M95D 0 Posted September 28, 2023 Did anyone try to use a recent kernel version on Asus Tinkerboard S? I tried v6.5, but wifi is very rarely detected during boot. Share this post Link to post Share on other sites
tooz 56 Posted October 12, 2023 hello @M95D, does it happen all the time? what's the occurence? which os did you compile? is it a debian with kernel v6.5? Share this post Link to post Share on other sites
M95D 0 Posted October 18, 2023 "Very rarely detected" means the error happens frequently and it only works sometimes. The error is this one: [ 4.670203][ T34] mmc_host mmc2: card is non-removable. [ 4.703241][ T34] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 4.757624][ T44] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 4.777618][ T44] mmc2: error -84 whilst initialising SDIO card [ 4.811293][ T44] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) [ 4.893354][ T44] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 4.903224][ T44] mmc2: error -84 whilst initialising SDIO card [ 4.936591][ T44] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) [ 4.977762][ T44] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 4.986768][ T44] mmc2: error -84 whilst initialising SDIO card [ 5.014797][ T44] mmc_host mmc2: Bus speed (slot 0) = 187500Hz (slot req 187500Hz, actual 187500HZ div = 0) [ 5.337342][ T44] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 5.350427][ T44] mmc2: error -84 whilst initialising SDIO card [ 5.433537][ T44] mmc2: Failed to initialize a non-removable card I compiled Gentoo, but I didn't use Gentoo kernel. I used the mainline, official, torvalds' kernel from github. Share this post Link to post Share on other sites
tooz 56 Posted October 19, 2023 hello @M95D, kernel v.6 is not supported just yet, the reason why the wifi is hardly detected might be the mmc sdio driver difference (kernel v.6 & kernel v.4.4) [ 4.394371] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 4.489425] mmc_host mmc2: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0) [ 4.490020] mmc2: new high speed SDIO card at address 0001 [ 6.561012] mmc2:mmc host rescan start! Share this post Link to post Share on other sites
