Jay 0 Posted November 7, 2022 (edited) I have switched to wireless connection and every time I log in I have to disconnect the wired connection 1. How can I prevent the wired connect from trying to connect at boot time so I don't have to disconnect it manually? Is there a config file I can edit to permanently disconnect it and then I can edit it later if I want to use wireless again later. I'm using Tinkerboard2 OS. Edited November 7, 2022 by Jay Share this post Link to post Share on other sites
tooz 56 Posted November 11, 2022 hello @Jay, you can edit the rc.local in /etc/ this is the script auto executed when booting. please add the following line in the file: sudo ifconfig eth0 down (save the modifed local.rc, and then reboot) remove this line if you'd like to use wired connection. alternatively, sudo ifconfig eth0 down can be added in /etc/init.d/rockchp.sh --it does the same job Share this post Link to post Share on other sites
