wahaha 4 Posted November 13, 2023 I reinstalled debian onto the tinkeboard 2s, and added the below to /etc/network/interfaces # Add the following (for ethernet): auto lo eth0 allow-hotplug eth0 iface lo inet loopback iface eth0 inet dhcp However, when I did: ifconfig It produced the below result: eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.50.146 netmask 255.255.255.0 broadcast 192.168.50.255 inet6 fe80::7e10:c9ff:feed:f504 prefixlen 64 scopeid 0x20<link> ether 7c:10:c9:ed:f5:04 txqueuelen 1000 (Ethernet) RX packets 1536 bytes 159578 (159.5 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 908 bytes 199763 (199.7 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 35 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 90 bytes 6869 (6.8 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 90 bytes 6869 (6.8 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 As you can see, wlan / wlp1s0 is not found in there. As such, I am unable to connect via wifi / bluetooth. Is there a driver / kernel / firmware that I can use to update the drivers so that the wifi and bluetooth modules are detectable? Share this post Link to post Share on other sites
tooz 56 Posted November 13, 2023 hello @wahaha, not sure if it's a hardware or driver issue, to get a little further: 1. what is the image version you're using? is it debian 11 v.3.0.6? 2. what are the results when you execute the commands: ifconfig -a sudo lspci sudo lsmod Share this post Link to post Share on other sites
wahaha 4 Posted November 13, 2023 hi @tooz jakew@tk0:~$ lspci 00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port 01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter jakew@tk0:~$ sudo lsmod Module Size Used by jakew@tk0:~$ jakew@tk0:~$ ifconfig -a eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.50.146 netmask 255.255.255.0 broadcast 192.168.50.255 inet6 fe80::7e10:c9ff:feed:f504 prefixlen 64 scopeid 0x20<link> ether 7c:10:c9:ed:f5:04 txqueuelen 1000 (Ethernet) RX packets 416 bytes 37385 (37.3 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 386 bytes 228443 (228.4 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 35 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 84 bytes 6308 (6.3 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 84 bytes 6308 (6.3 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 jakew@tk0:~$ lspci 00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3399 PCI Express Root Port 01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter jakew@tk0:~$ sudo lsmod Module Size Used by jakew@tk0:~$ seems like might be a driver issue? since lscpi is showing hardware results. Note: I used debian 11 v3.0.6 --> but I used debootstrap to install a variant of ubuntu instead. which probably didn't install the driver (i think?) Share this post Link to post Share on other sites
tooz 56 Posted November 13, 2023 hello @wahaha, looks like the driver isn't initialised, please try: sudo modprobe 8822ce uname -a Share this post Link to post Share on other sites
wahaha 4 Posted November 13, 2023 Yea I think it'll work. I copied the modules over. Will enable it and try. But I believe it'll work. Thanks! Also, can I please trouble you to help upload the kernel resources for 5.10 to git so that I can customize my kernel and the modules? Share this post Link to post Share on other sites
