Jump to content
Bram
Clone existing tinker board R2.0
Recommended Posts
For a project, I need to create several identical tinker boards.
I have one that is programmed and works well, now I would like to clone the SD card and create an identical one.
Can somebody help me with this?
I tried using the Win32DiskImager tool, however when I insert the SD card into my pc it shows up as multiple different stations and none of them I can work with.
Thanks in advance!
Share this post
Link to post
Share on other sites
hello @Bram,
if you're using a windows pc and see these popping up just ignore -- these are the partitions divided in the storage
i use balenaetcher: https://etcher.balena.io/ there's a 'clone drive' option that allows users to clone sd cards/ usb drives
win32diskimger should work too
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
