sonyan11 0 Posted April 17, 2023 Hello. I use tinker board 2S. Previously, I received following advice about UVC Cam. Quote uvcvideo is compiled into the kernel, tasks that are module-related cannot be supported as uvcvideo by default is not part of the module. Now I tried to change uvc cam setting to module by following https://github.com/TinkerBoard/TinkerBoard/wiki/Developer-Guide. However, I cannot find uvc related topic at make menuconfig Please tell me the correct way to change .config in order to compiled uvcvideo driver to module. Best regards, Share this post Link to post Share on other sites
tooz 56 Posted April 18, 2023 hello @sonyan11, for uvc option, the config has to be set with the command below before make menuconfig tinker board linux 4.19: make ARCH=arm64 tinker_board_2_defconfig and then make menuconfig 1 Share this post Link to post Share on other sites
sonyan11 0 Posted April 24, 2023 Dear @tooz, Thank you very much for your comment. I apologize for not presenting my environment first. I use Kernel 4.4. I have done the followings and still the UVC is not recognized as a module. 1. Installing the build tools $ sudo apt-get install git-core gitk git-gui gcc-arm-linux-gnueabihf device-tree-compiler gcc-aarch64-linux-gnu mtools parted libssl-dev 2. Build Kernel $ cd [source code] $ make ARCH=arm64 tinker2_defconfig $ make menuconfig Modify USB Video Class to module. Device Drivers> Multimedia Support > Media USB Adapters > USB Video Class [*] → [M] $ make ARCH=arm64 rk3399-tinker_board_2.img CROSS_COMPILE=aarch64-linux-gnu- -j8 3. Install Kernel $ sudo dd if=boot.img of=/dev/mmcblk1p4 status=progress && sync $ sudo reboot Please let me know if I am missing a process that we need. Best regards, Share this post Link to post Share on other sites
tooz 56 Posted April 25, 2023 hello @sonyan11, i think you're able to modify uvcvideo driver to module mode through menuconfig, but tinker board 2s is not able to recognize the new module because the module driver is not updated to tinker board 2s. to update tinker board 2s' module driver, please execute these two commands in the kernel directory of the source code, make ARCH=arm64 modules make ARCH=arm64 modules_install INSTALL_MOD_PATH={INSTALL_PATH} and then update the \lib\modules\4.4.194\ kernel and \lib\modules\4.4.194\modules (of which from {INSTALL_PATH} ) onto tinker board 2s accordingly 1 Share this post Link to post Share on other sites
