hoser 0 Posted December 6, 2022 Hi I am running Ubuntu (see below) and want to upgrade my micro SD card from a 32GB to a 64GB How can I clone my 32GB card over to the 64GB card? I want to upgrade to the newer OS after the clone. Thanks in advance. ELAR-Systems:~$ inxi -Fxxxrz System: Host: ELAR-Systems Kernel: 4.4.103-ELAR-Systems armv7l bits: 32 gcc: 4.9.4 Desktop: Xfce 4.12.3 (Gtk 2.24.31) info: xfce4-panel dm: lightdm Distro: Ubuntu 18.04.6 LTS Machine: No /sys/class/dmi; using dmidecode: no smbios data. Old system? CPU: Quad core ARMv7 rev 1 (v7l) (-MCP-) bmips: 576 arch: ARM clock speeds: min/max: 126/1800 MHz 1: 1800 MHz 2: 1800 MHz 3: 1800 MHz 4: 1800 MHz Graphics: Card: Failed to Detect Video Card! Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev) Resolution: 1440x900@59.89hz Share this post Link to post Share on other sites
Ming-Ta Yu 0 Posted December 6, 2022 Generally, you can use tool such as balenaEtcher to clone the SD card from a 32 GB one to a 64 GB one. Then, you need to resize the rootfs partition to fill the rest of the 32G space. Share this post Link to post Share on other sites
hoser 0 Posted December 6, 2022 I went to their website and looked at their forums it seems balenaEtcher is a nightmare of problems, I rather not risk data loss using a product hat appears to have a high failure rate. You know of any other methods ? https://forums.balena.io/c/etcher/32 Thanks. Share this post Link to post Share on other sites
tooz 55 Posted December 6, 2022 hello @hoser, win32 disk imager is the other alternative Share this post Link to post Share on other sites
Ming-Ta Yu 0 Posted December 7, 2022 You can also use Linux dd command to do this. Share this post Link to post Share on other sites
bARTi4 0 Posted December 13, 2022 useful information Share this post Link to post Share on other sites
