walter 0 Posted September 28, 2023 你好 你能告訴我是否有4.4.132+ 的 linux-headers 檔案?我已經有了linux-headers-4.4.194_4.4.194-7_armhf.deb 的文件 Share this post Link to post Share on other sites
tooz 56 Posted October 17, 2023 hello @walter, the kernel header (4.4.132) can be downloaded here: https://www.asuswebstorage.com/navigate/a/#/s/0A7B214566FE4B3F9439CC570B5390284 Share this post Link to post Share on other sites
tooz 56 Posted October 17, 2023 Building Linux headers for Tinker Board R2.0: git clone https://github.com/TinkerBoard/debian_kernel.git cd debian_kernel make ARCH=arm distclean make ARCH=arm miniarm-rk3288_defconfig make ARCH=arm bindeb-pkg RK_KERNEL_DTS=rk3288-miniarm to fix the errors during compilation: error 1: CC arch/arm/kernel/vdso.o arch/arm/kernel/vdso.c: In function ‘vdso_init’ arch/arm/kernel/vdso.c:182:6: warning: ‘memcmp’ reading 4 bytes from a region of size 1 [-Wstringop-overflow=] error, forbidden warning: vdso.c:182 make[3]: *** [scripts/Makefile.build:278: arch/arm/kernel/vdso.o] Error 1 make[2]: *** [Makefile:1028: arch/arm/kernel] Error 2 make[1]: *** [scripts/package/Makefile:96: bindeb-pkg] Error 2 make: *** [Makefile:1316: bindeb-pkg] Error 2 cause: The current kernel sources provided are not compatible as of right now with GCC8. Until the kernel sources are patched, you need to use a gcc version that is compatible fix: use gcc7 instead of gcc8 error 2: CC drivers/net/usb/qmi_wwan.o drivers/net/usb/qmi_wwan.c: In function ‘qmi_wwan_tx_fixup’: drivers/net/usb/qmi_wwan.c:32:2: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation] error, forbidden warning: qmi_wwan.c:32 make[5]: *** [scripts/Makefile.build:278: drivers/net/usb/qmi_wwan.o] Error 1 make[4]: *** [scripts/Makefile.build:484: drivers/net/usb] Error 2 make[3]: *** [scripts/Makefile.build:484: drivers/net] Error 2 make[2]: *** [Makefile:1028: drivers] Error 2 make[1]: *** [scripts/package/Makefile:96: bindeb-pkg] Error 2 make: *** [Makefile:1316: bindeb-pkg] Error 2 fix: edit the qmi_wwan_tx_fixup in /qmi_wwan.c, and start a new line for the if statement else skb_reset_mac_header(skb); if (skb_pull(skb, Eth_HLEN)) { return skb; } else { Dev_err(&dev->intf->dev,”Packet Dropped “); Share this post Link to post Share on other sites
