shizimi 0 Posted January 9, 2024 Is there a way to hide the system message that appears at the top right of the desktop screen? Share this post Link to post Share on other sites
tooz 56 Posted January 9, 2024 hello @shizimi, are you using the debian tinker os or the android one? Share this post Link to post Share on other sites
shizimi 0 Posted January 9, 2024 Oh, sorry I forgot to write,use debian tinker os Share this post Link to post Share on other sites
tooz 56 Posted January 9, 2024 hello @shizimi, you can either: 1. remove the notification package with this command: sudo apt-get remove xfce4-notifyd sudo apt reboot now or 2. toolbar ->preferences ->desktop session settings -> uncheck every application, and then reboot tinker board r2.0 method #2 will not remove the audio jack plugged in notification, if you'd like to remove the notifications related-to the audio jack, comment out everything that uses 'notify-send' in the directory /etc/audio/ to remove the audio jack detection function completely, edit the audio.conf and make the config 'jack_auto_switch' =off sudo vim /etc/audio/audio.conf jack_auto_switch="off" Share this post Link to post Share on other sites
