Thinh Nguyen 0 Posted January 12, 2023 I have a Tinker board 2S and I would like to control USB 3.0 VBUS to turn on/off devices that connected to USB port. Does this board support controlling USB Power? I also look at schemtic, please look at the picture below (Attached) Can USB3_EN be control by software? Share this post Link to post Share on other sites
nishi 0 Posted July 9, 2023 Hello, I've come across this thread and realized that the original question hasn't been answered yet. I am also interested in this topic, and I'm wondering if anyone could provide some insights or experiences related to this. Thank you in advance for any help you can provide. Share this post Link to post Share on other sites
tooz 56 Posted July 10, 2023 (edited) hello @nishi and @Thinh Nguyen, you can control the vbus power through echo commands 1. check the kernel version with command: uname -a keep in mind that if you're using a usb keyboard, the power will be off immediately after you execute the echo off command. if you wish to turn it back on without reboot, please: 1. use a type c keyboard, or 2. connect tinker board to a pc with a ttys dongle so the commands can be executed from the putty console here are the commands to control the vbus power: linux4.4 debian10 (v.2.0.20 2023/07/13 and later): TypeA port: echo on > /sys/kernel/debug/fe900000.dwc3/vbus echo off > /sys/kernel/debug/fe900000.dwc3/vbus TypeC port: echo on > /sys/kernel/debug/fe800000.dwc3/vbus echo off > /sys/kernel/debug/fe800000.dwc3/vbus linux4.19 debian10 (v.2.1.16 2023/07/14 and later): TypeA port: echo on > /sys/kernel/debug/fe900000.dwc3/vbus echo off > /sys/kernel/debug/fe900000.dwc3/vbus TypeC port (for cc chip fusb302): echo on > /sys/kernel/debug/fe800000.dwc3/vbus echo off > /sys/kernel/debug/fe800000.dwc3/vbus TypeC port (for cc chip rt1715): echo sink >/sys/class/typec/port0/port_type echo dual >/sys/class/typec/port0/port_type linux5.10 debian11 (v.3.0.6 2023/07/31 and later): typeA port: echo on > /sys/kernel/debug/usb/fe900000.usb/hub_vbus echo off > /sys/kernel/debug/usb/fe900000.usb/hub_vbus TypeC port (both fusb302 & rt1715 use the same commands): echo sink >/sys/class/typec/port0/port_type echo dual >/sys/class/typec/port0/port_type android12 (v.3.0.2 2023/07/13 and later): typeA port: echo on > /sys/kernel/debug/fe900000.dwc3/hub_vbus echo off > /sys/kernel/debug/fe900000.dwc3/hub_vbus typeC port (for cc chip fusb302): echo on > /sys/kernel/debug/fe800000.dwc3/hub_vbus echo off > /sys/kernel/debug/fe800000.dwc3/hub_vbus TypeC port (for cc chip rt1715): echo sink >/sys/class/typec/port0/port_type echo dual >/sys/class/typec/port0/port_type Edited December 12, 2023 by tooz updated supported versions (with dates) 1 Share this post Link to post Share on other sites
nishi 0 Posted July 11, 2023 Thank you for your response! I was able to confirm the behavior as expected. Share this post Link to post Share on other sites
sonyan11 0 Posted December 12, 2023 @tooz Hello. I followed your instruction about usb-c. I use "linux4.4 debian10". echo on > /sys/kernel/debug/fe800000.dwc3/vbus echo off > /sys/kernel/debug/fe800000.dwc3/vbus The result is -bash: /sys/kernel/debug/fe800000.dwc3/vbus: Permission denied I cannot find vbus as follows. ~# ls /sys/kernel/debug/fe800000.dwc3/ ep0in ep1in ep2in ep3in ep4in ep5in ep6in mode testmode ep0out ep1out ep2out ep3out ep4out ep5out link_state regdump I would be grateful if you could help me. Share this post Link to post Share on other sites
tooz 56 Posted December 12, 2023 hello @sonyan11, 33 minutes ago, sonyan11 said: ~# ls /sys/kernel/debug/fe800000.dwc3/ ep0in ep1in ep2in ep3in ep4in ep5in ep6in mode testmode ep0out ep1out ep2out ep3out ep4out ep5out link_state regdump what's the image version you're using? if it's not on the list then the function might not have been added -- my bad. i have updated my previous post with versions that support usb vbus control. for debian 10 kernel 4.4, please use v.2.0.20 or later 1 Share this post Link to post Share on other sites
sonyan11 0 Posted December 13, 2023 Dear @tooz Thank you so much, I have updated kenel and have successfully control the vbus. I am super happy to get this result. I deeply appreciate your contribution to this forum. Best regards, Share this post Link to post Share on other sites
sonyan11 0 Posted September 11, 2025 Hello. Since Tinkerboard3 has been released, I've migrated my development environment to Tinker3. Can I still control USB power delivery with Tinker3? Best regards, Share this post Link to post Share on other sites
TzuWen_Chang 2 Posted September 11, 2025 hello @sonyan11 For TB3 use the following commands Reset usb 2.0 hub: echo 1 > /sys/kernel/debug/usb/fd800000.usb/hub_reset Power off and power on usb 2.0 hub device: echo off > /sys/kernel/debug/usb/fd800000.usb/hub_vbus echo on > /sys/kernel/debug/usb/fd800000.usb/hub_vbus Power off and power on usb 3.0 hub device: echo off > /sys/kernel/debug/usb/fd000000.dwc3/hub_vbus echo on > /sys/kernel/debug/usb/fd000000.dwc3/hub_vbus 1 Share this post Link to post Share on other sites
sonyan11 0 Posted September 12, 2025 @TzuWen_Chang Thank you so much for your response. It works! Thank you! Share this post Link to post Share on other sites
