Jump to content
User 604
4x USB A Camera
Recommended Posts
Just got my new Tinker Board 2S and installed the Debian 11 image (v3.0.6-20230627) on the emmc. All seems to be working.
I need to connect 4x Basler USB3 cameras using the USB A. Since 2S has 3 USB A ports, I used a USB A to USB C adapter for the 4th camera. Tinker Board doc says the USB C port is OTG. Do I need to change any configuration to disable OTG for my use case? I tried gstreamer plugin (https://github.com/basler/gst-plugin-pylon) to capture from the cameras, but everything seems extremely slow. A simple command line "gst-launch-1.0 pylonsrc ! fakesink" even takes a long time, feels like hanging. Any thoughts?
Share this post
Link to post
Share on other sites
hello @User 604
do you have the product name/ serial of the basler usb3 cameras you're using so i can have a look at the specifications and support?
Share this post
Link to post
hello @User 604,
3x USB A ≈13.5W, USB C ≈7.5W; please make sure the adapter that you use provides sufficient power. OTG for USB C means both host mode and device mode are supported at the same time, so no need for extra configuration, if the camera that connects to the USB C port's been detected/ recognized. However please keep in mind that the 4 USB A ports use the same host controller via an usb hub so they share the same bandwith; the USB C uses another host controller and therefore doesn't share the same bandwith with the 4 USB A ports.
please try this command and see if the issue still persists:
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=NV12,width=640,height=480 ! videoconvert ! autovideosink
reference: https://tinker-board.asus.com/doc_tb.html#camera/
Share this post
Link to post
4 Basler USB3 Vision cameras are connected, but during our testing, we only started gs-launch-1.0 using the camera [0] and [1]:
[0]: 23298703    acA2440-35um
[1]: 23299426    acA2440-35um
[2]: 23844311    daA2500-14um
[3]: 40120759    daA3840-45um
We use the official power adapter that comes with Tinker Board 2s.
Share this post
Link to post
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=NV12,width=640,height=480 ! videoconvert ! autovideosink
Setting pipeline to PAUSED ...
No protocol specified
arm_release_ver of this libmali is 'r18p0-01rel0', rk_so_ver is '4'.Using mplane plugin for capture
Pipeline is live and does not need PREROLL ...
Got context from element 'autovideosink0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayGBM\)\ gldisplaygbm0";
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
../sys/v4l2/gstv4l2src.c(700): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.038114558
Setting pipeline to NULL ...
Freeing pipeline ...
The command completed immediately.
Share this post
Link to post
hello @User 604,
1. did you get camera preview sucessfully when you executed command?
2. seems like the cameras you use don't support NV12 format, also the cameras used are not specified in the commands.
please use this command to check the cameras' video nodes:
v4l2-ctl --list-devices
and then use this commend to check if you can get a preview smoothly:
gst-launch-1.0 v4l2src device=/dev/videoN ! videoconvert ! autovideosink
^ /dev/videoN -- please change the 'N' to the actual # of the video node you're using
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
