Jump to content
Hashimoto Kenichi
eMMC writing in u-boot
Recommended Posts
The following settings were made to save the u-boot env to eMMC.
U-Boot 2022.01
CONFIG_ENV_IS_IN_MMC=y
CONFIG_SYS_MMC_ENV_DEV=0
CONFIG_SYS_MMC_ENV_PART=0
The write operation succeeds once, but then the eMMC stops responding.
Writing by ums is also successful, so writing itself seems to be OK, but there seems to be a problem in the subsequent operation.
What are the problems with writing to eMMC?
Edited by Hashimoto Kenichi
Share this post
Link to post
Share on other sites
=> mmc dev 0
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:8
                ARG                      0x000000aa
                RET                      -110
CMD_SEND:55
                ARG                      0x00000000
                RET                      -110
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:8
                ARG                      0x000000aa
                RET                      -110
CMD_SEND:55
                ARG                      0x00000000
                RET                      -110
CMD_SEND:0
                ARG                      0x00000000
                MMC_RSP_NONE
CMD_SEND:1
                ARG                      0x00000000
                MMC_RSP_R3,4             0xffffffff
CMD_SEND:2
                ARG                      0x00000000
                RET                      -110
CMD_SEND:2
                ARG                      0x00000000
                RET                      -110
CMD_SEND:2
                ARG                      0x00000000
                RET                      -110
CMD_SEND:2
                ARG                      0x00000000
                RET                      -110
CMD_SEND:2
                ARG                      0x00000000
                RET                      -110
Enable CONFIG_MMC_TRACE
Share this post
Link to post
hello @Hashimoto Kenichi,
1. are you using tinker os?
2. what's the error you encountered?
to write in uboot:
1. connect tinker board 2s to an ubuntu machine (tinker board 2s should be in ums mode while connecting)
2. press any key during booting to enter u-boot
3. here's an example using setenv/ printenv, and then savenv
4. saveenv and reboot, printenv test and it returns the right value
Share this post
Link to post
No.
I am using Yocto (kirkstone) with patches.
u-boot version is 2022.01.
The second "mmc dev 0" execution results in an error.
Writing to eMMC, such as saveenv, succeeds, but distro_bootcmd executes "mmc dev 0", so it fails there.
Share this post
Link to post
@Hashimoto Kenichi,
one possible reason might be broken emmc, but we'll need more information to confirm if it's the cause
1, what are the results of:
printenv devnum
and
printenv devtype
2. where was the uboot flashed onto? (such as emmc/ sd card/ other storage ... etc)
3. is there any other storage (such as sd card/ usb flash storage ... etc) attached to tinker board 2s?
Share this post
Link to post
1. what are the results of:
devnum and devtype is not set.
Because I use distro_bootcmd.
eMMC
SD card is removed.
Share this post
Link to post
devnum and devtype are set by default if you're using tinker os, may i know what's the source code you're using for compiling os/ uboot, so we can have a look at the configs?
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
