b60 [ 1176.972345] x29: ffffff8010de3b60 x28: ffffffc0d734ab80 [ 1176.977648] x27: 0000000000000002 x26: 0000000013940000 [ 1176.982951] x25: ffffffc0e5ff2a60 x24: 0000000000000000 [ 1176.988253] x23: 0000000020400005 x22: ffffff80082236bc [ 1176.993555] x21: 000000000217d000 x20: 0000007fffffffff [ 1176.998857] x19: ffffff8010de3b80 x18: 0000000000000000 [ 1177.004159] x17: 0000000000000000 x16: 0000000000000000 [ 1177.009461] x15: ffffff80082236bc x14: 0000000000000000 [ 1177.014762] x13: 0000000000000000 x12: 0000000000000002 [ 1177.020064] x11: 0000000000000000 x10: ffffff80099c3018 [ 1177.025366] x9 : 8cc1380e76654f00 x8 : 0000000000000005 [ 1177.030669] x7 : 0000000000000000 x6 : ffffff8010de3b18 [ 1177.035971] x5 : ffffff8010de3b18 x4 : ffffffc0f6f421d0 [ 1177.041273] x3 : 0000000000000001 x2 : 0000000000000001 [ 1177.046575] x1 : 0000000000000000 x0 : 0000000000000000 [ 1177.051878] [ 1177.051878] PC: 0xffffff80080807cc: [ 1177.056841] 07cc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.065016] 07ec 00000000 00000000 00000000 00000000 00000000 a9be7bfd f9000bf3 910003fd [ 1177.073191] 080c aa0003f3 9400127b 34000160 aa1303e0 940040ac 34000100 f9408262 52800080 [ 1177.081366] 082c 52800021 9400403b 39442268 72000d1f 54000081 f9400bf3 a8c27bfd d65f03c0 [ 1177.089541] 084c d4210000 a9be7bfd f9000bf3 910003fd 529f8028 72a007e8 529b800a 0a080009 [ 1177.097715] 086c 72a0024a 6b0a013f aa0103f3 54000101 b0000088 91193108 aa1303e1 d63f0100 [ 1177.105890] 088c f9400bf3 a8c27bfd d65f03c0 11007908 529f0029 0a080008 72a00609 6b09011f [ 1177.114065] 08ac 540001e0 52980029 72a00649 6b09011f 54000100 529f0029 72a00689 6b09011f [ 1177.122241] [ 1177.122241] LR: 0xffffff80080807b4: [ 1177.127203] 07b4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.135378] 07d4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.143552] 07f4 00000000 00000000 00000000 a9be7bfd f9000bf3 910003fd aa0003f3 9400127b [ 1177.151727] 0814 34000160 aa1303e0 940040ac 34000100 f9408262 52800080 52800021 9400403b [ 1177.159901] 0834 39442268 72000d1f 54000081 f9400bf3 a8c27bfd d65f03c0 d4210000 a9be7bfd [ 1177.168076] 0854 f9000bf3 910003fd 529f8028 72a007e8 529b800a 0a080009 72a0024a 6b0a013f [ 1177.176251] 0874 aa0103f3 54000101 b0000088 91193108 aa1303e1 d63f0100 f9400bf3 a8c27bfd [ 1177.184425] 0894 d65f03c0 11007908 529f0029 0a080008 72a00609 6b09011f 540001e0 52980029 [ 1177.192601] [ 1177.192601] SP: 0xffffff8010de3ae0: [ 1177.197563] 3ae0 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 00000002 00000000 [ 1177.205738] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.213914] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.222088] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.230263] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.238437] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.246612] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.254786] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.262962] [ 1177.262962] X4: 0xffffffc0f6f42150: [ 1177.267925] 2150 b05834c8 ffffffc0 0001af34 00000000 02c160c0 ffffffbf 00000000 00000000 [ 1177.276100] 2170 8f0af900 ffffffc0 0000250c 00000000 023c2b00 ffffffbf 0275d600 ffffffbf [ 1177.284275] 2190 ee181a40 ffffffc0 0000005c 00000000 03b86000 ffffffbf 00000000 00000000 [ 1177.292449] 21b0 00000000 00000000 00000000 00000000 00000000 0000000e 00000000 00000000 [ 1177.300623] 21d0 edb43dc0 ffffffc0 0000032c 00000000 03b6d0c0 ffffffbf 00000000 00000000 [ 1177.308798] 21f0 9f2f1490 ffffffc0 00005d9c 00000000 027cbc00 ffffffbf 00000000 00000000 [ 1177.316972] 2210 ef65e000 ffffffc0 000000f4 00000000 03bd9780 ffffffbf 00000000 00000000 [ 1177.325147] 2230 e5716f00 ffffffc0 000014c4 00000000 0395c580 ffffffbf 00000000 00000000 [ 1177.333323] [ 1177.333323] X5: 0xffffff8010de3a98: [ 1177.338285] 3a98 082236bc ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.346460] 3ab8 10de3b80 ffffff80 ffffffff 0000007f 0217d000 00000000 082236bc ffffff80 [ 1177.354635] 3ad8 20400005 00000000 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 [ 1177.362809] 3af8 00000002 00000000 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 [ 1177.370984] 3b18 10de3b60 ffffff80 0808084c ffffff80 00400005 00000000 00000000 00000000 [ 1177.379159] 3b38 20400005 00000000 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 [ 1177.387334] 3b58 0808084c ffffff80 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 [ 1177.395508] 3b78 080f8998 ffffff80 00000000 00000000 13940000 00000000 00000001 00000000 [ 1177.403683] [ 1177.403683] X6: 0xffffff8010de3a98: [ 1177.408646] 3a98 082236bc ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.416820] 3ab8 10de3b80 ffffff80 ffffffff 0000007f 0217d000 00000000 082236bc ffffff80 [ 1177.424996] 3ad8 20400005 00000000 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 [ 1177.433170] 3af8 00000002 00000000 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 [ 1177.441345] 3b18 10de3b60 ffffff80 0808084c ffffff80 00400005 00000000 00000000 00000000 [ 1177.449519] 3b38 20400005 00000000 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 [ 1177.457694] 3b58 0808084c ffffff80 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 [ 1177.465869] 3b78 080f8998 ffffff80 00000000 00000000 13940000 00000000 00000001 00000000 [ 1177.474044] [ 1177.474044] X10: 0xffffff80099c2f98: [ 1177.479091] 2f98 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.487280] 2fb8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.495464] 2fd8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.503648] 2ff8 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.511832] 3018 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.520016] 3038 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.528201] 3058 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.536384] 3078 ******** ******** ******** ******** ******** ******** ******** ******** [ 1177.544570] [ 1177.544570] X15: 0xffffff800822363c: [ 1177.549617] 363c 1100052a 7100115f 1a8907e9 8b294d0a f9420140 b40000e0 f940000a eb01015f [ 1177.557792] 365c 54000088 f940040a eb01015f 540002a8 1100052a 7100115f 1a8907e9 8b294d08 [ 1177.565966] 367c f9420100 b40000e0 f9400008 eb01011f 54000088 f9400408 eb01011f 54000128 [ 1177.574140] 369c aa1f03e0 d65f03c0 aa1f03e0 f9027d09 f902011f f902851f f902891f f9028d1f [ 1177.582316] 36bc d65f83c0 a9bf7bfd 910003fd a9402009 f9404c0a f940002d cb090108 8b483148 [ 1177.590490] 36dc d1000508 b400028d 52800022 5280018b 14000008 f9404d8d eb0d015f 9a8b256e [ 1177.598665] 36fc f86e798d 1a9f27ef 0a0f0042 b400010d f9400dac aa0d03e9 eb08019f d10161ac [ 1177.606839] 371c 54fffea2 f9003988 17fffff3 8b0e0d8a 14000004 aa1f03e9 52800022 aa0103ea [ 1177.615015] [ 1177.615015] X19: 0xffffff8010de3b00: [ 1177.620063] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.628237] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.636412] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.644586] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.652760] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.660935] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.669109] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.677284] 3be0 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.685459] [ 1177.685459] X22: 0xffffff800822363c: [ 1177.690506] 363c 1100052a 7100115f 1a8907e9 8b294d0a f9420140 b40000e0 f940000a eb01015f [ 1177.698680] 365c 54000088 f940040a eb01015f 540002a8 1100052a 7100115f 1a8907e9 8b294d08 [ 1177.706855] 367c f9420100 b40000e0 f9400008 eb01011f 54000088 f9400408 eb01011f 54000128 [ 1177.715030] 369c aa1f03e0 d65f03c0 aa1f03e0 f9027d09 f902011f f902851f f902891f f9028d1f [ 1177.723205] 36bc d65f83c0 a9bf7bfd 910003fd a9402009 f9404c0a f940002d cb090108 8b483148 [ 1177.731380] 36dc d1000508 b400028d 52800022 5280018b 14000008 f9404d8d eb0d015f 9a8b256e [ 1177.739554] 36fc f86e798d 1a9f27ef 0a0f0042 b400010d f9400dac aa0d03e9 eb08019f d10161ac [ 1177.747729] 371c 54fffea2 f9003988 17fffff3 8b0e0d8a 14000004 aa1f03e9 52800022 aa0103ea [ 1177.755904] [ 1177.755904] X25: 0xffffffc0e5ff29e0: [ 1177.760951] 29e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.769126] 2a00 d42f31b0 ffffffc0 d42bd2a8 ffffffc0 0000119f 00000000 082317ec ffffff80 [ 1177.777301] 2a20 df07b000 0000007a 00000000 00000000 00000000 00000080 d139c000 0000007f [ 1177.785475] 2a40 d4bad000 ffffffc0 0000008c 00000004 00207000 00000000 00000e85 00000000 [ 1177.793650] 2a60 00000001 00000000 e5ff2a68 ffffffc0 e5ff2a68 ffffffc0 00000000 00000000 [ 1177.801825] 2a80 00000001 00000000 00000000 00000000 e5ff2a90 ffffffc0 e5ff2a90 ffffffc0 [ 1177.809999] 2aa0 0001a117 00000000 00411785 00000000 0040dd84 00000000 00005e7d 00000000 [ 1177.818174] 2ac0 00000000 00000000 0007472e 00000000 0000af1a 00000000 00000800 00000000 [ 1177.826350] [ 1177.826350] X28: 0xffffffc0d734ab00: [ 1177.831397] ab00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.839571] ab20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.847746] ab40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.855920] ab60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.864094] ab80 04000023 00000000 ffffffff ffffffff d4bad000 01ca0000 00000001 00000000 [ 1177.872269] aba0 00000000 00000000 10de0000 ffffff80 00000002 00404040 00000000 00000000 [ 1177.880444] abc0 00000000 00000000 00000001 00000004 00000050 00000000 00040379 00000001 [ 1177.888618] abe0 f15f5700 ffffffc0 00000005 00000004 00000001 00000082 00000082 00000082 [ 1177.896793] [ 1177.896793] X29: 0xffffff8010de3ae0: [ 1177.901840] 3ae0 00000000 00000000 e5ff2a60 ffffffc0 13940000 00000000 00000002 00000000 [ 1177.910015] 3b00 d734ab80 ffffffc0 10de3b60 ffffff80 08080834 ffffff80 10de3b60 ffffff80 [ 1177.918190] 3b20 0808084c ffffff80 00400005 00000000 00000000 00000000 20400005 00000000 [ 1177.926364] 3b40 ffffffff 0000007f 0217d000 00000000 10de3b60 ffffff80 0808084c ffffff80 [ 1177.934539] 3b60 10de3cb0 ffffff80 08082c84 ffffff80 13940000 00000000 080f8998 ffffff80 [ 1177.942714] 3b80 00000000 00000000 13940000 00000000 00000001 00000000 00000000 00000000 [ 1177.950889] 3ba0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1177.959063] 3bc0 d734ab80 ffffffc0 0000119f 00000000 00000a76 00000000 fffff000 00000000 [ 1177.967238] [ 1177.968733] Call trace: [ 1177.971181] do_undefinstr+0x4c/0x50 [ 1177.974750] el1_undef+0x10/0xa8 [ 1177.977983] vmacache_find+0x100/0x104 [ 1177.981724] do_page_fault+0x230/0x468 [ 1177.985472] do_translation_fault+0x2c/0x40 [ 1177.989653] do_mem_abort+0x4c/0xf8 [ 1177.993136] el0_da+0x1c/0x20 [ 1177.996105] Code: 54000081 f9400bf3 a8c27bfd d65f03c0 (d4210000) [ 1178.002190] ---[ end trace 4ac3784c65534562 ]--- [ 1178.016992] Kernel panic - not syncing: Fatal exception [ 1178.022214] SMP: stopping secondary CPUs [ 1179.192799] SMP: failed to stop secondary CPUs 0,2-4 [ 1179.197763] CRU: [ 1179.199604] 00000000: 0000003f 00001101 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.208122] 00000020: 0000003b 00001101 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.216641] 00000040: 00000034 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.225159] 00000060: 000000c0 00001302 8000031f 00000008 00000007 00007f00 00000000 00000000 [ 1179.233677] 00000080: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.242194] 000000a0: 000000fa 00001206 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.250712] 000000c0: 00000129 00001608 8000031f 00000108 00000007 00007f00 00000000 00000000 [ 1179.259230] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.267748] 00000100: 00000100 00000707 00000140 00006606 00000045 00008580 00008320 00000141 [ 1179.276266] 00000120: 00000142 00004242 00000141 00000141 00004141 00008343 00003185 00000477 [ 1179.284784] 00000140: 00000102 00000300 00004a87 0000032f 00008381 00008387 00001103 00005282 [ 1179.293301] 00000160: 00008247 00000187 00001784 0000001f 00000300 00000300 00000180 00000000 [ 1179.301819] 00000180: 0000e380 00000200 00000200 00000200 00000200 00000200 00003f3f 00000042 [ 1179.310336] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000004 00000381 [ 1179.318854] 000001c0: 00000381 00000000 00000103 00000087 00000087 00000141 00000141 00008181 [ 1179.327372] 000001e0: 00008323 00000007 00008f1f 00008f8f 00008f8f 00008783 00008787 00008787 [ 1179.335889] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.344407] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.352925] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.361443] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.369961] 00000280: 0bb8ea60 0bb8ea60 01b97a12 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 [ 1179.378480] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000 [ 1179.386998] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.395515] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.404033] 00000300: 00000080 00000080 00000402 0000006f 00000c30 000001c0 00000019 000001c0 [ 1179.412550] 00000320: 0000fff8 0000f0ff 0000e0ff 0000c130 00000040 0000e203 00000000 00000000 [ 1179.421068] 00000340: 00000505 00000505 00000000 00000000 00000200 0000000f 0000cfeb 00003f00 [ 1179.429585] 00000360: 0000ef60 00000020 00000ffe 000001f0 000000c0 00000f86 00000d08 00000180 [ 1179.438104] 00000380: 00002010 00000000 0000003b 00000000 00000000 00000000 00000000 00000000 [ 1179.446621] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.455139] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.463656] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.472174] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.480692] 00000420: 00000000 00004040 00000000 00000014 00000000 00000000 00000000 00000000 [ 1179.489209] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.497727] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.506245] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.514763] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.523281] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.531799] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.540317] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000 [ 1179.548835] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.557352] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.565870] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.574386] 00000580: 00000004 0000089a 00000002 00000000 00000004 [ 1179.580554] PMU CRU: [ 1179.582741] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000 [ 1179.591261] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.599780] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.608290] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.616810] 00000080: 0000060d 00001986 00000303 00000003 000002dc 00000200 0bb8ea60 00010014 [ 1179.625329] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.633848] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.642368] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.650887] 00000100: 00000bfc 0000fa80 0000000f 00000000 00000024 00000000 00000000 00000000 [ 1179.659404] 00000120: 00000000 00000000 00000000 00000000 00000003 [ 1179.665573] PMU: [ 1179.667412] 00000000: 00000000 00000000 00000000 00000000 00000000 80cf0000 80cf0000 00000000 [ 1179.675932] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.684451] 00000040: 00000000 00000000 00000000 00000000 00000000 cacf833f 00000000 00000000 [ 1179.692971] 00000060: 20000778 20000778 20000778 00000010 00000000 00007e00 00000000 28800000 [ 1179.701491] 00000080: 000003c0 00011940 00005dc0 000003c0 00005dc0 00000060 0000000f 00000018 [ 1179.710010] 000000a0: 00000018 00000018 00000018 00000006 00000006 00005dc0 00005dc0 00005dc0 [ 1179.718529] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 3fffffff 00000000 [ 1179.727048] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.735563] Kernel Offset: disabled [ 1179.739047] CPU features: 0x00000000,2000600c [ 1179.743397] Memory Limit: none [ 1179.746460] rockchip-thermal ff260000.tsadc: channal 0: temperature(43 C) [ 1179.753240] THERMAL REGS: [ 1179.755861] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000 [ 1179.764379] 00000020: 0000022a 00000222 00000000 00000000 0000024e 00000000 00000000 00000000 [ 1179.772898] 00000040: 000002a5 000002a5 00000000 00000000 00000000 00000000 00000000 00000000 [ 1179.781416] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000 [ 1179.789931] 00000080: 00000000 00000000 [ 1179.804451] Rebooting in 5 seconds.. [ 1184.808679] sched: RT throttling activated [ 1184.812851] rk3x-i2c ff3d0000.i2c: timeout, ipd: 0x1b, state: 1 from the logs i'd suggest to keep the cpu freq at maximum, using adb commands below: adb root adb shell "echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor" adb shell "echo performance > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor" Share this post Link to post Share on other sites
manaasch 0 Posted May 30, 2023 김용래 I've got the similar problem as you. In my case after plugged power supply there is nothing happen only red light is turn on . If I unplug and wait for 5-10 minutes then plug again, it is randomly able to boot (not every time). I'm pretty sure that my power supply is good enough. Do you find solution for this problem? or anybody come across this problem please let me know. Thank you in advance. Share this post Link to post Share on other sites
tooz 53 Posted May 31, 2023 hello @manaasch, have you tried using a newer os? does this persist in every version of the os you're using? Share this post Link to post Share on other sites
manaasch 0 Posted June 2, 2023 Hello tooz, I return my TB 2S to distributor for check. Not yet receive any information. I just wondering, it is not completely out of work. It is something like there are some period of time before it can boot again. As discuss with distributor it's abnormal. Share this post Link to post Share on other sites
roro 0 Posted June 14, 2023 Can someone solve the problem? I have the same problem and I am using the board for my degree work .I have to hand in in a few weeks :c help! Share this post Link to post Share on other sites
tooz 53 Posted June 16, 2023 hello @manaasch and @roro, please try using the latest android 11 os v.2.0.14: Tinker Board 2 Android 11 V2.0.14 Share this post Link to post Share on other sites
