jjj44 0 Posted March 29, 2023 I am currently attempting to use a TinkerBoard2S as a rosbag recorder for various sensors, and I am encountering a few issues. Here are my requirements: I need to install ROS on the TinkerBoard2S. I need to be able to read UART for IMU data. Initially, I attempted to install the complete ROS system via a simple deb installation, but I ran into issues because ROS does not support Debian10 well. I then tried to follow the instructions on this page (https://github.com/lawkee48/TinkerOS-ROS), which allowed me to run roscore, but I encountered a problem when trying to compile the PCL library for my Velodyne sensor, as it took too long. Next, I tried installing Ubuntu20 on the TinkerBoard2S, which made it easy to install the full ROS system. However, I am now unsure how to enable the UART port on the Ubuntu20 system. I know that for the TinkerBoard2S, I only need to set /boot/config.txt and set the intf:uart0=on. After rebooting, the ttyS0 should be mounted as the UART port. Any suggestions on how to proceed would be greatly appreciated. Thank you! Share this post Link to post Share on other sites
tooz 54 Posted April 6, 2023 hello @jjj44, here are the commands to install ros (ros-noetic-desktop) -- verified it can be installed in debian 10 v.2.1.6 / 2.0.14 wget http://ftp.us.debian.org/debian/pool/main/g/gmp/libgmp10_6.1.2+dfsg-4+deb10u1_arm64.deb wget http://ftp.us.debian.org/debian/pool/main/n/nettle/libhogweed4_3.4.1-1+deb10u1_arm64.deb wget http://ftp.us.debian.org/debian/pool/main/n/nettle/libnettle6_3.4.1-1+deb10u1_arm64.deb wget http://security.debian.org/debian-security/pool/updates/main/g/gnutls28/libgnutls30_3.6.7-4+deb10u10_arm64.deb sudo dpkg -i libgmp10_6.1.2+dfsg-4+deb10u1_arm64.deb sudo dpkg -i libhogweed4_3.4.1-1+deb10u1_arm64.deb sudo dpkg -i libnettle6_3.4.1-1+deb10u1_arm64.deb sudo dpkg -i libgnutls30_3.6.7-4+deb10u10_arm64.deb sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list' sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654 sudo apt update sudo apt install ros-noetic-desktop *notices like these are expected and can be ignored: ldconfig: file /usr/lib/mali/libmali.so is truncated ldconfig: file /usr/lib/mali/libmali.so.1.9.0 is truncated ldconfig: file /usr/lib/mali/libmali.so.1 is truncated ldconfig: file /usr/lib/mali/libmali-midgard-t86x-r18p0-x11.so is truncated ldconfig: file /usr/lib/libmali.so.1 is truncated Share this post Link to post Share on other sites
