Jump to content
ChaJH
Recognize or change the display resolution on the Tinkerboard 2s
Recommended Posts
Hello everyone!
I have a Tinker Board 2s and it also has a touchable LCD display.
The products of display model are as follows
>> 9.3inch Capacitive Touch Display, High Brightness, 1600×600, Optical Bonding Toughened Glass Panel, HDMI Interface, IPS | 9.3inch 1600x600 LCD (waveshare.com)
The display and the Tinker Board are connected using HDMI only.
And the os image on the Tinker Board is Android 12. (Tinker_Board_2-Android11-v2.0.8-20220503)
First of all, the lcd display on the Tinker Board shows Android's screen well.
However, the screen is streched a bit vertically.
I,ve also tried the following ways to solve this problem myself.
on the Tinker Board 2s :
       Setting > Display > HDMI > (SCREEN SETTING) HDMIA: Change Resolution
But it didn't work....
How can I change the resolution to a normal state where the vertical is not stretched?
Or does Tinker Board not support the resolution of the display I use....?
I would appreciate it if you could let me know the solution!
Thank you in advance.
Share this post
Link to post
Share on other sites
hello @ChaJH,
1 hour ago, ChaJH said:
Could the Android OS version be a problem...?
no, just checking the environment
this panel's resolution is 1600x600, which is supported on tinker board 2s, but it might be blocked by resolution_white.xml
please use commands below to remove resolution white
adb root
adb remount
adb shell
rm -rf /system/usr/share/resolution_white.xml
and then reboot tinker board 2s
the expected result is the 1600x600 resolution is supported on tinker board 2s
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Create New...
