JFB 0 Posted March 11, 2024 I have a tinker board 2S and a EP06-A Quectel modem. How can I get the Android OS to recognize the modem to get on the cellular network? Share this post Link to post Share on other sites
tooz 56 Posted March 12, 2024 hello @JFB, have you tried using the latest os (android 12 v.3.0.2)? we don't have this module in the lab to test it out at the moment but it should work on this version: Tinker Board 2 /2S Android 12 V3.0.2 Share this post Link to post Share on other sites
JFB 0 Posted March 12, 2024 Good day @tooz Yes I load Android 12 v3.0.2 and ha e it working on the board. I am able to get WiFi up, however it seems not to recognize the USB modem with the Quectel EP06-A, which does have an active SIM card. Are there drivers I need to install? Share this post Link to post Share on other sites
tooz 56 Posted March 13, 2024 hello @JFB, you're right, this module is yet to be supported, we will add it to the next release (target release date 2024/04) Share this post Link to post Share on other sites
JFB 0 Posted March 13, 2024 @tooz Much appreciated, how would I connect to the usb modem if it was a supported modem? Is there specific setting I need to have set, such as USB configuration, to get the board to recognize and use the cellular network? Share this post Link to post Share on other sites
JFB 0 Posted March 13, 2024 As I do have a couple of EM06-E that I have tried to connect, however I am not sure how it should look or what settings I need to have set in the Android OS for it connect. Share this post Link to post Share on other sites
