Jump to content
Sign in to follow this
lloydhussell
Android/Linux system is audio driver order with usb mic attached on boot.
Recommended Posts
As you can see from the logs below, I used cat for the cards in proc/asound. First without the mic attached, second with the mic attached at runtime, and third with the mic attached at boot.
you can see that for some strange reason, the order is broken and 0(which I suspect is the mic array) is not shown. All help is greatly appreciated.
127|Tinker_Board_2:/proc/asound $ cat cards
 0 [hdmisound      ]: hdmi-sound - hdmi-sound
                      hdmi-sound
 1 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
Tinker_Board_2:/proc/asound $ aplay -l
/system/bin/sh: aplay: inaccessible or not found
                      hdmi-sound
 2 [ArrayUAC10     ]: USB-Audio - ReSpeaker 4 Mic Array (UAC1.0)
                      SEEED ReSpeaker 4 Mic Array (UAC1.0) at usb-xhci-hcd.1.auto-1.1, full speed
Tinker_Board_2:/proc/asound $ %        lloydhussell@MAC-Y6XGW6XJ0H Dukebox-Android % adb shell
Tinker_Board_2:/ $ cd proc/asound/
 1 [hdmisound      ]: hdmi-sound - hdmi-sound
                      hdmi-sound
 2 [rockchipcdndpso]: rockchip-cdndp- - rockchip-cdndp-sound
Share this post
Link to post
Share on other sites
hello @lloydhussell,
what's the result if you sudo aplay -l instead of aplay -l? and what's the version of the linux os you're using?
20 hours ago, lloydhussell said:
Tinker_Board_2:/proc/asound $ aplay -l /system/bin/sh: aplay: inaccessible or not found
Share this post
Link to post
I can't use aplay because it's the Android 11 image I am using. I saw I could use tinymix and tinyplay and something else, but I couldn't really see much going on there, to be honest.
Unless I am missing something, both of the aplay -l commands you posted are exactly the same?
Share this post
Link to post
My mistake, you used sudo before the other. I will try and use sudo later, yeah. I think I may have tried it already actually. And using tinymix and tinyplay I used su, which afaiu is the sudo on Android.
Edited by lloydhussell
Share this post
Link to post
hello @lloydhussell
the order of sound cards depends on which driver completes first -- so for tinker board 2s( without any modification): hdmi=0, dp=1, following new device=2, new device2=3 and so on.
for android, the order goes: usb-> hdmi-> dp, so when booting with usb mic inserted it's usb=0, hdmi=1, dp=2; and changes to hdmi=1, dp=2 when usb mic is removed
Share this post
Link to post
So the issue was actually in my application code. I was iterating through the interfaces on the USB devices and claiming the interface for communication, as well as iterating the endpoints to use them for direct USB comms.
I then used the defined interface information provided with the component manufacturer documentation and it worked.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
