giseleznev 0 Posted April 21, 2023 (edited) Hi, team, I want to connect tinker board 2 with dac PCM5102PW and also adc PCM1804DBR using i2s and i2c Is i2s and i2c interface supported currently? Can i use alsa over i2s out of the box? Or should I install any overlays? Thanks! Edited April 21, 2023 by giseleznev Share this post Link to post Share on other sites
tooz 56 Posted April 26, 2023 hello @giseleznev, PCM5102PW and PCM1804DBR are not supported at the moment Share this post Link to post Share on other sites
giseleznev 0 Posted May 10, 2023 On 4/26/2023 at 11:16 AM, tooz said: hello @giseleznev, PCM5102PW and PCM1804DBR are not supported at the moment Hi, I'm adding support of this chips. I want to use hifiberry.*c and other files as a reference, can't find them for tinker board 2, just see them in official repo for tinker board (not 2), believe they are different. Please, could you send me all hifiberry*.c, iqaudio*.c, justboom*.c files from /sound/soc/rockchip/ for tinker board 2. Thanks a lot ! Share this post Link to post Share on other sites
tooz 56 Posted May 11, 2023 hello @giseleznev, 19 hours ago, giseleznev said: Please, could you send me all hifiberry*.c, iqaudio*.c, justboom*.c files from /sound/soc/rockchip/ for tinker board 2. these can be found here, directory is /kernel/sound/soc/rockchip: kernel/sound/soc/rockchip at linux4.19-rk3399-debian10 · TinkerBoard2/kernel · GitHub Share this post Link to post Share on other sites
giseleznev 0 Posted May 11, 2023 3 hours ago, tooz said: hello @giseleznev, these can be found here, directory is /kernel/sound/soc/rockchip: kernel/sound/soc/rockchip at linux4.19-rk3399-debian10 · TinkerBoard2/kernel · GitHub Thanks a lot ! Where can I get instructions for kernel compiling ? It doesn't suit for tinker board 2 https://gist.github.com/TinkerTeam/6286550ce70d34f6b3d483cd803da786 analog of rk3288-tinker.dtb is missing Share this post Link to post Share on other sites
tooz 56 Posted May 12, 2023 hello @giseleznev, 15 hours ago, giseleznev said: Where can I get instructions for kernel compiling ? It doesn't suit for tinker board 2 kernel build process instruction for tinker board 2s can be found here: Developer Guide · TinkerBoard/TinkerBoard Wiki (github.com) Share this post Link to post Share on other sites
giseleznev 0 Posted May 12, 2023 8 hours ago, tooz said: hello @giseleznev, kernel build process instruction for tinker board 2s can be found here: Developer Guide · TinkerBoard/TinkerBoard Wiki (github.com) Hi, currently there are no build.sh and docker-builder-run.sh in the repo, so how can I build 4.19 ? In the attached instruction they are needed. Share this post Link to post Share on other sites
tooz 56 Posted May 12, 2023 hello @giseleznev, you need to set up the build enviornment first: Install Docker environment Uninstall old versions $ sudo apt-get remove docker docker-engine docker.io containerd runc Install Docker Engine – Community $ sudo apt-get update $ sudo apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common $ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add - $ sudo apt-key fingerprint 0EBFCD88 $ sudo add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" $ sudo apt-get update $ sudo apt-get install docker-ce docker-ce-cli containerd.io $ sudo docker run hello-world Reference: https://docs.docker.com/engine/install/ubuntu/ Manage Docker as a non-root user $ sudo groupadd docker $ sudo usermod -aG docker $USER $ newgrp docker $ docker run hello-world Reference: https://docs.docker.com/engine/install/linux-postinstall/ Code compiling Go to the directory where you have downloaded the code base and execute the script. This will take a while to install the necessary packages on the host and build the Docker image. $ ./docker_builder/docker-builder-run.sh Once the above is done, you are in the shell of the newly started Docker container as the following. You can start to issue commands as usual. Successfully built 702bff5a9b3f Successfully tagged asus/tinker_2-linux-builder:latest Options to run docker: --privileged --rm -it --volume /DIRECTORY_PATH_TO_SOURCE:/source your_usernmae@292c696527f6:/source$ You can issue the following command to build all the images for Debian. All the images will be saved in the directory rockdev. $ ./build.sh It will generate a file which named sdboot.img and located at [source tree]/rockdev/sdboot.img Compiling u-boot/Kernel/Debian separately u-boot $ ./build.sh uboot It will generate a file which named uboot.img and located at [source tree]/u-boot/uboot.img Kernel $ ./build.sh kernel It will generate a file which named boot.img and located at [source tree]/kernel/boot.img Debian $ ./build.sh debian It will generate a file which named linaro-rootfs.img and located at [source tree]/debian/linaro-rootfs.img Share this post Link to post Share on other sites
giseleznev 0 Posted May 12, 2023 (edited) @tooz there is no ./docker_builder/docker-builder-run.sh file here: https://github.com/TinkerBoard2/kernel Edited May 12, 2023 by giseleznev Share this post Link to post Share on other sites
tooz 56 Posted May 12, 2023 hello @giseleznev, https://github.com/TinkerBoard2/docker_builder Share this post Link to post Share on other sites
giseleznev 0 Posted May 12, 2023 3 minutes ago, tooz said: hello @giseleznev, https://github.com/TinkerBoard2/docker_builder Thanks a lot ! Now build.sh is missing Share this post Link to post Share on other sites
giseleznev 0 Posted May 12, 2023 12 minutes ago, tooz said: hello @giseleznev, https://github.com/TinkerBoard2/docker_builder Seems like this script doesn't work well: cp: cannot stat '/home/coder/kernel/debian/ubuntu-build-service/packages': No such file or directory no debian dir here https://github.com/TinkerBoard2/kernel Share this post Link to post Share on other sites
giseleznev 0 Posted May 12, 2023 OK, I clonned https://github.com/TinkerBoard2/debian, got debian dir. But no build.sh Share this post Link to post Share on other sites
tooz 56 Posted May 14, 2023 hello @giseleznev, please download the complete source code: execute the following command in the terminal to download source code from github: $ repo init -u https://github.com/TinkerBoard2/manifest.git -b linux4.19-rk3399-debian10 $ repo sync Share this post Link to post Share on other sites
giseleznev 0 Posted May 14, 2023 9 hours ago, tooz said: hello @giseleznev, please download the complete source code: execute the following command in the terminal to download source code from github: $ repo init -u https://github.com/TinkerBoard2/manifest.git -b linux4.19-rk3399-debian10 $ repo sync how long should be syncing? I'm on 14% more than 30 minutes, is it ok ? Share this post Link to post Share on other sites
giseleznev 0 Posted May 14, 2023 @tooz Synced lasted 4 hours, now ok. Got it, then did ./docker_builder/docker-builder-run.sh Now I have a problem inside a docker after ./build.sh Log attached. Please help! ============Start building kernel============ TARGET_ARCH =arm64 TARGET_KERNEL_CONFIG =tinker_board_2_defconfig TARGET_KERNEL_DTS =rk3399-tinker_board_2 TARGET_KERNEL_CONFIG_FRAGMENT = ========================================== arch/arm64/configs/tinker_board_2_defconfig:205:warning: override: reassigning to symbol NETFILTER arch/arm64/configs/tinker_board_2_defconfig:206:warning: override: reassigning to symbol IP_NF_MANGLE # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig CALL scripts/checksyscalls.sh CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o AR init/built-in.a GZIP kernel/config_data.gz make[2]: *** No rule to make target 'net/netfilter/xt_TCPMSS.o', needed by 'net/netfilter/built-in.a'. Stop. scripts/Makefile.build:637: recipe for target 'net/netfilter' failed make[1]: *** [net/netfilter] Error 2 make[1]: *** Waiting for unfinished jobs.... Makefile:1194: recipe for target 'net' failed make: *** [net] Error 2 make: *** Waiting for unfinished jobs.... fatal: not a git repository (or any parent up to mount point /) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). ERROR: Running build_kernel failed! ERROR: exit code 2 from line 674: make ARCH=$RK_ARCH $RK_KERNEL_DTS.img -j$RK_JOBS Share this post Link to post Share on other sites
tooz 56 Posted May 15, 2023 hello @giseleznev, 9 hours ago, giseleznev said: make[2]: *** No rule to make target 'net/netfilter/xt_TCPMSS.o', needed by 'net/netfilter/built-in.a'. Stop. scripts/Makefile.build:637: recipe for target 'net/netfilter' failed the cause might be the build enviornment, the filesystem you're compiling kernel on has to be case-sensitive (such as ubuntu), if you're using mac os for compiling it's likely to fail. what is your build enviornment? reference: https://lkml.org/lkml/2020/5/6/1301 Share this post Link to post Share on other sites
giseleznev 0 Posted May 15, 2023 (edited) @tooz Thanks a lot! Really worked for me, but now I'm getting a new error: It's true, there no mk-base-debian.sh in a debian_new dir Running build_modules succeeded. Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN. =========Start building debian for arm64========= ./build.sh: line 829: ./mk-base-debian.sh: No such file or directory ERROR: Running build_debian failed! ERROR: exit code 127 from line 829: RELEASE=$RK_DEBIAN_VERSION TARGET=desktop ARCH=$ARCH ./mk-base-debian.sh Edited May 15, 2023 by giseleznev Share this post Link to post Share on other sites
tooz 56 Posted May 15, 2023 hello @giseleznev, 2 hours ago, giseleznev said: Running build_modules succeeded. Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN. =========Start building debian for arm64========= ./build.sh: line 829: ./mk-base-debian.sh: No such file or directory these are included in the sources: TinkerBoard2/debian (github.com) please be sure to download them too Share this post Link to post Share on other sites
giseleznev 0 Posted May 15, 2023 1 hour ago, tooz said: hello @giseleznev, these are included in the sources: TinkerBoard2/debian (github.com) please be sure to download them too I see it in sources /debian, but there no mk-base-debian.sh in /debian_new dir, as needed in a build script Share this post Link to post Share on other sites
giseleznev 0 Posted May 16, 2023 @tooz Build script doesn't work without mk-base-debian.sh in /debian_new, how to build 4.19 then? Share this post Link to post Share on other sites
giseleznev 0 Posted May 18, 2023 @tooz hey, I need to build 4.19, please help ! Share this post Link to post Share on other sites
tooz 56 Posted May 18, 2023 hello @giseleznev, On 5/16/2023 at 5:38 PM, giseleznev said: mk-base-debian.sh should be there once you repo sync if you're not using docker, run ./build.sh if you're using docker then ./docker_builder/docker-builder-run.sh build.sh Share this post Link to post Share on other sites
giseleznev 0 Posted May 18, 2023 @tooz coder@mod4:~/Projects/tinker_2$ python3 /usr/bin/repo sync warning: Python 3 support is currently experimental. YMMV. Please use Python 2.6 - 2.7 instead. ... A new version of repo (2.32) is available. ... New version is available at: /home/coder/Projects/tinker_2/.repo/repo/repo ... The launcher is run from: /usr/bin/repo !!! The launcher is not writable. Please talk to your sysadmin or distro !!! to get an update installed. Fetching: 100% (55/55), done in 1m53.075s repo sync has finished successfully. coder@mod4:~/Projects/tinker_2$ ./docker_builder/docker-builder-run.sh Docker is installed and the execute permission is granted. User coder is in the group docker. The package qemu-user-static is installed. The package binfmt-support is installed. There is no directory path to the source provided. Use the default directory path to the source [/home/coder/Projects/tinker_2]. Sending build context to Docker daemon 703.5kB Step 1/24 : FROM ubuntu:18.04 ---> 3941d3b032a8 Step 2/24 : ARG DEBIAN_FRONTEND=noninteractive ---> Using cache ---> 87dc09c519f1 Step 3/24 : ARG userid ---> Using cache ---> c252a5fc6017 Step 4/24 : ARG groupid ---> Using cache ---> f13d24d94dbc Step 5/24 : ARG username ---> Using cache ---> 6dcdfb098a80 Step 6/24 : COPY packages /packages ---> Using cache ---> 7700bfeba439 Step 7/24 : COPY device-tree-compiler_1.4.7-4_amd64.deb . ---> Using cache ---> 694bb7ddb575 Step 8/24 : RUN apt-get update ---> Using cache ---> 996afe4c0b92 Step 9/24 : RUN apt-get install -y repo git ssh make gcc libssl-dev liblz4-tool expect g++ patchelf chrpath gawk texinfo chrpath diffstat binfmt-support qemu-user-static live-build bison flex fakeroot cmake gcc-multilib g++-multilib unzip device-tree-compiler python-pip ncurses-dev python-pyelftools ---> Using cache ---> 69dfbd1b9f1a Step 10/24 : RUN apt-get update && apt-get install -y kmod expect patchelf ---> Using cache ---> 94fb903151db Step 11/24 : RUN apt-get update && apt-get install -y zip mtools ---> Using cache ---> 3ac5a80f9d7d Step 12/24 : RUN apt-get install -y binfmt-support qemu-user-static live-build ---> Using cache ---> 49e41b1a75b6 Step 13/24 : RUN apt-get install -y bc time rsync ---> Using cache ---> 9f60ffcef5e2 Step 14/24 : RUN apt-get install -y zstd ---> Using cache ---> da9c73706cf0 Step 15/24 : RUN apt-get update && apt-get install -y locales ---> Using cache ---> c475127e3538 Step 16/24 : RUN dpkg -i device-tree-compiler_1.4.7-4_amd64.deb ---> Using cache ---> 8f0cd55e4ec6 Step 17/24 : RUN dpkg -i /packages/* || apt-get install -f -y ---> Using cache ---> ec0c4d58f339 Step 18/24 : RUN rm device-tree-compiler_1.4.7-4_amd64.deb ---> Using cache ---> e50065a84a30 Step 19/24 : RUN locale-gen en_US.UTF-8 ---> Using cache ---> 736747386d07 Step 20/24 : RUN groupadd -g $groupid $username && useradd -m -u $userid -g $groupid $username && echo "$username ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers && echo $username >/root/username ---> Using cache ---> 081c901cc447 Step 21/24 : ENV HOME=/home/$username ---> Using cache ---> 03a2ea164546 Step 22/24 : ENV USER=$username ---> Using cache ---> 5a8ed192fd95 Step 23/24 : WORKDIR /source ---> Using cache ---> 50d9bf27fb76 Step 24/24 : ENTRYPOINT chroot --skip-chdir --userspec=$(cat /root/username):$(cat /root/username) / /bin/bash -i ---> Using cache ---> e4c4537eb6ba Successfully built e4c4537eb6ba Successfully tagged asus/tinker_2-linux-builder:latest Options to run docker: --privileged --rm -it --volume /home/coder/Projects/tinker_2:/source coder@828f3ca52a6b:/source$ ./build.sh VERSION: debug VERSION_NUMBER: eng-coder-20230518 RELEASE_NAME: Tinker_Board_2-Debian-Buster-eng-coder-20230518 processing option: allsave ============================================ TARGET_ARCH=arm64 TARGET_PLATFORM=tinker_board_2 TARGET_UBOOT_CONFIG=tinker_board_2 TARGET_SPL_CONFIG= TARGET_KERNEL_CONFIG=tinker_board_2_defconfig TARGET_KERNEL_DTS=rk3399-tinker_board_2 TARGET_TOOLCHAIN_CONFIG= TARGET_BUILDROOT_CONFIG=rockchip_tinker_board_2 TARGET_RECOVERY_CONFIG=rockchip_rk3399_recovery TARGET_PCBA_CONFIG=rockchip_rk3399_pcba TARGET_RAMBOOT_CONFIG= ============================================ ============Start building uboot============ TARGET_UBOOT_CONFIG=tinker_board_2 ========================================= ## make tinker_board_2_defconfig -j8 # # configuration written to .config # scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h GEN include/autoconf.mk.dep CFG u-boot.cfg CFG spl/u-boot.cfg CFG tpl/u-boot.cfg GEN spl/include/autoconf.mk GEN include/autoconf.mk GEN tpl/include/autoconf.mk CHK include/config/uboot.release CHK include/generated/timestamp_autogenerated.h UPD include/generated/timestamp_autogenerated.h CHK include/config.h CFG u-boot.cfg UPD include/config/uboot.release CHK include/generated/version_autogenerated.h UPD include/generated/version_autogenerated.h CHK include/generated/generic-asm-offsets.h CHK include/generated/asm-offsets.h HOSTCC tools/mkenvimage.o HOSTCC tools/fit_image.o HOSTCC tools/image-host.o HOSTCC tools/mkimage.o HOSTCC tools/dumpimage.o HOSTCC tools/rockchip/boot_merger.o HOSTCC tools/rockchip/loaderimage.o HOSTLD tools/loaderimage HOSTLD tools/mkenvimage HOSTLD tools/mkimage HOSTLD tools/dumpimage HOSTLD tools/boot_merger CC arch/arm/cpu/armv8/fwcall.o CC cmd/version.o CC common/main.o LD arch/arm/cpu/armv8/built-in.o LD cmd/built-in.o LD common/built-in.o CC drivers/usb/gadget/f_fastboot.o CC lib/smbios.o CC lib/display_options.o LD drivers/usb/gadget/built-in.o LD lib/built-in.o LD u-boot OBJCOPY u-boot.srec OBJCOPY u-boot-nodtb.bin SYM u-boot.sym make[2]: 'arch/arm/dts/rk3399-evb.dtb' is up to date. COPY u-boot.dtb start=$(/source/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ' '); end=$(/source/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ' '); tools/relocate-rela u-boot-nodtb.bin 0x00200000 $start $end CAT u-boot-dtb.bin CC tpl/arch/arm/mach-rockchip/tpl.o CC spl/arch/arm/cpu/armv8/fwcall.o LD spl/arch/arm/cpu/armv8/built-in.o CC tpl/common/spl/spl.o LD tpl/arch/arm/mach-rockchip/built-in.o CC spl/common/spl/spl.o CC tpl/arch/arm/cpu/armv8/fwcall.o MKIMAGE u-boot.img LD tpl/arch/arm/cpu/armv8/built-in.o LD tpl/common/spl/built-in.o LD spl/common/spl/built-in.o MKIMAGE u-boot-dtb.img COPY u-boot.bin ALIGN u-boot.bin COPY tpl/u-boot-tpl.dtb CC tpl/lib/display_options.o CC spl/lib/display_options.o COPY spl/u-boot-spl.dtb LD tpl/lib/built-in.o LD spl/lib/built-in.o LD tpl/u-boot-tpl LD spl/u-boot-spl OBJCOPY tpl/u-boot-tpl-nodtb.bin CAT tpl/u-boot-tpl-dtb.bin COPY tpl/u-boot-tpl.bin OBJCOPY spl/u-boot-spl-nodtb.bin CAT spl/u-boot-spl-dtb.bin COPY spl/u-boot-spl.bin CFGCHK u-boot.cfg load addr is 0x200000! pack input u-boot.bin pack file size: 1098664(1072 KB) crc = 0xe5e79a4b uboot version: U-Boot 2017.09-gc64e256218-200416 #yzc (Apr 29 2020 - 16:22:05) pack uboot.img success! pack uboot okay! Input: u-boot.bin out:trust.img merge success(trust.img) pack trust okay! Input: /source/rkbin/RKTRUST/RK3399TRUST.ini /source/u-boot ********boot_merger ver 1.2******** Info:Pack loader ok. pack loader okay! Input: /source/rkbin/RKBOOT/RK3399MINIALL.ini /source/u-boot Platform RK3399 is build OK, with new .config(make tinker_board_2_defconfig -j8) /source/prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- Thu May 18 08:46:11 UTC 2023 Running build_uboot succeeded. Skipping build_loader for missing configs: RK_LOADER_BUILD_TARGET. ============Start building kernel============ TARGET_ARCH =arm64 TARGET_KERNEL_CONFIG =tinker_board_2_defconfig TARGET_KERNEL_DTS =rk3399-tinker_board_2 TARGET_KERNEL_CONFIG_FRAGMENT = ========================================== arch/arm64/configs/tinker_board_2_defconfig:205:warning: override: reassigning to symbol NETFILTER arch/arm64/configs/tinker_board_2_defconfig:206:warning: override: reassigning to symbol IP_NF_MANGLE # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig CALL scripts/checksyscalls.sh CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o GZIP kernel/config_data.gz AR init/built-in.a GEN .version CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o AR init/built-in.a AR built-in.a MODPOST vmlinux.o KSYM .tmp_kallsyms1.o KSYM .tmp_kallsyms2.o LD vmlinux SORTEX vmlinux SYSMAP System.map OBJCOPY arch/arm64/boot/Image LZ4C arch/arm64/boot/Image.lz4 Image: kernel.img is ready CALL scripts/checksyscalls.sh Building modules, stage 2. MODPOST 14 modules is not rk356x Image: resource.img (with rk3399-tinker_board_2.dtb logo.bmp logo_kernel.bmp) is ready Image: boot.img (with Image resource.img) is ready Image: zboot.img (with Image.lz4 resource.img) is ready PLEASE CHECK BOARD GPIO POWER DOMAIN CONFIGURATION !!!!! <<< ESPECIALLY Wi-Fi/Flash/Ethernet IO power domain >>> !!!!! Check Node [pmu_io_domains] in the file: /source/kernel/arch/arm64/boot/dts/rockchip/rk3399-tinker_board_2.dts 请再次确认板级的电源域配置!!!!!! <<< 特别是Wi-Fi,FLASH,以太网这几路IO电源的配置 >>> !!!!! 检查内核文件 /source/kernel/arch/arm64/boot/dts/rockchip/rk3399-tinker_board_2.dts 的节点 [pmu_io_domains] pmu1830-supply = < 0x83 regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1500mV regulator-max-microvolt = 1500mV regulator-min-microvolt = 900mV regulator-max-microvolt = 900mV regulator-min-microvolt = 3000mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 12000mV regulator-max-microvolt = 12000mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 3000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 800mV regulator-max-microvolt = 1400mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV bt656-supply = < 0x83 regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1500mV regulator-max-microvolt = 1500mV regulator-min-microvolt = 900mV regulator-max-microvolt = 900mV regulator-min-microvolt = 3000mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 12000mV regulator-max-microvolt = 12000mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 3000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 800mV regulator-max-microvolt = 1400mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV audio-supply = < 0x83 regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1500mV regulator-max-microvolt = 1500mV regulator-min-microvolt = 900mV regulator-max-microvolt = 900mV regulator-min-microvolt = 3000mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 12000mV regulator-max-microvolt = 12000mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 3000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 800mV regulator-max-microvolt = 1400mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV sdmmc-supply = < 0x30 regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1500mV regulator-max-microvolt = 1500mV regulator-min-microvolt = 900mV regulator-max-microvolt = 900mV regulator-min-microvolt = 3000mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 12000mV regulator-max-microvolt = 12000mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 3000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 800mV regulator-max-microvolt = 1400mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV gpio1830-supply = < 0x83 regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 750mV regulator-max-microvolt = 1350mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1500mV regulator-max-microvolt = 1500mV regulator-min-microvolt = 900mV regulator-max-microvolt = 900mV regulator-min-microvolt = 3000mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 12000mV regulator-max-microvolt = 12000mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV regulator-max-microvolt = 3000mV regulator-min-microvolt = 3000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 5000mV regulator-max-microvolt = 5000mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 800mV regulator-max-microvolt = 1400mV regulator-min-microvolt = 3300mV regulator-max-microvolt = 3300mV regulator-min-microvolt = 1800mV regulator-max-microvolt = 1800mV Running build_kernel succeeded. ============Start building kernel modules============ TARGET_ARCH =arm64 TARGET_KERNEL_CONFIG =tinker_board_2_defconfig TARGET_KERNEL_CONFIG_FRAGMENT = ================================================== arch/arm64/configs/tinker_board_2_defconfig:205:warning: override: reassigning to symbol NETFILTER arch/arm64/configs/tinker_board_2_defconfig:206:warning: override: reassigning to symbol IP_NF_MANGLE # # configuration written to .config # scripts/kconfig/conf --syncconfig Kconfig CALL scripts/checksyscalls.sh Building modules, stage 2. MODPOST 14 modules INSTALL drivers/bluetooth/rtk_btusb.ko INSTALL drivers/net/can/can-dev.ko INSTALL drivers/net/can/spi/mcp251x.ko INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex.ko INSTALL drivers/net/wireless/marvell/mwifiex/mwifiex_sdio.ko INSTALL drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/bcmdhd.ko INSTALL drivers/net/wireless/rockchip_wlan/rtl8812AU_8821AU_linux/8812au.ko INSTALL drivers/net/wireless/rockchip_wlan/rtl8814au/8814au.ko INSTALL drivers/net/wireless/rockchip_wlan/rtl8822ce/8822ce.ko INSTALL drivers/net/wireless/rockchip_wlan/rtl8852be/8852be.ko INSTALL net/can/can-bcm.ko INSTALL net/can/can-gw.ko INSTALL net/can/can-raw.ko INSTALL net/can/can.ko DEPMOD 4.19.232 Running build_modules succeeded. Skipping build_toolchain for missing configs: RK_CFG_TOOLCHAIN. =========Start building debian for arm64========= ./build.sh: line 829: ./mk-base-debian.sh: No such file or directory ERROR: Running build_debian failed! ERROR: exit code 127 from line 829: RELEASE=$RK_DEBIAN_VERSION TARGET=desktop ARCH=$ARCH ./mk-base-debian.sh coder@mod4:~/Projects/tinker_2$ find . -name mk-base-debian.sh ./debian/mk-base-debian.sh there is no this file in the debian_new dir Share this post Link to post Share on other sites
Stone_Wu 0 Posted May 18, 2023 @giseleznev We will fix this bug ASAP Share this post Link to post Share on other sites
