denchakapon 5 Posted April 14 Hi guys. Let me share Android 12 for Tinkerboard / Tinkerboard S 1-st revision (not R2.0) which Asus marked as outdated/legacy. You can find download link below: Download Android 12 ROM Tinkerboard (not R2.0) Bug reporting are welcome. Release is based on official Asus firmware for Tinkerboard S R2.0. 1 Share this post Link to post Share on other sites
SPARKRU 0 Posted April 16 (edited) Wi-Fi doesn't work... I've encountered a problem. I use microSD 32Gb and 64Gb. Android 12 does not see the full microSD capacity. I tried doing a factory reset, but it didn't help. I tried different programs for recording the image - balenaEtcher, win32diskimager, USB Image Tool. Wi-Fi не работает... Я столкнулся с проблемой. Использую microSD 32Гб и 64Гб. Android 12 не видит всю емкость microSD. Пробовал сделать сброс к заводским настройкам, не помогло. Пробовал разные программы для записи изображения - balenaEtcher, win32diskimager, USB Image Tool. Edited April 16 by SPARKRU Share this post Link to post Share on other sites
